path: root/arch/arm/boot/dts/at91sam9260.dtsi
2020-02-14ARM: dts: at91: Reenable UART TX pull-upsIngo van Lil
commit 9d39d86cd4af2b17b970d63307daad71f563d207 upstream. Pull-ups for SAM9 UART/USART TX lines were disabled in a previous commit. However, several chips in the SAM9 family require pull-ups to prevent the TX lines from falling (and causing an endless break condition) when the transceiver is disabled. From the SAM9G20 datasheet, 32.5.1: "To prevent the TXD line from falling when the USART is disabled, the use of an internal pull up is mandatory.". This commit reenables the pull-ups for all chips having that sentence in their datasheets. Fixes: 5e04822f7db5 ("ARM: dts: at91: fixes uart pinctrl, set pullup on rx, clear pullup on tx") Signed-off-by: Ingo van Lil <inguin@gmx.de> Cc: Peter Rosin <peda@axentia.se> Link: https://lore.kernel.org/r/20191203142147.875227-1-inguin@gmx.de Signed-off-by: Alexandre Belloni <alexandre.belloni@bootlin.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2019-05-21treewide: Replace GPLv2 boilerplate/reference with SPDX - rule 4Thomas Gleixner
Based on 1 normalized pattern(s): licensed under gplv2 or later extracted by the scancode license scanner the SPDX license identifier GPL-2.0-or-later has been chosen to replace the boilerplate/reference in 118 file(s). Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Reviewed-by: Jilayne Lovejoy <opensource@jilayne.com> Reviewed-by: Steve Winslow <swinslow@gmail.com> Reviewed-by: Allison Randal <allison@lohutok.net> Reviewed-by: Kate Stewart <kstewart@linuxfoundation.org> Cc: linux-spdx@vger.kernel.org Link: https://lkml.kernel.org/r/20190519154040.961286471@linutronix.de Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2019-01-30ARM: dts: Kill off skeleton{64}.dtsiRob Herring
Remove the usage of skeleton.dtsi in the remaining dts files. It was deprecated since commit 9c0da3cc61f1 ("ARM: dts: explicitly mark skeleton.dtsi as deprecated"). This will make adding a unit-address to memory nodes easier. The main tricky part to removing skeleton.dtsi is we could end up with no /memory node at all when a bootloader depends on one being present. I hacked up dtc to check for this condition. Acked-by: Linus Walleij <linus.walleij@linaro.org> Reviewed-by: Florian Fainelli <f.fainelli@gmail.com> Reviewed-by: Matthias Brugger <matthias.bgg@gmail.com> Acked-by: Viresh Kumar <viresh.kumar@linaro.org> Acked-by: Alexandre Belloni <alexandre.belloni@bootlin.com> Acked-by: Neil Armstrong <narmstrong@baylibre.com> Acked-by: Antoine Tenart <antoine.tenart@bootlin.com> Acked-by: Alexandre TORGUE <alexandre.torgue@st.com> Acked-by: Robert Jarzmik <robert.jarzmik@free.fr> Acked-by: Vladimir Zapolskiy <vz@mleia.com> Tested-by: Kevin Hilman <khilman@baylibre.com> Reviewed-by: Kevin Hilman <khilman@baylibre.com> Tested-by: Martin Blumenstingl <martin.blumenstingl@googlemail.com> Reviewed-by: Martin Blumenstingl <martin.blumenstingl@googlemail.com> Signed-off-by: Rob Herring <robh@kernel.org> Reviewed-by: Gregory CLEMENT <gregory.clement@bootlin.com> Tested-by: Gregory CLEMENT <gregory.clement@bootlin.com> Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2018-11-21ARM: dts: at91: at91sam9260: switch to new clock bindingsAlexandre Belloni
Switch at91sam9260 and at91sam9g20 boards to the new PMC clock bindings. Signed-off-by: Alexandre Belloni <alexandre.belloni@bootlin.com>
2018-03-21ARM: dts: at91sam9260: pullup rx on usart0Peter Rosin
For consistency with all other serial pins, add this pullup. It also prevents the signal from floating and so consuming a useless extra amount of power in crowbarred state if nothing is connected to RX. Signed-off-by: Peter Rosin <peda@axentia.se> Signed-off-by: Alexandre Belloni <alexandre.belloni@bootlin.com>
2018-03-21ARM: dts: at91: fixes uart pinctrl, set pullup on rx, clear pullup on txPeter Rosin
