Add a node describing the drivebus regulator which is an (optional)
part of the axp221/axp223 pmic. Since this regulator may not be
available at all depending on the board, mark it as disabled by
default.
Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
Add a node describing the (optional) usbpower-supply of the
axp221 / axp223 pmic.
Use of these as regulators conflicts with use of the gpio pins as
gpios, so disabled the ldo_io# regulators by default, this avoids
the regulator core touching them when the pins are used as gpios.
The AXP22x family of PMIC is used with some Allwinner SoCs. This
includes the AXP221, AXP221s and AXP223. They differ in the host
interface, maximum supply current for DCDC1 regulator, and default
voltage and state for various LDO regulators. Also, the AXP221s
does not support fine calibration of the battery fuel gauge.
This patch adds a dtsi file for all the common bindings for these
PMICs. Currently this is just listing all the regulator nodes. The
regulators are initialized based on their device node names.
Signed-off-by: Chen-Yu Tsai <wens@csie.org>
