Such a trigger doesn't exist in Linux and is not needed as LED is being
turned off by default. This could cause errors in LEDs core code when
trying to set default trigger.
Signed-off-by: Rafał Miłecki <rafal@milecki.pl>
Signed-off-by: Florian Fainelli <f.fainelli@gmail.com>
It's preferred to have DT source files licensed under BSD compatible
license. All new BCM5301X DTS files use ISC so let's also relicense old
ones to it.
Except for me only Hauke was ever touched these files in his commit
9faa5960eef3 ("ARM: BCM5301X: add NAND flash chip description") and
commit bb1d8fba1965 ("ARM: BCM5301X: add NAND flash chip description for
Asus RT-AC87U").
Acked-by: Hauke Mehrtens <hauke@hauke-m.de>
The first 128 MiB of RAM can be accessed using an alias at address 0x0.
In theory we could access whole RAM using 0x80000000 - 0xbfffffff range
(up to 1 GiB) but it doesn't seem to work on Northstar. For some reason
(hardware setup left by the bootloader maybe?) 0x80000000 - 0x87ffffff
range can't be used. I reproduced this problem on:
1) Buffalo WZR-600DHP2 (BCM47081)
2) Netgear R6250 (BCM4708)
3) D-Link DIR-885L (BCM47094)
So it seems we're forced to access first 128 MiB using alias at 0x0 and
the rest using real base address + 128 MiB offset which is 0x88000000.
Acked-by: Jon Mason <jon.mason@broadcom.com>
It was tested by LEDE users, all we need is to adjust clock frequency.
While we're at it create a separated DTS include file to share code with
other BCM4709 devices easier.
The NAND flash chip description were not imported for the Asus RT-AC87U
dts file when this was done for all the other dts files, because these
patches were send in parallel.
This adds a missing NAND flash chip description to this patch:
commit 9faa5960eef3204cae6637b530f5e23e53b5a9ef
Author: Hauke Mehrtens <hauke@hauke-m.de>
Date: Fri May 29 23:39:47 2015 +0200
Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
Signed-off-by: Rafał Miłecki <zajec5@gmail.com>
Signed-off-by: Álvaro Fernández Rojas <noltari@gmail.com>
