path: root/arch/arm/boot/dts/at91sam9263ek.dts
2014-07-09ARM: at91/dt: sam9263ek: define crystals frequenciesAlexandre Belloni
Define at91sam9263ek main and slow crystals frequencies. Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com> Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com>
2013-12-09ARM: at91: sam9263ek: add dt lcd supportJean-Christophe PLAGNIOL-VILLARD
Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com>
2013-05-31ARM: at91/dts: add the watchdog nodes for at91 boardsWenyou Yang
boards include: at91sam9263ek, at91sam9g20ek, at91sam9m10g45ek, at91sam9n12ek, at91sam9x5ek Signed-off-by: Wenyou Yang <wenyou.yang@atmel.com> Tested-by: Richard Genoud <richard.genoud@gmail.com> Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com>
2013-05-17ARM: at91: dt: switch to pinctrl to pre-processorJean-Christophe PLAGNIOL-VILLARD
Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Acked-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com>
2013-05-17ARM: at91: dt: switch to standard GPIO flag defines.Jean-Christophe PLAGNIOL-VILLARD
2013-05-17ARM: at91: dt: use #include for all device treesJean-Christophe PLAGNIOL-VILLARD
to prepare the switch to the macro. Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com>
2013-05-02Merge tag 'dt-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC device-tree updates from Olof Johansson: "Part 1 of device-tree updates for 3.10. The bulk of the churn in this branch is due to i.MX moving from C-defined pin control over to device tree, which is a one-time conversion that will allow greater flexibility down the road. Besides that, there's PCI-e bindings for Marvell mvebu platforms and a handful of cleanups to tegra due to the new include file functionality of the device tree compiler" * tag 'dt-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (113 commits) arm: mvebu: PCIe Device Tree informations for Armada XP GP arm: mvebu: PCIe Device Tree informations for Armada 370 DB arm: mvebu: PCIe Device Tree informations for Armada 370 Mirabox arm: mvebu: PCIe Device Tree informations for Armada XP DB arm: mvebu: PCIe Device Tree informations for OpenBlocks AX3-4 arm: mvebu: add PCIe Device Tree informations for Armada XP arm: mvebu: add PCIe Device Tree informations for Armada 370 ARM: sunxi: unify osc24M_fixed and osc24M arm: vt8500: Add SDHC support to WM8505 DT ARM: dts: Add a 64 bits version of the skeleton device tree ARM: mvebu: Add Device Bus and CFI flash memory support to defconfig ARM: mvebu: Add support for NOR flash device on Openblocks AX3 board ARM: mvebu: Add support for NOR flash device on Armada XP-GP board ARM: mvebu: Add Device Bus support for Armada 370/XP SoC ARM: dts: imx6dl-wandboard: Add USB Host support ARM: dts: imx51 cpu node ARM: dts: Add missing imx27-phytec-phycore dtb target ARM: dts: Add NFC support for i.MX27 Phytec PCM038 module ARM: i.MX51: Add PATA support ARM: dts: Add initial support for Wandboard Dual-Lite ...
2013-04-24ARM: dts: add spi nodes for the atmel boardsRichard Genoud
Signed-off-by: Richard Genoud <richard.genoud@gmail.com> [wenyou.yang@atmel.com: added spi nodes for the sam9263ek, sam9g20ek, sam9m10g45ek and sam9n12ek boards] [wenyou.yang@atmel.com: submit the patch] Signed-off-by: Wenyou Yang <wenyou.yang@atmel.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2013-03-21ARM: at91/dt: gpio-keys: remove address-cells and size-cells propertiesNicolas Ferre
Gpio-keys nodes are not using the "reg" property in their sub nodes. So, there is no need to define #address-cells and #size-cells properties in gpio-keys nodes: we remove them. Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com>
2012-11-20ARM: at91: dt: add mmc pinctrl for Atmel reference boardsJean-Christophe PLAGNIOL-VILLARD
2012-11-20ARM: at91/dts: add nodes for atmel hsmci controllers for atmel boardsLudovic Desroches
Add mci controller nodes to atmel boards. Signed-off-by: Ludovic Desroches <ludovic.desroches@atmel.com> Acked-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2012-11-19ARM: at91: dt: at91sam9260: split rts and cts pinctrl notJean-Christophe PLAGNIOL-VILLARD
as we just use the rts and not the rts & cts for rs485 Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2012-11-19ARM: at91: fix usart/uart namimg in pinctrlJean-Christophe PLAGNIOL-VILLARD
USART are the full pin uart DBGU the debug Unit UART the two pin uart Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2012-10-13arm: at91: dt: sam9263ek: use rts/cts pinctrl group for uart0Jean-Christophe PLAGNIOL-VILLARD
Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com> Acked-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2012-04-20ARM: at91: add at91sam9263ek DT supportJean-Christophe PLAGNIOL-VILLARD
Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com>
