The A13 hardware line is shared by SPI and MCI1 controller.This patch
disables the SPI controller so that the MCI1 (the big MMC card slot) can
be used.
Signed-off-by: Cristian Birsan <cristian.birsan@microchip.com>
Acked-by: Nicolas Ferre <nicolas.ferre@microchip.com>
Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
The ISI is only present on the at91sam9g25, move the definition to the
at91sam9g25ek board dts to avoid warnings.
Solves the following warning for other 9x5ek boards:
Warning (unit_address_vs_reg): Node /ahb/apb/isi@f8048000 has a unit name, but no reg property
On at91sam9x5ek/at91sam9m10g45ek/sama5d3xek boards, we use the parallel
connection for ov2640. So we must set the hsync/vsync property (1 means
active high).
Otherwise, the connection would be seen as BT.656 or BT.1120.
Signed-off-by: Josh Wu <josh.wu@atmel.com>
Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com>
Use stdout-path to specify the console and remove the console argument from
the kernel command line.
Add the camera sensor ov2640 dt support. And connect sensor to isi node
as well.
Acked-by: Boris Brezillon <boris.brezillon@free-electrons.com>
There is an external resistor divider on PB16, acting like a pull-down,
the pull-up increase power consumption and prevent the vbus detect pin
to reach Vss voltage, ~1.5V mesured on my board, it might not even work
if the pull-up is stronger than usual.
Signed-off-by: Sylvain Rochet <sylvain.rochet@finsecur.com>
Acked-by: Bo Shen <voice.shen@atmel.com>
Acked-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
Pull ARM SoC DT updates from Olof Johansson:
"Device tree and bindings updates for 3.12.
General additions of various on-chip and on-board peripherals on
various platforms as support gets added. Some of the bigger changes
are:
- Addition of (new) PCI-e support on Tegra.
- More Tegra4 support, including PMC configuration for Dalmore.
- Addition of a new board for Exynos4 (trats2) and more bindings for
4x12 IP.
- Addition of Allwinner A20 and A31 SoC and board files.
- Move of the ST Ericsson device tree files to now use ste-* prefix.
- More move of hardware description of shmobile platforms to DT.
- Two new board dts files for Freescale MXs"
* tag 'dt-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (177 commits)
dts: Rename DW APB timer compatible strings
dts: Deprecate ALTR as a vendor prefix
of: add vendor prefix for Altera Corp.
ARM: at91/dt: sam9x5ek: add sound configuration
ARM: at91/dt: sam9x5ek: enable SSC
ARM: at91/dt: sam9x5ek: add WM8731 codec
ARM: at91/dt: sam9x5: add SSC DMA parameters
ARM: at91/dt: add at91rm9200 PQFP package version
ARM: at91: at91rm9200: set default mmc0 pinctrl-names
ARM: at91: at91sam9n12: correct pin number of gpio-key
ARM: at91: at91sam9n12: add qt1070 support
ARM: at91: at91sam9n12: add pinctrl of TWI
ARM: at91: Add PMU support for sama5d3
ARM: at91: at91sam9260: add missing pinctrl-names on mmc
ARM: tegra: configure power off for Dalmore
ARM: DT: binding fixup to align with vendor-prefixes.txt (DT)
ARM: dts: add sdio blocks to bcm28155-ap board
ARM: dts: align sdio numbers to HW definition
ARM: sun7i: Add Olimex A20-Olinuxino-Micro support
ARM: sun7i: Add Allwinner A20 DTSI
The sam9x5ek board has 2 jacks:
headphone wired on RHPOUT/LHPOUT of the wm8731
line in wired on LLINEIN/RLINEIN of the wm8731
Signed-off-by: Richard Genoud <richard.genoud@gmail.com>
Enable the SSC needed for the WM8731 codec
The WM8731 codec on sam9x5ek board is on i2c, address 1A
Acked-by: Mark Brown <broonie@linaro.org>
Device Tree "num-ports" property of USB host node has to be
set to maximum number of ports available.
The possibility to activate a particular port is done by specifying the proper
gpio configuration for its vbus.
This patch fixes the USB host node by configuring the 3 ports available on the
product and letting "port A" available for USB gadget usage.
Reported-by: Rodolfo Giometti <giometti@enneenne.com>
Acked-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
Cc: Bo Shen <voice.shen@atmel.com>
Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com>
Tested-by: Bo Shen <voice.shen@atmel.com>
boards include:
at91sam9263ek, at91sam9g20ek, at91sam9m10g45ek, at91sam9n12ek, at91sam9x5ek
Signed-off-by: Wenyou Yang <wenyou.yang@atmel.com>
Tested-by: Richard Genoud <richard.genoud@gmail.com>
to prepare the switch to the macro.
Pull ARM SoC device-tree updates from Olof Johansson:
"Part 1 of device-tree updates for 3.10. The bulk of the churn in this
branch is due to i.MX moving from C-defined pin control over to device
tree, which is a one-time conversion that will allow greater
flexibility down the road.
Besides that, there's PCI-e bindings for Marvell mvebu platforms and a
handful of cleanups to tegra due to the new include file functionality
of the device tree compiler"
* tag 'dt-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (113 commits)
arm: mvebu: PCIe Device Tree informations for Armada XP GP
arm: mvebu: PCIe Device Tree informations for Armada 370 DB
arm: mvebu: PCIe Device Tree informations for Armada 370 Mirabox
arm: mvebu: PCIe Device Tree informations for Armada XP DB
arm: mvebu: PCIe Device Tree informations for OpenBlocks AX3-4
arm: mvebu: add PCIe Device Tree informations for Armada XP
arm: mvebu: add PCIe Device Tree informations for Armada 370
ARM: sunxi: unify osc24M_fixed and osc24M
arm: vt8500: Add SDHC support to WM8505 DT
ARM: dts: Add a 64 bits version of the skeleton device tree
ARM: mvebu: Add Device Bus and CFI flash memory support to defconfig
ARM: mvebu: Add support for NOR flash device on Openblocks AX3 board
ARM: mvebu: Add support for NOR flash device on Armada XP-GP board
ARM: mvebu: Add Device Bus support for Armada 370/XP SoC
ARM: dts: imx6dl-wandboard: Add USB Host support
ARM: dts: imx51 cpu node
ARM: dts: Add missing imx27-phytec-phycore dtb target
ARM: dts: Add NFC support for i.MX27 Phytec PCM038 module
ARM: i.MX51: Add PATA support
ARM: dts: Add initial support for Wandboard Dual-Lite
[wenyou.yang@atmel.com: added spi nodes for the sam9263ek, sam9g20ek, sam9m10g45ek and sam9n12ek boards]
[wenyou.yang@atmel.com: submit the patch]
Macb0 node cannot be activated in generic sam9x5ek.dtsi file
as the sam9g15 does not have one.
Move the macb0 & macb1 activation in board .dts file that
support them.
Remove the malformed "mem=" bootargs parameter in at91sam9x5ek.dtsi
Cc: stable <stable@vger.kernel.org> # 3.8+
On at91sam9x5ek, macb0 is enabled, so it conflicts with i2c2 (PB4)
same for i2c1, (conflicts with LCD).
Moreover, only i2c0 is used on this board.
Add mci controller nodes to atmel boards.
Signed-off-by: Ludovic Desroches <ludovic.desroches@atmel.com>
Set the dbgu pinctrl config by default as we have only one possible config
For other uart set the rxd/txd by default.
For at91sam9x5ek create soc based dts as we need to include specific soc dtsi.
