path: root/arch/arm/boot/dts/at91sam9x5cm.dtsi
2019-11-24ARM: dts: at91: at91sam9x5cm: fix addressable nand flash sizeTudor Ambarus
[ Upstream commit 6f270d88a0c4a11725afd8fd2001ae408733afbf ] at91sam9x5cm comes with a 2Gb NAND flash. Fix the rootfs size to match this limit. Signed-off-by: Tudor Ambarus <tudor.ambarus@microchip.com> Signed-off-by: Ludovic Desroches <ludovic.desroches@microchip.com> Signed-off-by: Sasha Levin <sashal@kernel.org>
2017-05-31ARM: dts: at91: Switch to the new NAND bindingsBoris Brezillon
Use the new EBI/NAND bindings to declare NAND chips and remove old NAND nodes along the way. Note that we keep using old bindings in at91rm9200.dtsi because this SoC is not supported by the EBI driver. Signed-off-by: Boris Brezillon <boris.brezillon@free-electrons.com> Tested-by: Peter Rosin <peda@axentia.se> Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
2015-11-16ARM: at91/dt: remove leftovers clock definitionAlexandre Belloni
The clocks group properties and the clock@0 node are useless, remove them to avoid copy pasting in future device trees. Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com> Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com>
2015-03-23ARM: at91/dt: at91sam9x5cm: enable RTCNicolas Ferre
Enable RTC for all the at91sam9x5 CPU Modules: this will enable it for all the EK boards. Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com>
2014-07-09ARM: at91/dt: sam9x5 crystals under the clocks nodeAlexandre Belloni
Having clocks grouped in a subnode is common practice, so move the crystals and the ADC clock under a clocks node for the at91sam9x5 SoC and at91sam9x5 based boards. Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com> Acked-by: Boris BREZILLON <boris.brezillon@free-electrons.com> Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com>
2014-05-22ARM: at91/dt: define sam9x5ek's crystal frequenciesBoris BREZILLON
Define sam9x5ek's main and slow crystal frequencies. Signed-off-by: Boris BREZILLON <boris.brezillon@free-electrons.com> Acked-by: Alexandre Belloni <alexandre.belloni@free-electrons.com> Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com>
2013-05-17ARM: at91: dt: switch to pinctrl to pre-processorJean-Christophe PLAGNIOL-VILLARD
Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Acked-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com>
2013-05-17ARM: at91: dt: switch to standard GPIO flag defines.Jean-Christophe PLAGNIOL-VILLARD
Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com>
2013-03-21ARM: at91/at91sam9x5cm: add 1-wire chip on CM boardRichard Genoud
This add the 1-wire chip present on the CM board to the DTS. As the pin is also used by leds, it's disabled by default. If the board really wants it, it can be enabled in the board DTS. Signed-off-by: Richard Genoud <richard.genoud@gmail.com> Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com>
2013-02-07ARM: at91: at91sam9x5: add DT parameters to enable PMECCJosh Wu
Default ecc correctable setting is 2bits in 512 bytes. Signed-off-by: Josh Wu <josh.wu@atmel.com> Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com>
2012-04-04ARM: at91: dt: remove unit-address part for memory nodesLudovic Desroches
Because of the inclusion of skeleton.dtsi, the memory node is named "memory" we where not modifying the already included one but creating a new one. It caused bad memory node detection during early_init_dt_scan_memory() so we modify them. Signed-off-by: Ludovic Desroches <ludovic.desroches@atmel.com> Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com> Acked-by: Grant Likely <grant.likely@secretlab.ca> Cc: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Cc: devicetree-discuss@lists.ozlabs.org
2012-03-15ARM: at91: add pmc DT supportJean-Christophe PLAGNIOL-VILLARD
Specified the main Oscillator via clock binding. This will allow to do not hardcode it anymore in the DT board at 12MHz. Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Acked-by: Rob Herring <rob.herring@calxeda.com> Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com>
2012-03-15ARM: at91: sam9x5 add nand supportJean-Christophe PLAGNIOL-VILLARD
Enable the nand in the cpu module with the partition. Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2012-03-01ARM: at91: at91sam9x5cm/dt: add leds supportJean-Christophe PLAGNIOL-VILLARD
Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com>
2012-02-03ARM: at91/at91sam9x5: Device tree definition filesNicolas Ferre
Device tree include file for the AT91SAM9x5 SoC family. An additional .dtsi file is created to describe the generic SAM9x5 CPU Module (CM). Device tree source files for each Evaluation Kit that are using the generic CPU Module and the carrier board. The selection of available peripherals is done in this .dts file. Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com>
