Use the new EBI/NAND bindings to declare NAND chips and remove old NAND
nodes along the way.
Note that we keep using old bindings in at91rm9200.dtsi because this
SoC is not supported by the EBI driver.
Signed-off-by: Boris Brezillon <boris.brezillon@free-electrons.com>
Tested-by: Peter Rosin <peda@axentia.se>
Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
lcd_bus has never been mainlined and is replaced by the atmel_hlcdc driver.
Remove stale nodes.
On SAMA5D4EK board, the Ethernet doesn't work after resuming from the suspend
state.
Signed-off-by: Wenyou Yang <wenyou.yang@atmel.com>
[nicolas.ferre@atmel.com: adapt to newer kernel]
Fixes: 38153a017896 ("ARM: at91/dt: sama5d4: add dts for sama5d4 xplained board")
Cc: <stable@vger.kernel.org> # 4.1+
Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com>
Passing earlyprintk in the bootargs may crash the board as it depends on
having a sane DEBUG_UART_PHYS configured which is not always the case.
Also remove ignore_loglevel
The clocks group properties and the clock@0 node are useless, remove them
to avoid copy pasting in future device trees.
Though the keyboard driver for GPIO buttons(gpio-keys) will continue to
check for/support the legacy "gpio-key,wakeup" boolean property to
enable gpio buttons as wakeup source, "wakeup-source" is the new
standard binding.
This patch replaces the legacy "gpio-key,wakeup" with the unified
"wakeup-source" property in order to avoid any futher copy-paste
duplication.
Cc: Alexandre Belloni <alexandre.belloni@free-electrons.com>
Cc: Jean-Christophe Plagniol-Villard <plagnioj@jcrosoft.com>
Signed-off-by: Sudeep Holla <sudeep.holla@arm.com>
As the EK board comes with a PDA 7" screen, add the touch buttons
and touchscreen for it.
Signed-off-by: Patrice Vilchez <patrice.vilchez@atmel.com>
[nicolas.ferre@atmel.com: add commit message]
The ADC pinctrl is board specific, move it to the board device trees.
Mci0 uses slot 0 not 1.
Signed-off-by: Ludovic Desroches <ludovic.desroches@atmel.com>
Fixes: 7a4752677c44 ("ARM: at91: dt: add device tree file for SAMA5D4ek board")
Cc: stable@vger.kernel.org
Use stdout-path to specify the console and remove the console argument from
the kernel command line.
Enable audio support for sama5d4ek board.
Signed-off-by: Bo Shen <voice.shen@atmel.com>
Add wm8904 codec node and enable it.
Enable SSC0 node, which will be used for audio.
Add the leds DT node in the dts file.
In the leds, d10 is set as heartbeat led.
Signed-off-by: Josh Wu <josh.wu@atmel.com>
Gpio-keys nodes are not using the "reg" property in their sub nodes.
So, there is no need to define #address-cells and #size-cells properties
in gpio-keys nodes: we remove them in these new boards.
During the submission of these new sama5d4 files, the GPL notice mentioned the
device tree as a library, which is not really accurate.
Fix all these library mentions to reflect the fact that it's actually just a
file.
Reported-by: Maxime Ripard <maxime.ripard@free-electrons.com>
Add reference SAMA5D4-EK platform DT file.