Remove pullup on uart TX signals, they are push-pull outputs thus pullups are pointless. Add pullup on uart RX signals, they prevent the RX signals to be left floating and so consuming a useless extra amount of power in crowbarred state if nothing is connected to RX. Signed-off-by: Peter Rosin <peda@axentia.se> Signed-off-by: Alexandre Belloni <alexandre.belloni@bootlin.com>
2017-12-31ARM: dts: at91: at91sam9260: TC blocks are also simple-mfd and syscon devicesAlexandre Belloni
Add simple-mfd and syscon to the TC blocks to allow to register one of the channels as clocksource properly at boot time and free up the remaining channels for other use. Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com> Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
2017-10-20arm: dts: fix unit-address leading 0sRob Herring
Fix dtc warnings for 'simple_bus_reg' due to leading 0s. Converted using the following command: perl -p -i -e 's/\@0+([0-9a-f])/\@$1/g' `find arch/arm/boot/dts -type -f -name '*.dts*' Dropped changes to ARM, Ltd. boards LED nodes and manually fixed up some occurrences of uppercase hex. Signed-off-by: Rob Herring <robh@kernel.org> Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2017-05-31ARM: dts: at91: Switch to the new NAND bindingsBoris Brezillon
Use the new EBI/NAND bindings to declare NAND chips and remove old NAND nodes along the way. Note that we keep using old bindings in at91rm9200.dtsi because this SoC is not supported by the EBI driver. Signed-off-by: Boris Brezillon <boris.brezillon@free-electrons.com> Tested-by: Peter Rosin <peda@axentia.se> Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
2017-05-31ARM: dts: at91: Declare EBI/NAND controllersBoris Brezillon
Declare new nodes for the EBI and NAND controllers embedded in various at91/sama5 SoCs. Signed-off-by: Boris Brezillon <boris.brezillon@free-electrons.com> Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
2016-10-20ARM: dts: at91: fixes dbgu pinctrl, set pullup on rx, clear pullup on txSylvain Rochet
Remove pullup on dbgu DTXD signal, it is a push-pull output thus the pullup is pointless. Add pullup on dbgu DRXD signal, it prevents the DRXD signal to be left floating and so consuming a useless extra amount of power in crowbarred state if nothing is externally connected to dbgu. Signed-off-by: Sylvain Rochet <sylvain.rochet@finsecur.com> Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
2016-07-15ARM: dts: at91: fix i2c-gpio node nameAlexandre Belloni
i2c-gpio doesn't need a reg property. Change the node names to i2c-gpio-x as used in other dts to remove the unit-address. Solves: Warning (unit_address_vs_reg): Node /i2c@0 has a unit name, but no reg property Warning (unit_address_vs_reg): Node /i2c@1 has a unit name, but no reg property Warning (unit_address_vs_reg): Node /i2c@2 has a unit name, but no reg property Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
2016-07-15ARM: dts: at91: Fix ADC trigger nodesAlexandre Belloni
The triggers don't need a reg property, remove it when prenset. Also remove the unit-address from their name. This solves: Warning (unit_address_vs_reg): Node /ahb/apb/adc@fc034000/trigger@0 has a unit name, but no reg property Warning (unit_address_vs_reg): Node /ahb/apb/adc@fc034000/trigger@1 has a unit name, but no reg property Warning (unit_address_vs_reg): Node /ahb/apb/adc@fc034000/trigger@2 has a unit name, but no reg property Warning (unit_address_vs_reg): Node /ahb/apb/adc@fc034000/trigger@3 has a unit name, but no reg property Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
2016-06-07ARM: dts: at91: at91sam9260: Remove leading zeros in OHCI node.Raashid Muhammed
Remove leading zeros in OHCI node for at91sam9260 based boards. Signed-off-by: Raashid Muhammed <raashidmuhammed@zilogic.com> Reviewed-by: Vijay Kumar B. <vijaykumar@bravegnu.org> Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
2015-10-19ARM: at91/dt: use syscon for PMCAlexandre Belloni
The PMC is not only used to drive the clocks but also has some registers related to other functions. One of those is for example the USB gadget bias. Using a syscon allows to properly separate those functions. Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
