There might be headless setups of the Compute Module without HDMI,
so better enable HDMI at board level. Btw this allows moving HDMI
base definition into upcoming bcm2835-common.dtsi.
Signed-off-by: Stefan Wahren <wahrenst@gmx.net>
Reviewed-by: Eric Anholt <eric@anholt.net>
Now with the varity of several RPi boards, the memory should be defined
at board level. This step gives us the chance to fix the memory size
of the RPi 1 B+, Zero (incl. W) and Compute Module 1.
Acked-by: Eric Anholt <eric@anholt.net>
Starting with RPi 4 this is the first board, which doesn't use sdhost
as default SD interface. So the MMC interfaces should be defined finally at
board level. Since all boards using sdhci already does this, we can drop the
pinctrl part from bcm2835-rpi.dtsi.
The GPIO sysfs is deprecated and disabled in the defconfig files.
So in order to motivate the usage of the new GPIO character device API
add the missing GPIO line names for Raspberry Pi 2 and 3. In the lack
of full schematics i would leave all undocumented pins as unnamed.
Signed-off-by: Stefan Wahren <stefan.wahren@i2se.com>
Tested-by: Peter Robinson <pbrobinson@gmail.com>
Compiling the bcm283x DTS with W=1 leads to the following warning:
Warning (unit_address_vs_reg): /memory: node has a reg or ranges property,
but no unit name
Fix this by adding the unit address.
To allow VCHIQ to determine the correct cache line size, use the new
"brcm,bcm2836-vchiq" compatible string on BCM2836 and BCM2837.
Signed-off-by: Phil Elwell <phil@raspberrypi.org>
Acked-by: Stefan Wahren <stefan.wahren@i2se.com>
All RPi 1 and 2 boards used the PWM (audio out) on pin 40 and 45.
So it was easy to define them in bcm2835-rpi.dtsi. Starting with RPi 3
this wont work anymore, because it uses pin 40 and 41. Furthermore the
Zero variants doesn't have audio out.
This patch fixes this pin conflict by moving the PWM node to the board-level.
Change summary:
RPi 3 B: PWM1 45 -> 41
Zero, Zero W: PWM disabled
all other: no functional change
Reported-by: Baruch Siach <baruch@tkos.co.il>
Signed-off-by: Eric Anholt <eric@anholt.net>
Currently most of the Raspberry Pi DTS have a mixture of magic
numbers and the proper GPIO polarity defines. So use the latter
one consistently.
Philippe Ombredanne.
How this work was done:
the use cases:
lines of source
lines).
identifiers to apply.
COPYING file license applied.
GPL-2.0 11139
the concluded license(s).
in time.
they are related.
in about 15000 files.
correct identifier.
version early this week with:
license ids and scores
generate the patches.
Until RPI 3 and Zero W the pl011 (uart0) was always on pin 14/15. So in
order to take care of them and other boards in the future,
we need to define UART pinmuxing on board level.
This work based on Eric Anholt's patch "ARM: bcm2385: Don't force pl011
onto pins 14/15." and Fabian Vogt's patch "ARM64: dts: bcm2837: assign
uart0 to BT and uart1 to pin headers".
As the alt3 group has no pins left drop it from &gpio.
Signed-off-by: Gerd Hoffmann <kraxel@redhat.com>
In case dr_mode isn't passed via DT, the dwc2 defaults to OTG mode.
But all Raspberry Pi boards here are designed only for host mode.
So fix this issue by providing a dtsi file which set the dr_mode
to host.
The hub and the ethernet in its port 1 are hardwired on the board.
Compared to the adapters that can be plugged into the USB ports, this
one has no serial EEPROM to store its MAC. Nevertheless, the Raspberry Pi
has the MAC address for this adapter in its ROM, accessible from its
firmware.
U-Boot can read out the address and set the local-mac-address property of the
node with "ethernet" alias. Let's add the node so that U-Boot can do its
business.
Model B rev2 and Model B+ entries were verified by me, the hierarchy and
pid/vid pair for the Version 2 was provided by Peter Chen. Original
Model B is a blind shot, though very likely correct.
Signed-off-by: Lubomir Rintel <lkundrak@v3.sk>
Acked-by: Stephen Warren <swarren@wwwdotorg.org>
VC4 is the GPU (display and 3D) present on the 283x.
The Pi 2 B ends up like a Pi 1 B+, with the same peripherals and
pinout, but the CPU and memory layout changed to use the 2836.
