Use the new EBI/NAND bindings to declare NAND chips and remove old NAND
nodes along the way.
Note that we keep using old bindings in at91rm9200.dtsi because this
SoC is not supported by the EBI driver.
Signed-off-by: Boris Brezillon <boris.brezillon@free-electrons.com>
Tested-by: Peter Rosin <peda@axentia.se>
Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
Declare new nodes for the EBI and NAND controllers embedded in various
at91/sama5 SoCs.
Remove pullup on dbgu DTXD signal, it is a push-pull output thus the
pullup is pointless.
Add pullup on dbgu DRXD signal, it prevents the DRXD signal to be left
floating and so consuming a useless extra amount of power in crowbarred
state if nothing is externally connected to dbgu.
Signed-off-by: Sylvain Rochet <sylvain.rochet@finsecur.com>
i2c-gpio doesn't need a reg property. Change the node names to i2c-gpio-x
as used in other dts to remove the unit-address.
Solves:
Warning (unit_address_vs_reg): Node /i2c@0 has a unit name, but no reg property
Warning (unit_address_vs_reg): Node /i2c@1 has a unit name, but no reg property
Warning (unit_address_vs_reg): Node /i2c@2 has a unit name, but no reg property
Endpoint nodes have a reg property. Add their mandatory unit-address.
This solves:
Warning (unit_address_vs_reg): Node /ahb/gadget@00400000/ep0 has a reg or ranges property, but no unit name
Warning (unit_address_vs_reg): Node /ahb/gadget@00400000/ep1 has a reg or ranges property, but no unit name
Warning (unit_address_vs_reg): Node /ahb/gadget@00400000/ep2 has a reg or ranges property, but no unit name
Warning (unit_address_vs_reg): Node /ahb/gadget@00400000/ep3 has a reg or ranges property, but no unit name
Warning (unit_address_vs_reg): Node /ahb/gadget@00400000/ep4 has a reg or ranges property, but no unit name
Warning (unit_address_vs_reg): Node /ahb/gadget@00400000/ep5 has a reg or ranges property, but no unit name
Warning (unit_address_vs_reg): Node /ahb/gadget@00400000/ep6 has a reg or ranges property, but no unit name
Warning (unit_address_vs_reg): Node /ahb/gadget@00400000/ep7 has a reg or ranges property, but no unit name
Warning (unit_address_vs_reg): Node /ahb/gadget@00400000/ep8 has a reg or ranges property, but no unit name
Warning (unit_address_vs_reg): Node /ahb/gadget@00400000/ep9 has a reg or ranges property, but no unit name
Warning (unit_address_vs_reg): Node /ahb/gadget@00400000/ep10 has a reg or ranges property, but no unit name
Warning (unit_address_vs_reg): Node /ahb/gadget@00400000/ep11 has a reg or ranges property, but no unit name
Warning (unit_address_vs_reg): Node /ahb/gadget@00400000/ep12 has a reg or ranges property, but no unit name
Warning (unit_address_vs_reg): Node /ahb/gadget@00400000/ep13 has a reg or ranges property, but no unit name
Warning (unit_address_vs_reg): Node /ahb/gadget@00400000/ep14 has a reg or ranges property, but no unit name
Warning (unit_address_vs_reg): Node /ahb/gadget@00400000/ep15 has a reg or ranges property, but no unit name
The triggers don't need a reg property, remove it when prenset. Also remove
the unit-address from their name.
This solves:
Warning (unit_address_vs_reg): Node /ahb/apb/adc@fc034000/trigger@0 has a unit name, but no reg property
Warning (unit_address_vs_reg): Node /ahb/apb/adc@fc034000/trigger@1 has a unit name, but no reg property
Warning (unit_address_vs_reg): Node /ahb/apb/adc@fc034000/trigger@2 has a unit name, but no reg property
Warning (unit_address_vs_reg): Node /ahb/apb/adc@fc034000/trigger@3 has a unit name, but no reg property
The memory range assigned to the PMC (Power Management Controller) was
not including the PMC_PCR register which are used to control peripheral
clocks.
This was working fine thanks to the page granularity of ioremap(), but
started to fail when we switched to syscon/regmap, because regmap is
making sure that all accesses are falling into the reserved range.
Reported-by: Richard Genoud <richard.genoud@gmail.com>
Tested-by: Richard Genoud <richard.genoud@gmail.com>
Fixes: 863a81c3be1d ("clk: at91: make use of syscon to share PMC registers in several drivers")
Cc: <stable@vger.kernel.org>
Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com>
The PMC is not only used to drive the clocks but also has some registers
related to other functions. One of those is for example the USB gadget
bias.
Using a syscon allows to properly separate those functions.
Signed-off-by: Josh Wu <josh.wu@atmel.com>
The watchdog, the reset controller, the RTC, the shutdown controller, the
timer counters and the LCD PWM need the slow clock, add it where necessary,
The LCD PWM will be handled later.
