i2c-gpio doesn't need a reg property. Change the node names to i2c-gpio-x
as used in other dts to remove the unit-address.
Solves:
Warning (unit_address_vs_reg): Node /i2c@0 has a unit name, but no reg property
Warning (unit_address_vs_reg): Node /i2c@1 has a unit name, but no reg property
Warning (unit_address_vs_reg): Node /i2c@2 has a unit name, but no reg property
Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
Remove leading zeros in OHCI node for at91sam9260 based boards.
Signed-off-by: Raashid Muhammed <raashidmuhammed@zilogic.com>
Reviewed-by: Vijay Kumar B. <vijaykumar@bravegnu.org>
The clocks group properties and the clock@0 node are useless, remove them
to avoid copy pasting in future device trees.
Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com>
Though the keyboard driver for GPIO buttons(gpio-keys) will continue to
check for/support the legacy "gpio-key,wakeup" boolean property to
enable gpio buttons as wakeup source, "wakeup-source" is the new
standard binding.
This patch replaces the legacy "gpio-key,wakeup" with the unified
"wakeup-source" property in order to avoid any futher copy-paste
duplication.
Cc: Alexandre Belloni <alexandre.belloni@free-electrons.com>
Cc: Jean-Christophe Plagniol-Villard <plagnioj@jcrosoft.com>
Signed-off-by: Sudeep Holla <sudeep.holla@arm.com>
The network_red LED uses the 4th PWM device.
Signed-off-by: Gaël PORTAY <g.portay@overkiz.com>
The kizbox dts are using the deprecated linux,stdout-path. Replace those by
stdout-path.
Acked-by: Gaël PORTAY <g.portay@overkiz.com>
Simplify the bootargs since the platform is booting from an initramfs and
set the kernel stdout path to DBGU.
Acked-by: Boris Brezillon <boris.brezillon@free-electrons.com>
Acked-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
Re-size NAND partitions since the bootstrap is able to read volumes from an
UBI image.
This:
* moves to pwm-leds using tcb-pwm driver and
* renames leds to pwm:<color>:<function>.
This:
* fixes active level of GPIO (active high) and
* renames buttons:
- reset (PB_RST), and
- mode to user (PB_USER).
USART3 is the only serial UART accessible.
Consists in:
* sorting nodes by address as possible or alphabetically,
* adding myself as new maintainer and
* update license.
Rename to match AT91 naming convention.
