i2c-gpio doesn't need a reg property. Change the node names to i2c-gpio-x
as used in other dts to remove the unit-address.
Solves:
Warning (unit_address_vs_reg): Node /i2c@0 has a unit name, but no reg property
Warning (unit_address_vs_reg): Node /i2c@1 has a unit name, but no reg property
Warning (unit_address_vs_reg): Node /i2c@2 has a unit name, but no reg property
Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
The clocks group properties and the clock@0 node are useless, remove them
to avoid copy pasting in future device trees.
Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com>
Though the keyboard driver for GPIO buttons(gpio-keys) will continue to
check for/support the legacy "gpio-key,wakeup" boolean property to
enable gpio buttons as wakeup source, "wakeup-source" is the new
standard binding.
This patch replaces the legacy "gpio-key,wakeup" with the unified
"wakeup-source" property in order to avoid any futher copy-paste
duplication.
Cc: Alexandre Belloni <alexandre.belloni@free-electrons.com>
Cc: Jean-Christophe Plagniol-Villard <plagnioj@jcrosoft.com>
Signed-off-by: Sudeep Holla <sudeep.holla@arm.com>
Use stdout-path to specify the console and remove the console argument from
the kernel command line.
Add RTC support to the at91sam9rlek.
The clock-frequency property became obsolete since the rework of the main
clock driver in 3.16 (see commit 27cb1c2083373a44130d50d4d2fb64cf7eff2d90).
It now get and uses the clock-frequency from the main_xtal node.
Signed-off-by: Gaël PORTAY <g.portay@overkiz.com>
Acked-by: Boris Brezillon <boris.brezillon@free-electrons.com>
Having clocks grouped in a subnode is common practice, so move the crystals
under a clocks node for the at91sam9rl SoC and at91sam9rl based boards.
Acked-by: Boris BREZILLON <boris.brezillon@free-electrons.com>
arch/arm/boot/dts/at91sam9rl.dtsi
Needed as a dependency for the at91/dt2 branch
Define at91sam9rlek crystal frequencies.
Signed-off-by: Boris BREZILLON <boris.brezillon@free-electrons.com>
Acked-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
This adds support for:
- SPI
- Dataflash
- LCD
- i2c
- ADC
- Touchscreen
- USB gadget
- PWM
Also it switches the ds1 and ds2 leds to PWM control.
Define the main clock frequency for the new main clock node in
at91sam9rlek.dts
Acked-by: Boris BREZILLON <b.brezillon.dev@gmail.com>
Add a device tree for the at91sam9rl-ek. For now it supports:
- MMC
- dbgu
- usart1
- watchdog
- nand
- leds
- buttons