Acked-by: Boris Brezillon <boris.brezillon@free-electrons.com>
at91sam9g45, at91sam9x5 and sama5 SoCs should not use
"atmel,at91sam9rl-udc" for their USB device compatible property since
this compatible is attached to a specific hardware bug fix.
Acked-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
Tested-by: Bo Shen <voice.shen@atmel.com>
Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com>
Cc: <stable@vger.kernel.org> #4.0+
Signed-off-by: Kevin Hilman <khilman@linaro.org>
The ohci driver now calls clk_set_rate on the uhpck clock (which forwards
set_rate requests to its parent: the usb clock).
Remove useless references to usb clocks from ohci definitions.
The uhpck is useless for High-Speed communications, remove the reference
to this clock in all ehci definitions.
SCK1 pin is pioC 29. Comment was okay.
Defines the pinctrl configurations for PWM0.
Signed-off-by: Gaël PORTAY <g.portay@overkiz.com>
The DBGU is not a simple UART and we need to be able to distinguish it from the
other UARTs, in particular to get its address and check the chip id.
The UTMI clock must be selected by any high-speed USB IP. The logic behind it
needs this particular clock.
So, correct the clock in the device tree files affected.
Reported-by: Bo Shen <voice.shen@atmel.com>
Cc: <stable@vger.kernel.org> #3.18
Since turning on idle-halt in commit fe46aa679f12 (ARM: at91/dt: add
sam9 watchdog default options to SoCs), SoCs compatible with at91sam9260-wdt
no longer reboot if the watchdog times out while the CPU is in idle state.
Removing the 'idle-halt' flag that was set by default fixes this.
Signed-off-by: Michel Marti <mma@objectxp.com>
Acked-by: Sylvain Rochet <sylvain.rochet@finsecur.com>
[nicolas.ferre@atmel.com: rework the commit message]
Add nodes for the SRAM available on atmel SoCs
For the at91sam9260 and the at91sam9g20, address mirroring is used to create a
single contiguous SRAM range instead of declaring two separate banks.
Also remove leftover TODOs in the sam9g45 file
[nicolas.ferre@atmel.com: correct at91sam9rl sram size => 0x10000]
This patch adds usart dma definitions to both dtsi for sam9x5 chips. Without
usage of dma it's unable to catch all bytes on usart receiver.
Signed-off-by: Jiri Prchal <jiri.prchal@aksignal.cz>
Acked-by: Ludovic Desroches <ludovic.desroches@atmel.com>
Use the correct compatible string for the ADC of the at91sam9x5 family of SoCs.
git://git.kernel.org/pub/scm/linux/kernel/git/mripard/linux
Pull AT91 ramc and reset/poweroff related DT patches from Maxim Ripard:
"This branch gathers a few devicetree patches needed for the reworks found in
the later patches to be sent. More precisely, it holds:
- The addition of ddrck for the sama5d3 and the sam9 SoCs
- The addition of the shutdown controller node in the sama5d3 DTSI
- The slight rework of the ramc bindings for the SoCs that have several RAM
controllers"
arch/arm/boot/dts/at91sam9g45.dtsi
Update to Linux 3.16-rc6 as a dependency for the broadcom changes.
Merge "Xilinx Zynq changes for v3.17" from Michal Simek:
arm: Xilinx Zynq dt patches for v3.17
- Document and use new cadence serial binding
* tag 'zynq-dt-for-3.17' of git://git.xilinx.com/linux-xlnx:
ARM: zynq: DT: Migrate UART to Cadence binding
tty: cadence: Document DT binding
+ Linux 3.16-rc5
Merge "at91: fixes for 3.16 #2" from Nicolas Ferre:
Second AT91 fixes series for 3.16
- fix clock definitions after the move to CCF for:
* at91sam9n12 (ohci)
* at91sam9x5 (ohci, pwm)
* tag 'at91-fixes' of git://github.com/at91linux/linux-at91:
ARM: at91/dt: add missing clocks property to pwm node in sam9x5.dtsi
ARM: at91/dt: fix usb0 clocks definition in sam9n12 dtsi
ARM: at91: at91sam9x5: correct typo error for ohci clock
The pwm driver requires a clocks property referencing the pwm peripheral
clk.
Signed-off-by: Boris BREZILLON <boris.brezillon@free-electrons.com>
Correct the typo error for the second "uhphs_clk".
Signed-off-by: Bo Shen <voice.shen@atmel.com>
Make the ram controller driver take the ddrck clock for at91sam9n12 and
at91sam9x5.
Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
Add clocks for usb device, or else switch to CCF, the gadget
won't work.
Reported-by: Jiri Prchal <jiri.prchal@aksignal.cz>
Tested-by: Jiri Prchal <jiri.prchal@aksignal.cz>
Having clocks grouped in a subnode is common practice, so move the crystals and
the ADC clock under a clocks node for the at91sam9x5 SoC and at91sam9x5 based
boards.
Acked-by: Boris BREZILLON <boris.brezillon@free-electrons.com>
ICPLL can only take 0 or 1, it got mixed with OUT which can be in the [0-3]
range.
Define sam9x5 clocks in sam9x5 dt files and make use of them in peripheral
definitions.
