Use the new EBI/NAND bindings to declare NAND chips and remove old NAND
nodes along the way.
Note that we keep using old bindings in at91rm9200.dtsi because this
SoC is not supported by the EBI driver.
Signed-off-by: Boris Brezillon <boris.brezillon@free-electrons.com>
Tested-by: Peter Rosin <peda@axentia.se>
Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
i2c-gpio doesn't need a reg property. Change the node names to i2c-gpio-x
as used in other dts to remove the unit-address.
Solves:
Warning (unit_address_vs_reg): Node /i2c@0 has a unit name, but no reg property
Warning (unit_address_vs_reg): Node /i2c@1 has a unit name, but no reg property
Warning (unit_address_vs_reg): Node /i2c@2 has a unit name, but no reg property
Remove leading zeros in OHCI node for at91sam9260 based boards.
Signed-off-by: Raashid Muhammed <raashidmuhammed@zilogic.com>
Reviewed-by: Vijay Kumar B. <vijaykumar@bravegnu.org>
The clocks group properties and the clock@0 node are useless, remove them
to avoid copy pasting in future device trees.
Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com>
Though the keyboard driver for GPIO buttons(gpio-keys) will continue to
check for/support the legacy "gpio-key,wakeup" boolean property to
enable gpio buttons as wakeup source, "wakeup-source" is the new
standard binding.
This patch replaces the legacy "gpio-key,wakeup" with the unified
"wakeup-source" property in order to avoid any futher copy-paste
duplication.
Cc: Alexandre Belloni <alexandre.belloni@free-electrons.com>
Cc: Jean-Christophe Plagniol-Villard <plagnioj@jcrosoft.com>
Signed-off-by: Sudeep Holla <sudeep.holla@arm.com>
Use stdout-path to specify the console and remove the console argument from
the kernel command line.
Enable the RTT and GPBR devices and specify the general purpose register
used to store the current time.
Enable wakeup on RTT event on the shutdown controller device.
Define at91sam9g20ek main and slow crystals frequencies.
Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com>
These MMC and SPI buses can't be configured at the same time because they
share the same traces on the EK board.
Reported-by: Mark Brown <broonie@kernel.org>
boards include:
at91sam9263ek, at91sam9g20ek, at91sam9m10g45ek, at91sam9n12ek, at91sam9x5ek
Signed-off-by: Wenyou Yang <wenyou.yang@atmel.com>
Tested-by: Richard Genoud <richard.genoud@gmail.com>
to prepare the switch to the macro.
Pull ARM SoC device-tree updates from Olof Johansson:
"Part 1 of device-tree updates for 3.10. The bulk of the churn in this
branch is due to i.MX moving from C-defined pin control over to device
tree, which is a one-time conversion that will allow greater
flexibility down the road.
Besides that, there's PCI-e bindings for Marvell mvebu platforms and a
handful of cleanups to tegra due to the new include file functionality
of the device tree compiler"
* tag 'dt-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (113 commits)
arm: mvebu: PCIe Device Tree informations for Armada XP GP
arm: mvebu: PCIe Device Tree informations for Armada 370 DB
arm: mvebu: PCIe Device Tree informations for Armada 370 Mirabox
arm: mvebu: PCIe Device Tree informations for Armada XP DB
arm: mvebu: PCIe Device Tree informations for OpenBlocks AX3-4
arm: mvebu: add PCIe Device Tree informations for Armada XP
arm: mvebu: add PCIe Device Tree informations for Armada 370
ARM: sunxi: unify osc24M_fixed and osc24M
arm: vt8500: Add SDHC support to WM8505 DT
ARM: dts: Add a 64 bits version of the skeleton device tree
ARM: mvebu: Add Device Bus and CFI flash memory support to defconfig
ARM: mvebu: Add support for NOR flash device on Openblocks AX3 board
ARM: mvebu: Add support for NOR flash device on Armada XP-GP board
ARM: mvebu: Add Device Bus support for Armada 370/XP SoC
ARM: dts: imx6dl-wandboard: Add USB Host support
ARM: dts: imx51 cpu node
ARM: dts: Add missing imx27-phytec-phycore dtb target
ARM: dts: Add NFC support for i.MX27 Phytec PCM038 module
ARM: i.MX51: Add PATA support
ARM: dts: Add initial support for Wandboard Dual-Lite
Signed-off-by: Richard Genoud <richard.genoud@gmail.com>
[wenyou.yang@atmel.com: added spi nodes for the sam9263ek, sam9g20ek, sam9m10g45ek and sam9n12ek boards]
[wenyou.yang@atmel.com: submit the patch]
Gpio-keys nodes are not using the "reg" property in their sub nodes.
