path: root/arch/arm/boot/dts/at91-wb45n.dts
2019-01-08ARM: dts: at91: replace gpio-key,wakeup with wakeup-source propertySudeep Holla
Most of the legacy "gpio-key,wakeup" property are already replaced with "wakeup-source". However few occurrences of old property has popped up again, probably from the remnants in downstream trees. Almost all of those were remove couple of years back. Replace the legacy properties with the unified "wakeup-source" property introduced in the commit 700a38b27eef ("Input: gpio_keys - switch to using generic device properties") Cc: Alexandre Belloni <alexandre.belloni@bootlin.com> Cc: Peter Rosin <peda@axentia.se> Cc: Nicolas Ferre <nicolas.ferre@microchip.com> Signed-off-by: Sudeep Holla <sudeep.holla@arm.com> Acked-by: Peter Rosin <peda@axentia.se> Signed-off-by: Alexandre Belloni <alexandre.belloni@bootlin.com>
2018-07-20ARM: dts: add support for Laird WB45N cpu module and DVKBen Whitten
This adds support for Lairds combo CPU module, featuring on board Atheros wifi, CSR Bluetooth radio and, Atmel CPU. https://www.lairdtech.com/products/wb45nbt Signed-off-by: Ben Whitten <ben.whitten@lairdtech.com> Signed-off-by: Alexandre Belloni <alexandre.belloni@bootlin.com>