2015-08-07ARM: at91/dt: at91sam9260: use slow clock where necessaryAlexandre Belloni
The watchdog, the reset controller, the real-time timer, the shutdown controller, the timer counters need the slow clock, add it where necessary. Acked-by: Boris Brezillon <boris.brezillon@free-electrons.com> Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
2015-05-22ARM: at91/dt: remove useless usb clockBoris Brezillon
The ohci driver now calls clk_set_rate on the uhpck clock (which forwards set_rate requests to its parent: the usb clock). Remove useless references to usb clocks from ohci definitions. Signed-off-by: Boris Brezillon <boris.brezillon@free-electrons.com> Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com>
2015-04-22Merge tag 'armsoc-cleanup' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC cleanups from Olof Johansson: "We've got a fairly large cleanup branch this time. The bulk of this is removal of non-DT platforms of several flavors: - Atmel at91 platforms go full-DT, with removal of remaining board-file based support - OMAP removes legacy board files for three more platforms - removal of non-DT mach-msm, newer Qualcomm platforms now live in mach-qcom - Freescale i.MX25 also removes non-DT platform support" Most of the rest of the changes here are fallout from the above, i.e. for example removal of drivers that now lack platforms, etc. * tag 'armsoc-cleanup' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (58 commits) mmc: Remove msm_sdcc driver gpio: Remove gpio-msm-v1 driver ARM: Remove mach-msm and associated ARM architecture code ARM: shmobile: cpuidle: Remove the pointless default driver ARM: davinci: dm646x: Add interrupt resource for McASPs ARM: davinci: irqs: Correct McASP1 TX interrupt definition for DM646x ARM: davinci: dm646x: Clean up the McASP DMA resources ARM: davinci: devices-da8xx: Add support for McASP2 on da830 ARM: davinci: devices-da8xx: Clean up and correct the McASP device creation ARM: davinci: devices-da8xx: Add interrupt resource to McASP structs ARM: davinci: devices-da8xx: Add resource name for the McASP DMA request ARM: OMAP2+: Remove legacy support for omap3 TouchBook ARM: OMAP3: Remove legacy support for devkit8000 ARM: OMAP3: Remove legacy support for EMA-Tech Stalker board ARM: shmobile: Consolidate the pm code for R-Car Gen2 ARM: shmobile: r8a7791: Correct SYSCIER value ARM: shmobile: r8a7790: Correct SYSCIER value ARM: at91: remove old setup ARM: at91: sama5d4: remove useless map_io ARM: at91: sama5 use SoC detection infrastructure ...
2015-03-20Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netDavid S. Miller
Conflicts: drivers/net/ethernet/emulex/benet/be_main.c net/core/sysctl_net_core.c net/ipv4/inet_diag.c The be_main.c conflict resolution was really tricky. The conflict hunks generated by GIT were very unhelpful, to say the least. It split functions in half and moved them around, when the real actual conflict only existed solely inside of one function, that being be_map_pci_bars(). So instead, to resolve this, I checked out be_main.c from the top of net-next, then I applied the be_main.c changes from 'net' since the last time I merged. And this worked beautifully. The inet_diag.c and sysctl_net_core.c conflicts were simple overlapping changes, and were easily to resolve. Signed-off-by: David S. Miller <davem@davemloft.net>
2015-03-13ARM: at91/dt: introduce atmel,<chip>-dbguAlexandre Belloni
The DBGU is not a simple UART and we need to be able to distinguish it from the other UARTs, in particular to get its address and check the chip id. Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com> Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com>
2015-03-11ARM: at91/dt: fix at91 udc compatible stringsBoris Brezillon
