path: root/arch/arm/boot/dts/at91sam9x25.dtsi
2014-11-03ARM: at91/dt: at91sam9x5: Add CAN device nodesAlexander Stein
Add the missing CAN devices node including their pin muxing to the shared .dtsi for at91sam9x5. Actually include this file. Signed-off-by: Alexander Stein <alexander.stein@systec-electronic.com> Acked-by: Alexandre Belloni <alexandre.belloni@free-electrons.com> Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com>
2013-10-16ARM: at91/dt: split sam9x5 peripheral definitionsBoris BREZILLON
This patch splits the sam9x5 peripheral definitions into: - a common base for all sam9x5 SoCs (at91sam9x5.dtsi) - several optional peripheral definitions which will be included by specific sam9x5 SoCs (at91sam9x5_'periph name'.dtsi) This provides a better representation of the real hardware (drop unneeded dt nodes) and avoids future peripheral id conflict (lcdc and isi both use peripheral id 25). Signed-off-by: Boris BREZILLON <b.brezillon@overkiz.com> Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com>
2013-05-17ARM: at91: dt: switch to pinctrl to pre-processorJean-Christophe PLAGNIOL-VILLARD
Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Acked-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com>
2013-05-17ARM: at91: dt: use #include for all device treesJean-Christophe PLAGNIOL-VILLARD
to prepare the switch to the macro. Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com>
2013-03-26ARM: at91/trivial: typos in compatible propertyNicolas Ferre
- unneeded whitespace - missing double quote Acked-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com> Cc: stable <stable@vger.kernel.org> # 3.8+
2012-11-19ARM: at91sam9: add macb pinctrl supportJean-Christophe PLAGNIOL-VILLARD
2012-10-13arm: at91: dt: at91sam9 add serial pinctrl supportJean-Christophe PLAGNIOL-VILLARD
Set the dbgu pinctrl config by default as we have only one possible config For other uart set the rxd/txd by default. For at91sam9x5ek create soc based dts as we need to include specific soc dtsi. Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com> Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
