Use the new EBI/NAND bindings to declare NAND chips and remove old NAND
nodes along the way.
Note that we keep using old bindings in at91rm9200.dtsi because this
SoC is not supported by the EBI driver.
Signed-off-by: Boris Brezillon <boris.brezillon@free-electrons.com>
Tested-by: Peter Rosin <peda@axentia.se>
Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
The at24 driver allows to register I2C EEPROM chips using different vendor
and devices, but the I2C subsystem does not take the vendor into account
when matching using the I2C table since it only has device entries.
But when matching using an OF table, both the vendor and device has to be
taken into account so the driver defines only a set of compatible strings
using the "atmel" vendor as a generic fallback for compatible I2C devices.
So add this generic fallback to the device node compatible string to make
the device to match the driver using the OF device ID table.
Signed-off-by: Javier Martinez Canillas <javier@osg.samsung.com>
Acked-by: Peter Rosin <peda@axentia.se>
The Axentia TSE-850 is a SAMA5D3-based device designed to generate
FM subcarrier signals.
Signed-off-by: Peter Rosin <peda@axentia.se>
Acked-by: Rob Herring <robh@kernel.org>
Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com>