The at91rm9200, at91sam9260, at91sam9261 and at91sam9263 SoCs have slightly different UDC IPs. Those differences were previously handled with cpu_is_at91xx macro which are about to be dropped for multi-platform support, thus we need to change compatible strings. Signed-off-by: Boris Brezillon <boris.brezillon@free-electrons.com> Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com>
2015-03-07ARM: at91/dt: fix macb compatible stringsBoris BREZILLON
Some at91 SoCs embed a 10/100 Mbit Ethernet IP, that is based on the at91sam9260 SoC. Fix at91 DTs accordingly. Signed-off-by: Boris Brezillon <boris.brezillon@free-electrons.com> Reviewed-by: Alexandre Belloni <alexandre.belloni@free-electrons.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-03-04ARM: at91/dt: keep watchdog running in idle modeMichel Marti
Since turning on idle-halt in commit fe46aa679f12 (ARM: at91/dt: add sam9 watchdog default options to SoCs), SoCs compatible with at91sam9260-wdt no longer reboot if the watchdog times out while the CPU is in idle state. Removing the 'idle-halt' flag that was set by default fixes this. Signed-off-by: Michel Marti <mma@objectxp.com> Acked-by: Boris Brezillon <boris.brezillon@free-electrons.com> Acked-by: Sylvain Rochet <sylvain.rochet@finsecur.com> [nicolas.ferre@atmel.com: rework the commit message] Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com>
2015-03-04ARM: at91/dt: at91sam9260: fix usart pinctrlJonas Andersson
Corrected pins used by usart3. Signed-off-by: Jonas Andersson <jonas@microbit.se> Acked-by: Alexandre Belloni <alexandre.belloni@free-electrons.com> Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com>
2015-01-15ARM: at91/dt: add SRAM nodesAlexandre Belloni
Add nodes for the SRAM available on atmel SoCs For the at91sam9260 and the at91sam9g20, address mirroring is used to create a single contiguous SRAM range instead of declaring two separate banks. Also remove leftover TODOs in the sam9g45 file Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com> Acked-by: Boris Brezillon <boris.brezillon@free-electrons.com> [nicolas.ferre@atmel.com: correct at91sam9rl sram size => 0x10000] Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com>
2014-11-19ARM: at91/dt: add GPBR nodesBoris Brezillon
Add GPBR (General Purpose Block Backup Registers) nodes. Signed-off-by: Boris Brezillon <boris.brezillon@free-electrons.com> Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com>
2014-11-19ARM: at91/dt: add RTT nodes to at91 dtsisBoris Brezillon
at91sam926x, at91sam9g45 and at91sam9rl SoCs all have at least one RTT block. Signed-off-by: Boris Brezillon <boris.brezillon@free-electrons.com> Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com>
2014-07-09ARM: at91/dt: sam9260: define clocksAlexandre Belloni
Define the at91sam9260 clocks in the SoC dtsi file. Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com> Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com>
2014-05-13ARM: at91/dt: sam9260: correct external trigger valueAlexandre Belloni
The external trigger value is 0b1101 which is 13 but 0xd. Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com> Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com>
2014-03-12ARM: at91/dt: at91sam9260: remove useless adc propertiesAlexandre Belloni
Remove the properties that are not used anymore by the at91_adc driver. Also, add #address-cells, #size-cells and a reg for each trigger to comply to the ePAPR. Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com> Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com>
2014-01-28ARM: at91/dt: add sam9 watchdog default options to SoCsBoris BREZILLON
Set default watchdog options in every SoC compatible with the sam9 watchdog. Signed-off-by: Boris BREZILLON <b.brezillon@overkiz.com> Acked-by: Guenter Roeck <linux@roeck-us.net> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2013-08-21ARM: at91: at91sam9260: add missing pinctrl-names on mmcJean-Christophe PLAGNIOL-VILLARD