Remove the properties that are not used anymore by the at91_adc driver and fix
the atmel,adc-use-external-triggers property name.
Also, add #address-cells, #size-cells and a reg for each trigger to comply to
the ePAPR.
Add the "atmel,nand-has-dma" property to NAND node for SoC that
can use the DMA to perform NAND accesses.
Use of this property was added in 1b7192658a08f70df0f290634fd7cd2ecb629fc9
(mtd: atmel_nand: add a new dt binding item for nand dma support).
Acked-by: Boris BREZILLON <b.brezillon@overkiz.com>
Set default watchdog options in every SoC compatible with the sam9 watchdog.
Signed-off-by: Boris BREZILLON <b.brezillon@overkiz.com>
Acked-by: Guenter Roeck <linux@roeck-us.net>
Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
Add PWM device node for AT91 series SoC.
git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap into next/cleanup
From Paul Walmsley <paul@pwsan.com> via Tony Lindgren:
Move some of the OMAP2+ CM and System Control Module direct
register accesses into CM- and System Control
Module-specific "drivers" underneath arch/arm/mach-omap2/. This
is a prerequisite for moving this code out of arch/arm/mach-omap2/ into
drivers/.
Basic test logs are available here:
http://www.pwsan.com/omap/testlogs/cm_scm_cleanup_a_v3.13/20131019101809/
* tag 'omap-for-v3.13/cm-scm-cleanup-signed' of git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap:
ARM: OMAP3: control: add API for setting IVA bootmode
ARM: OMAP3: CM/control: move CM scratchpad save to CM driver
ARM: OMAP3: McBSP: do not access CM register directly
ARM: OMAP3: clock: add API to enable/disable autoidle for a single clock
ARM: OMAP2: CM/PM: remove direct register accesses outside CM code
+ Linux 3.12-rc4
This patch splits the sam9x5 peripheral definitions into:
- a common base for all sam9x5 SoCs (at91sam9x5.dtsi)
- several optional peripheral definitions which will be included by specific
sam9x5 SoCs (at91sam9x5_'periph name'.dtsi)
This provides a better representation of the real hardware (drop unneeded
dt nodes) and avoids future peripheral id conflict (lcdc and isi both use
peripheral id 25).
Replace pinctrl_usart2_rts and pinctrl_usart2_cts istead of pinctrl_uart2_*.
Signed-off-by: Richard Genoud <richard.genoud@gmail.com>
From Nicolas Ferre:
Again some nice DT updates for AT91:
- DMA binding update with one patch shared with slave-dma tree
- more SPI DT activation
- enable the USB gadget HS for DT platforms
* tag 'at91-dt' of git://github.com/at91linux/linux-at91:
ARM: at91: sam9m10g45ek add udc DT support
ARM: at91: sam9g45 add udc DT support
ARM: at91: sam9x5ek add udc DT support
ARM: at91: sam9x5 add udc DT support
ARM: at91: dt: at91sam9x5: add SPI DMA client infos
ARM: at91: dt: switch DMA DT bindings to pre-processor
ARM: at91: dt: add header to define at_hdmac configuration
Acked-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
Signed-off-by: Ludovic Desroches <ludovic.desroches@atmel.com>
From Lorenzo Pieralisi, this is a series of patches that cleans up the CPU
nodes in most of the SoC dtsi files to conform to the standard bindings.
* 'dts-cpus-updates' of git://linux-arm.org/linux-2.6-lp:
ARM: dts: sunxi: cpus/cpu nodes dts updates
ARM: dts: spear: cpus/cpu nodes dts updates
ARM: dts: sh7372: cpus/cpu nodes dts updates
ARM: dts: r8a7740: cpus/cpu nodes dts updates
ARM: dts: pxa2xx: cpus/cpu nodes dts updates
ARM: dts: prima2: cpus/cpu node dts updates
ARM: dts: picoxcell: cpus/cpu nodes dts updates
ARM: dts: omap: cpus/cpu nodes dts updates
ARM: dts: lpc32xx: cpus/cpu nodes dts updates
ARM: dts: imx: cpus/cpu nodes dts updates
ARM: dts: exynos5440: cpus/cpu nodes dts updates
ARM: dts: at91: cpus/cpu node dts updates
ARM: dts: armada-370-xp: cpus/cpu node dts updates
ARM: dts: am33xx: cpus/cpu nodes dts updates
This patch adds pinctrl configurations for at91 Timer Counter blocks.
These pin definitions can be referenced by "atmel,tcb-pwm" devices to
setup pins as PWM output for instance.
[nicolas.ferre@atmel.com: switch to pinctrl pre-processor macros]
at91sam9x5, at91sam9n12
Signed-off-by: Wenyou Yang <wenyou.yang@atmel.com>
Reported-by: Douglas Gilbert <dgilbert@interlog.com>
Due to a bug with RTC IMR, we cannot consider at91sam9x5 RTC compatible
with the previous one. Modify DT compatibility string, even if the driver
is not yet modified to take it into account.
