path: root/arch/arm/boot/dts/at91sam9x35ek.dts
2015-08-07ARM: at91/dt: enable lcd support for at91sam9x5 SoCsBoris Brezillon
Use the at91sam9x5 display module dtsi in the relevant board dts. Signed-off-by: Boris Brezillon <boris.brezillon@free-electrons.com> Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
2013-05-17ARM: at91: dt: use #include for all device treesJean-Christophe PLAGNIOL-VILLARD
to prepare the switch to the macro. Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com>
2013-04-04ARM: at91/dt: fix macb node declarationNicolas Ferre
Macb0 node cannot be activated in generic sam9x5ek.dtsi file as the sam9g15 does not have one. Move the macb0 & macb1 activation in board .dts file that support them. Acked-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com>
2012-10-13arm: at91: dt: at91sam9 add serial pinctrl supportJean-Christophe PLAGNIOL-VILLARD
Set the dbgu pinctrl config by default as we have only one possible config For other uart set the rxd/txd by default. For at91sam9x5ek create soc based dts as we need to include specific soc dtsi. Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com> Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