pinctrl-names was missing causing mmc pinctrl to never be requested. Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Acked-by: Ludovic Desroches <ludovic.desroches@atmel.com> [nicolas.ferre@atmel.com: added a commit message taken from Ludovic] Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com>
2013-06-07Merge branch 'dts-cpus-updates' of git://linux-arm.org/linux-2.6-lp into next/dtOlof Johansson
From Lorenzo Pieralisi, this is a series of patches that cleans up the CPU nodes in most of the SoC dtsi files to conform to the standard bindings. * 'dts-cpus-updates' of git://linux-arm.org/linux-2.6-lp: ARM: dts: sunxi: cpus/cpu nodes dts updates ARM: dts: spear: cpus/cpu nodes dts updates ARM: dts: sh7372: cpus/cpu nodes dts updates ARM: dts: r8a7740: cpus/cpu nodes dts updates ARM: dts: pxa2xx: cpus/cpu nodes dts updates ARM: dts: prima2: cpus/cpu node dts updates ARM: dts: picoxcell: cpus/cpu nodes dts updates ARM: dts: omap: cpus/cpu nodes dts updates ARM: dts: lpc32xx: cpus/cpu nodes dts updates ARM: dts: imx: cpus/cpu nodes dts updates ARM: dts: exynos5440: cpus/cpu nodes dts updates ARM: dts: at91: cpus/cpu node dts updates ARM: dts: armada-370-xp: cpus/cpu node dts updates ARM: dts: am33xx: cpus/cpu nodes dts updates Signed-off-by: Olof Johansson <olof@lixom.net>
2013-06-01Merge tag 'at91-dt' of git://github.com/at91linux/linux-at91 into next/dtOlof Johansson
From Nicolas Ferre: Big DT-centric update for AT91: - Calao boards update, removal of one board C file and associated defconfig, Kconfig Makefile lines - several Acme boards updates - addition of watchdog, uart and pinctrl descriptions for several products - modification of RTC compatible string for 9x5 family * tag 'at91-dt' of git://github.com/at91linux/linux-at91: (21 commits) ARM: at91/dt: add pinctrl definition for at91 tc blocks ARM: at91/dts: add the watchdog nodes for at91 boards ARM: at91/dtsi: add the watchdog nodes for at91 SoC ARM: at91: drop non DT: Calao USB-A96x ARM: at91: dt: add Calao USB-A9G20 low power version ARM: at91: dt: usb-a9263: add dataflash support ARM: at91: dt: usb-a9263: update shutdown controller ARM: at91: dt: usb-a9260: update shutdown controller ARM: at91: dt: sam9260: add i2c gpio pinctrl ARM: at91: switch Fox G20 board .dts to pre-processor defines ARM: at91: add Acme Systems Fox G20 board ARM: at91/at91-ariag25.dts: UART0/1 nodes are disabled ARM: at91/at91sam9x5.dtsi: add UART0/1 nodes ARM: at91/at91-ariag25.dts: add RTC node ARM: at91: at91sam9x5 RTC is not compatible with at91rm9200 one ARM: at91: udpate defconfigs ARM: at91: dt: switch to standard IRQ flag defines ARM: at91: dt: switch to pinctrl to pre-processor ARM: at91: dt: add pinctrl pre-processor define ARM: at91: dt: switch to standard GPIO flag defines. ... Signed-off-by: Olof Johansson <olof@lixom.net>
2013-05-31ARM: at91/dt: add pinctrl definition for at91 tc blocksBoris BREZILLON
This patch adds pinctrl configurations for at91 Timer Counter blocks. These pin definitions can be referenced by "atmel,tcb-pwm" devices to setup pins as PWM output for instance. Signed-off-by: Boris BREZILLON <b.brezillon@overkiz.com> [nicolas.ferre@atmel.com: switch to pinctrl pre-processor macros] Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com>
2013-05-31ARM: at91: dt: sam9260: add i2c gpio pinctrlJean-Christophe PLAGNIOL-VILLARD
Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com>
2013-05-24ARM: at91/dt: fix macb pinctrl_macb_rmii_mii_alt definitionBoris BREZILLON
The PA24 pin is wrongly assigned to peripheral B. In the current config there is 2 ETX3 pins (PA11 and PA24) and no ETXER pin (PA22). Signed-off-by: Boris BREZILLON <b.brezillon@overkiz.com> Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com> Cc: stable <stable@vger.kernel.org> # 3.8+
2013-05-23ARM: dts: at91: cpus/cpu node dts updatesLorenzo Pieralisi
This patch updates the in-kernel dts files according to the latest cpus and cpu bindings updates for ARM. Signed-off-by: Lorenzo Pieralisi <lorenzo.pieralisi@arm.com> Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com>
