path: root/arch/arm/boot/dts/bcm2835-rpi-zero-w.dts
2020-06-03ARM: dts: bcm2835-rpi-zero-w: Fix led polarityVincent Stehlé
[ Upstream commit 58bb90ab415562eededb932455046924e65df342 ] The status "ACT" led on the Raspberry Pi Zero W is on when GPIO 47 is low. This has been verified on a board and somewhat confirmed by both the GPIO name ("STATUS_LED_N") and the reduced schematics [1]. [1]: https://www.raspberrypi.org/documentation/hardware/raspberrypi/schematics/rpi_SCH_ZeroW_1p1_reduced.pdf Fixes: 2c7c040c73e9 ("ARM: dts: bcm2835: Add Raspberry Pi Zero W") Signed-off-by: Vincent Stehlé <vincent.stehle@laposte.net> Cc: Stefan Wahren <stefan.wahren@i2se.com> Cc: Florian Fainelli <f.fainelli@gmail.com> Tested-by: Stefan Wahren <stefan.wahren@i2se.com> Signed-off-by: Florian Fainelli <f.fainelli@gmail.com> Signed-off-by: Sasha Levin <sashal@kernel.org>
2020-04-02ARM: bcm2835-rpi-zero-w: Add missing pinctrl nameNick Hudson
commit 6687c201fdc3139315c2ea7ef96c157672805cdc upstream. Define the sdhci pinctrl state as "default" so it gets applied correctly and to match all other RPis. Fixes: 2c7c040c73e9 ("ARM: dts: bcm2835: Add Raspberry Pi Zero W") Signed-off-by: Nick Hudson <skrll@netbsd.org> Signed-off-by: Florian Fainelli <f.fainelli@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2019-10-15ARM: dts: bcm2835-rpi-zero-w: Fix bus-width of sdhciStefan Wahren
The commit e7774049ff25 ("ARM: dts: bcm283x: Define MMC interfaces at board level") accidently dropped the bus width for the sdhci on the RPi Zero W, because the board file was relying on the defaults from bcm2835-rpi.dtsi. So fix this performance regression by adding the bus width to the board file. Fixes: e7774049ff25 ("ARM: dts: bcm283x: Define MMC interfaces at board level") Reported-by: Phil Elwell <phil@raspberrypi.org> Signed-off-by: Stefan Wahren <wahrenst@gmx.net> Signed-off-by: Florian Fainelli <f.fainelli@gmail.com>
2019-08-15ARM: dts: bcm283x: Enable HDMI at board levelStefan Wahren
There might be headless setups of the Compute Module without HDMI, so better enable HDMI at board level. Btw this allows moving HDMI base definition into upcoming bcm2835-common.dtsi. Signed-off-by: Stefan Wahren <wahrenst@gmx.net> Reviewed-by: Eric Anholt <eric@anholt.net>
2019-08-12ARM: dts: bcm283x: Define memory at board levelStefan Wahren
Now with the varity of several RPi boards, the memory should be defined at board level. This step gives us the chance to fix the memory size of the RPi 1 B+, Zero (incl. W) and Compute Module 1. Signed-off-by: Stefan Wahren <wahrenst@gmx.net> Acked-by: Eric Anholt <eric@anholt.net>
2019-08-12ARM: dts: bcm283x: Define MMC interfaces at board levelStefan Wahren
Starting with RPi 4 this is the first board, which doesn't use sdhost as default SD interface. So the MMC interfaces should be defined finally at board level. Since all boards using sdhci already does this, we can drop the pinctrl part from bcm2835-rpi.dtsi. Signed-off-by: Stefan Wahren <wahrenst@gmx.net> Acked-by: Eric Anholt <eric@anholt.net>
2019-02-01ARM: dts: bcm2835-rpi-zero-w: Drop unnecessary pinctrlStefan Wahren
There is no need to specify a pinctrl for the reset GPIO. So we better remove this avoid a potential conflict between pinctrl and pwrseq after the pinmux driver has been changed to strict: pinctrl-bcm2835 20200000.gpio: pin gpio41 already requested by wifi-pwrseq; cannot claim for pinctrl-bcm2835:499 pinctrl-bcm2835 20200000.gpio: pin-41 (pinctrl-bcm2835:499) status -22 pwrseq_simple: probe of wifi-pwrseq failed with error -22 Signed-off-by: Stefan Wahren <stefan.wahren@i2se.com> Reviewed-by: Eric Anholt <eric@anholt.net>
2019-02-01ARM: dts: bcm2835: Fix labels for GPIO 0,1Stefan Wahren
According to the schematics for all RPis with a 40 pin header, the GPIOs 0 and 1 are labeled as ID_SD and ID_SC. In order to clarify that is a I2C bus, append the third letter. Signed-off-by: Stefan Wahren <stefan.wahren@i2se.com> Reviewed-by: Eric Anholt <eric@anholt.net>
2018-11-13ARM: dts: bcm2835-rpi-zero: Switch to SPDX identifierStefan Wahren
Adopt the SPDX license identifier headers to ease license compliance management. Signed-off-by: Stefan Wahren <stefan.wahren@i2se.com> Reviewed-by: Eric Anholt <eric@anholt.net>
2018-02-26ARM: dts: bcm2835-rpi-zero-w: Enable OTG modeStefan Wahren
Since commit 9273083a1530 ("usb: dwc2: Fix TxFIFOn sizes and total TxFIFO size issues") we could use the OTG mode again. Signed-off-by: Stefan Wahren <stefan.wahren@i2se.com> Signed-off-by: Eric Anholt <eric@anholt.net>
2018-02-26ARM: dts: bcm2835-rpi-zero-w: Add bcm43438 serial slaveStefan Wahren
Add BCM43438 (bluetooth) as a serdev slave device of uart0 (pl011/ttyAMA0). This allows to automatically insert the bcm43438 to the bluetooth subsystem instead of relying on patched userspace helpers (hciattach). In order to keep a debug UART we need to switch to uart1. Signed-off-by: Stefan Wahren <stefan.wahren@i2se.com> Signed-off-by: Eric Anholt <eric@anholt.net>
2017-10-06ARM: dts: bcm283x: Fix console path on RPi3Loic Poulain
Contrary to other RPi devices, RPi3 uses uart0 to communicate with the BCM43438 bluetooth controller. uart1 is then used for the console. Today, the console configuration is inherited from the bcm283x dtsi (bootargs) which is not the correct one for the RPi3. This leads to routing issue and confuses the Bluetooth controller with unexpected data. This patch introduces chosen/stdout path to configure console to uart0 on bcm283x family and overwrite it to uart1 in the RPi3 dts. Create serial0/1 aliases referring to uart0 and uart1 paths. Remove unneeded earlyprintk. Fixes: 4188ea2aeb6d ("ARM: bcm283x: Define UART pinmuxing on board level") Signed-off-by: Loic Poulain <loic.poulain@gmail.com> Tested-by: Stefan Wahren <stefan.wahren@i2se.com> Signed-off-by: Eric Anholt <eric@anholt.net> Reviewed-by: Eric Anholt <eric@anholt.net>
2017-08-02ARM: dts: bcm2835: Add Raspberry Pi Zero WStefan Wahren
The Raspberry Pi Zero W has the same components like the Zero plus a Cypress CYW43438 wireless chip (wifi + bl). Signed-off-by: Stefan Wahren <stefan.wahren@i2se.com> Signed-off-by: Eric Anholt <eric@anholt.net> Reviewed-by: Eric Anholt <eric@anholt.net>
