This uses trigger-sources documented in commit 80dc6e1cd85fc ("dt-bindings:
leds: document new trigger-sources property") to specify USB ports. Such an
information can be used by operating system to setup LEDs behavior.
I updated dts files for 7 devices I own and I was able to test.
Signed-off-by: Rafał Miłecki <rafal@milecki.pl>
Signed-off-by: Florian Fainelli <f.fainelli@gmail.com>
Such a trigger doesn't exist in Linux and is not needed as LED is being
turned off by default. This could cause errors in LEDs core code when
trying to set default trigger.
The first 128 MiB of RAM can be accessed using an alias at address 0x0.
In theory we could access whole RAM using 0x80000000 - 0xbfffffff range
(up to 1 GiB) but it doesn't seem to work on Northstar. For some reason
(hardware setup left by the bootloader maybe?) 0x80000000 - 0x87ffffff
range can't be used. I reproduced this problem on:
1) Buffalo WZR-600DHP2 (BCM47081)
2) Netgear R6250 (BCM4708)
3) D-Link DIR-885L (BCM47094)
So it seems we're forced to access first 128 MiB using alias at 0x0 and
the rest using real base address + 128 MiB offset which is 0x88000000.
Acked-by: Jon Mason <jon.mason@broadcom.com>
Every device tested so far got UART0 (at 0x18000300) working as serial
console. It's most likely part of reference design and all vendors use
it that way.
It seems to be easier to enable it by default and just disable it if we
ever see a device with different hardware design.
Acked-by: Hauke Mehrtens <hauke@hauke-m.de>
Commit 1b47b98acce2 ("ARM: BCM5301X: Add DT entry for SPI controller and
NOR flash") enabled SPI-NOR device on routers using serial flash only.
However there are also devices with two flash memories:
1) Small SPI attached flash used mostly for booting
2) Bigger NAND used mostly for storing firmware
On such devices we still need SPI-NOR e.g. to access NVRAM data.
Signed-off-by: Rafał Miłecki <zajec5@gmail.com>
This allows reporting & debugging problems occurring early in the boot
process.
There are few devices that have USB power controlled using GPIO. Linux
USB host driver (bcma-hcd) already supports this by reading vcc-gpio
from DT. Set it properly for all known devices.
There are two possible UARTs so we have (both of) them disabled by
default. Override uart0 status on devices that were verified to use it.
In case of Netgear R6250 also drop an old (and invalid) overwrite. It
doesn't have uart1 connected.
This adds the NAND flash chip description for a standard chip found
connected to this SoC. This makes use of generic Broadcom NAND driver
with the iProc interface.
Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
Signed-off-by: Felix Fietkau <nbd@openwrt.org>
It was accidentally left (& copied & pasted all around) from our
experiments with gpio-keys-polled.