2013-05-17ARM: at91: dt: switch to standard IRQ flag definesJean-Christophe PLAGNIOL-VILLARD
2013-05-17ARM: at91: dt: switch to pinctrl to pre-processorJean-Christophe PLAGNIOL-VILLARD
Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Acked-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com>
2013-05-17ARM: at91: dt: switch to standard GPIO flag defines.Jean-Christophe PLAGNIOL-VILLARD
2013-05-17ARM: at91: dt: use #include for all device treesJean-Christophe PLAGNIOL-VILLARD
to prepare the switch to the macro. Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com>
2013-05-02Merge tag 'dt-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC device-tree updates from Olof Johansson: "Part 1 of device-tree updates for 3.10. The bulk of the churn in this branch is due to i.MX moving from C-defined pin control over to device tree, which is a one-time conversion that will allow greater flexibility down the road. Besides that, there's PCI-e bindings for Marvell mvebu platforms and a handful of cleanups to tegra due to the new include file functionality of the device tree compiler" * tag 'dt-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (113 commits) arm: mvebu: PCIe Device Tree informations for Armada XP GP arm: mvebu: PCIe Device Tree informations for Armada 370 DB arm: mvebu: PCIe Device Tree informations for Armada 370 Mirabox arm: mvebu: PCIe Device Tree informations for Armada XP DB arm: mvebu: PCIe Device Tree informations for OpenBlocks AX3-4 arm: mvebu: add PCIe Device Tree informations for Armada XP arm: mvebu: add PCIe Device Tree informations for Armada 370 ARM: sunxi: unify osc24M_fixed and osc24M arm: vt8500: Add SDHC support to WM8505 DT ARM: dts: Add a 64 bits version of the skeleton device tree ARM: mvebu: Add Device Bus and CFI flash memory support to defconfig ARM: mvebu: Add support for NOR flash device on Openblocks AX3 board ARM: mvebu: Add support for NOR flash device on Armada XP-GP board ARM: mvebu: Add Device Bus support for Armada 370/XP SoC ARM: dts: imx6dl-wandboard: Add USB Host support ARM: dts: imx51 cpu node ARM: dts: Add missing imx27-phytec-phycore dtb target ARM: dts: Add NFC support for i.MX27 Phytec PCM038 module ARM: i.MX51: Add PATA support ARM: dts: Add initial support for Wandboard Dual-Lite ...
2013-04-24ARM: dts: add pinctrl property for spi node for atmel SoCWenyou Yang
Signed-off-by: Wenyou Yang <wenyou.yang@atmel.com> Tested-by: Richard Genoud <richard.genoud@gmail.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2013-04-24ARM: dts: add spi nodes for atmel SoCRichard Genoud
Signed-off-by: Richard Genoud <richard.genoud@gmail.com> [wenyou.yang@atmel.com: add spi nodes for sam9260, sam9263, sam9g45 and sam9n12] [wenyou.yang@atmel.com: remove spi property "cs-gpios" to the board dts files] [wenyou.yang@atmel.com: submit the patch] Signed-off-by: Wenyou Yang <wenyou.yang@atmel.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2013-04-04ARM: at91/at91sam9260.dtsi: fix u(s)art pinctrl encodingDouglas Gilbert
Signed-off-by: Douglas Gilbert <dgilbert@interlog.com> [nicolas.ferre@atmel.com: fix rts/cts for usart3] Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com> Cc: stable <stable@vger.kernel.org> [3.8+]
2013-04-04ARM: at91: dts: add adc resolution stuffLudovic Desroches
Add the ADC low and high resolution configuration and which one to use. Signed-off-by: Ludovic Desroches <ludovic.desroches@atmel.com> Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com>
2013-01-12ARM: at91/dts: add pinctrl support for SSC peripheralBo Shen
