Such a trigger doesn't exist in Linux and is not needed as LED is being
turned off by default. This could cause errors in LEDs core code when
trying to set default trigger.
Signed-off-by: Rafał Miłecki <rafal@milecki.pl>
Signed-off-by: Florian Fainelli <f.fainelli@gmail.com>
It's preferred to have DT source files licensed under BSD compatible
license. All new BCM5301X DTS files use ISC so let's also relicense old
ones to it.
Except for me only Hauke was ever touched these files in his commit
9faa5960eef3 ("ARM: BCM5301X: add NAND flash chip description") and
commit bb1d8fba1965 ("ARM: BCM5301X: add NAND flash chip description for
Asus RT-AC87U").
Acked-by: Hauke Mehrtens <hauke@hauke-m.de>
The first 128 MiB of RAM can be accessed using an alias at address 0x0.
In theory we could access whole RAM using 0x80000000 - 0xbfffffff range
(up to 1 GiB) but it doesn't seem to work on Northstar. For some reason
(hardware setup left by the bootloader maybe?) 0x80000000 - 0x87ffffff
range can't be used. I reproduced this problem on:
1) Buffalo WZR-600DHP2 (BCM47081)
2) Netgear R6250 (BCM4708)
3) D-Link DIR-885L (BCM47094)
So it seems we're forced to access first 128 MiB using alias at 0x0 and
the rest using real base address + 128 MiB offset which is 0x88000000.
Acked-by: Jon Mason <jon.mason@broadcom.com>
This adds the NAND flash chip description for a standard chip found
connected to this SoC. This makes use of generic Broadcom NAND driver
with the iProc interface.
Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
It was accidentally left (& copied & pasted all around) from our
experiments with gpio-keys-polled.
Signed-off-by: Rafał Miłecki <zajec5@gmail.com>