So, there is no need to define #address-cells and #size-cells properties
in gpio-keys nodes: we remove them.
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound
Pull sound updates from Takashi Iwai:
"This update contains a fairly wide range of changes all over in sound
subdirectory, mainly because of UAPI header moves by David and __dev*
annotation removals by Bill. Other highlights are:
- Introduced the support for wallclock timestamps in ALSA PCM core
- Add the poll loop implementation for HD-audio jack detection
- Yet more VGA-switcheroo fixes for HD-audio
- New VIA HD-audio codec support
- More fixes on resource management in USB audio and MIDI drivers
- More quirks for USB-audio ASUS Xonar U3, Reloop Play, Focusrite,
Roland VG-99, etc
- Add support for FastTrack C400 usb-audio
- Clean ups in many drivers regarding firmware loading
- Add PSC724 Ultiimate Edge support to ice1712
- A few hdspm driver updates
- New Stanton SCS.1d/1m FireWire driver
- Standardisation of the logging in ASoC codes
- DT and dmaengine support for ASoC Atmel
- Support for Wolfson ADSP cores
- New drivers for Freescale/iVeia P1022 and Maxim MAX98090
- Lots of other ASoC driver fixes and developments"
Fix up trivial conflicts. And go out on a limb and assume the dts file
'status' field of one of the conflicting things was supposed to be
"disabled", not "disable" like in pretty much all other cases.
* tag 'sound-3.8' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound: (341 commits)
ALSA: hda - Move runtime PM check to runtime_idle callback
ALSA: hda - Add stereo-dmic fixup for Acer Aspire One 522
ALSA: hda - Avoid doubly suspend after vga switcheroo
ALSA: usb-audio: Enable S/PDIF on the ASUS Xonar U3
ALSA: hda - Check validity of CORB/RIRB WP reads
ALSA: hda - use usleep_range in link reset and change timeout check
ALSA: HDA: VIA: Add support for codec VT1808.
ALSA: HDA: VIA Add support for codec VT1705CF.
ASoC: codecs: remove __dev* attributes
ASoC: utils: remove __dev* attributes
ASoC: ux500: remove __dev* attributes
ASoC: txx9: remove __dev* attributes
ASoC: tegra: remove __dev* attributes
ASoC: spear: remove __dev* attributes
ASoC: sh: remove __dev* attributes
ASoC: s6000: remove __dev* attributes
ASoC: OMAP: remove __dev* attributes
ASoC: nuc900: remove __dev* attributes
ASoC: mxs: remove __dev* attributes
ASoC: kirkwood: remove __dev* attributes
Add mci controller nodes to atmel boards.
Signed-off-by: Ludovic Desroches <ludovic.desroches@atmel.com>
http://github.com/at91linux/linux-at91 into at91
as we just use the rts and not the rts & cts for rs485
USART are the full pin uart
DBGU the debug Unit
UART the two pin uart
convert at91sam9g20ek with wm8731 to device tree support
Signed-off-by: Bo Shen <voice.shen@atmel.com>
Signed-off-by: Marek Belisko <marek.belisko@open-nandra.com>
Acked-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
Add both board revision support 1mmc and 2mmc and use a dtsi for common part.