Add pinctrl support for SSC on AT91 dtsi files. Signed-off-by: Bo Shen <voice.shen@atmel.com> [nicolas.ferre@atmel.com: split dtsi and driver changes] Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com> Reluctantly-acked-by: Olof Johansson <olof@lixom.net> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2012-12-13Merge tag 'sound-3.8' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound Pull sound updates from Takashi Iwai: "This update contains a fairly wide range of changes all over in sound subdirectory, mainly because of UAPI header moves by David and __dev* annotation removals by Bill. Other highlights are: - Introduced the support for wallclock timestamps in ALSA PCM core - Add the poll loop implementation for HD-audio jack detection - Yet more VGA-switcheroo fixes for HD-audio - New VIA HD-audio codec support - More fixes on resource management in USB audio and MIDI drivers - More quirks for USB-audio ASUS Xonar U3, Reloop Play, Focusrite, Roland VG-99, etc - Add support for FastTrack C400 usb-audio - Clean ups in many drivers regarding firmware loading - Add PSC724 Ultiimate Edge support to ice1712 - A few hdspm driver updates - New Stanton SCS.1d/1m FireWire driver - Standardisation of the logging in ASoC codes - DT and dmaengine support for ASoC Atmel - Support for Wolfson ADSP cores - New drivers for Freescale/iVeia P1022 and Maxim MAX98090 - Lots of other ASoC driver fixes and developments" Fix up trivial conflicts. And go out on a limb and assume the dts file 'status' field of one of the conflicting things was supposed to be "disabled", not "disable" like in pretty much all other cases. * tag 'sound-3.8' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound: (341 commits) ALSA: hda - Move runtime PM check to runtime_idle callback ALSA: hda - Add stereo-dmic fixup for Acer Aspire One 522 ALSA: hda - Avoid doubly suspend after vga switcheroo ALSA: usb-audio: Enable S/PDIF on the ASUS Xonar U3 ALSA: hda - Check validity of CORB/RIRB WP reads ALSA: hda - use usleep_range in link reset and change timeout check ALSA: HDA: VIA: Add support for codec VT1808. ALSA: HDA: VIA Add support for codec VT1705CF. ASoC: codecs: remove __dev* attributes ASoC: utils: remove __dev* attributes ASoC: ux500: remove __dev* attributes ASoC: txx9: remove __dev* attributes ASoC: tegra: remove __dev* attributes ASoC: spear: remove __dev* attributes ASoC: sh: remove __dev* attributes ASoC: s6000: remove __dev* attributes ASoC: OMAP: remove __dev* attributes ASoC: nuc900: remove __dev* attributes ASoC: mxs: remove __dev* attributes ASoC: kirkwood: remove __dev* attributes ...
2012-12-13Merge tag 'dt' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-socLinus Torvalds
Pull ARM SoC device tree conversions and enablement from Olof Johansson: "Continued device tree conversion and enablement across a number of platforms; Kirkwood, tegra, i.MX, Exynos, zynq and a couple of other smaller series as well. ux500 has seen continued conversion for platforms. Several platforms have seen pinctrl-via-devicetree conversions for simpler multiplatform. Tegra is adding data for new devices/drivers, and Exynos has a bunch of new bindings and devices added as well. So, pretty much the same progression in the right direction as the last few releases." Fix up conflicts as per Olof. * tag 'dt' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (185 commits) ARM: ux500: Rename dbx500 cpufreq code to be more generic ARM: dts: add missing ux500 device trees ARM: ux500: Stop registering the PCM driver from platform code ARM: ux500: Move board specific GPIO info out to subordinate DTS files ARM: ux500: Disable the MMCI gpio-regulator by default ARM: Kirkwood: remove kirkwood_ehci_init() from new boards ARM: Kirkwood: Add support LED of OpenBlocks A6 ARM: Kirkwood: Convert to EHCI via DT for OpenBlocks A6 ARM: kirkwood: Add NAND partiton map for OpenBlocks A6 ARM: kirkwood: Add support second I2C bus and RTC on OpenBlocks A6 ARM: kirkwood: Add support DT of second I2C bus ARM: kirkwood: Convert mplcec4 board to pinctrl ARM: Kirkwood: Convert km_kirkwood to pinctrl ARM: Kirkwood: support 98DX412x kirkwoods with pinctrl ARM: Kirkwood: Convert IX2-200 to pinctrl. ARM: Kirkwood: Convert lsxl boards to pinctrl. ARM: Kirkwood: Convert ib62x0 to pinctrl. ARM: Kirkwood: Convert GoFlex Net to pinctrl. ARM: Kirkwood: Convert dreamplug to pinctrl. ARM: Kirkwood: Convert dockstar to pinctrl. ...
