During the removal of the skeleton.dtsi file with commit abe60a3a7afb
("ARM: dts: Kill off skeleton{64}.dtsi") a number of Broadcom SoCs were
converted, but a few were left unoticed, now causing boot failures with
v5.1 since the kernel cannot find suitable memory.
Updating the .dtsi files with the property will be done next, since
there are some memory nodes that do not follow the proper naming
convention and lack an unit name.
Fixes: abe60a3a7afb ("ARM: dts: Kill off skeleton{64}.dtsi")
Reported-by: Kevin Hilman <khilman@kernel.org>
Signed-off-by: Florian Fainelli <f.fainelli@gmail.com>
Currently, the USB 3.0 PHY in bcm5301x.dtsi uses platform driver which
requires register range "ccb-mii" <0x18003000 0x1000>. This range
overlaps with MDIO cmd and param registers (<0x18003000 0x8>).
Essentially, the platform driver partly acts like a MDIO bus driver,
hence to use of this register range.
In some Northstar devices like Linksys EA9500, secondary switch is
connected via external MDIO. The only way to access and configure the
external switch is via MDIO bus. When we enable the MDIO bus in it's
current state, the MDIO bus and any child buses fail to register because
of the register range overlap.
On Northstar, the USB 3.0 PHY is connected at address 0x10 on the
internal MDIO bus. This change moves the usb3_phy node and makes it a
child node of internal MDIO bus.
Thanks to Rafał Miłecki's commit af850e14a7ae ("phy: bcm-ns-usb3: add
MDIO driver using proper bus layer") the same USB 3.0 platform driver
can now act as USB 3.0 PHY MDIO driver.
Tested on Linksys Panamera (EA9500)
Signed-off-by: Vivek Unune <npcomplete13@gmail.com>
These files were created and ever touched by a group of three people
only: Dan, Hauke and me. They were licensed under GNU/GPL or ISC.
Introducing and discussing SPDX-License-Identifier resulted in a
conclusion that ISC is a not recommended license (see also a
license-rules.rst). Moveover an old e-mail from Alan Cox was pointed
which explained that dual licensing is a safer solution than depending
on a common compatibility belief.
This commit switches most of BCM5301X DTS files to dual licensing using:
1) GPL 2.0+ to make sure they are compatible with Linux kernel
2) MIT to allow sharing with more permissive projects
Both licenses belong to the preferred ones (see LICENSES/preferred/).
An attempt to relicense remaining files will be made separately and will
require approve from more/other developers.
Signed-off-by: Rafał Miłecki <rafal@milecki.pl>
Reviewed-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
Acked-by: Hauke Mehrtens <hauke@hauke-m.de>
Acked-by: Dan Haab <dan.haab@luxul.com>
It's tri-band wireless home router based on BCM4709A0 with 3 x BCM43602
chipsets. LEDs will be hopefully added later to the DT.
