Based on 1 normalized pattern(s):
licensed under gplv2 or later
extracted by the scancode license scanner the SPDX license identifier
GPL-2.0-or-later
has been chosen to replace the boilerplate/reference in 118 file(s).
Reviewed-by: Jilayne Lovejoy <opensource@jilayne.com>
Reviewed-by: Steve Winslow <swinslow@gmail.com>
Reviewed-by: Allison Randal <allison@lohutok.net>
Cc: linux-spdx@vger.kernel.org
Link: https://lkml.kernel.org/r/20190519154040.961286471@linutronix.de
Use tcb0 for timers as selected in at91_dt_defconfig.
Cc: Raashid Muhammed <raashidmuhammed@zilogic.com>
Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com>
Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
i2c-gpio doesn't need a reg property. Change the node names to i2c-gpio-x
as used in other dts to remove the unit-address.
Solves:
Warning (unit_address_vs_reg): Node /i2c@0 has a unit name, but no reg property
Warning (unit_address_vs_reg): Node /i2c@1 has a unit name, but no reg property
Warning (unit_address_vs_reg): Node /i2c@2 has a unit name, but no reg property
Add power led node and rename status led node.
Signed-off-by: Raashid Muhammed <raashidmuhammed@zilogic.com>
Reviewed-by: Vijay Kumar B. <vijaykumar@bravegnu.org>
Add missing pinctrl information to ethernet node.
sam9-l9260 is a low cost board designed by Olimex.
More information is available at:
https://www.olimex.com/Products/ARM/Atmel/SAM9-L9260/
Acked-by: Rob Herring <robh@kernel.org>
