path: root/arch/arm/boot/dts/bcm4709-netgear-r8000.dts
2017-03-09ARM: dts: BCM5301X: Don't use nonexistent "default-off" LED triggerRafał Miłecki
Such a trigger doesn't exist in Linux and is not needed as LED is being turned off by default. This could cause errors in LEDs core code when trying to set default trigger. Signed-off-by: Rafał Miłecki <rafal@milecki.pl> Signed-off-by: Florian Fainelli <f.fainelli@gmail.com>
2017-03-06ARM: dts: BCM5301X: Add missing Netgear R8000 LEDs and KeysAditya Xavier
Added two WAN status LEDs and a GPIO key for brightness which were missing. Signed-off-by: Aditya Xavier <adityaxavier@gmail.com> Acked-by: Rafał Miłecki <rafal@milecki.pl> Signed-off-by: Florian Fainelli <f.fainelli@gmail.com>
2017-03-06ARM: dts: BCM5301X: Relicense DTS files I created to the ISCRafał Miłecki
It's preferred to have DT source files licensed under BSD compatible license. All new BCM5301X DTS files use ISC so let's also relicense old ones to it. Except for me only Hauke was ever touched these files in his commit 9faa5960eef3 ("ARM: BCM5301X: add NAND flash chip description") and commit bb1d8fba1965 ("ARM: BCM5301X: add NAND flash chip description for Asus RT-AC87U"). Signed-off-by: Rafał Miłecki <rafal@milecki.pl> Acked-by: Hauke Mehrtens <hauke@hauke-m.de> Signed-off-by: Florian Fainelli <f.fainelli@gmail.com>
2017-01-18ARM: dts: BCM5301X: Set 5 GHz wireless frequency limits on Netgear R8000Rafał Miłecki
Netgear R8000 is a tri-band home router. It has three BCM43602 chipsets two of them for 5 GHz band. Both seem the same and their firmwares report the same set of channels. The problem is due to hardware / board design there are extra limitations that should be respected. First PHY should be used for U-NII-2 and U-NII-3. Third PHY should be used for U-NII-1. Using them in a different way may result in wireless not working or in noticeably reduced performance. Basic version of this info was provided by Broadcom employee, then it has been verified by me using original vendor firmware (which has limitations hardcoded in UI). This patch uses recently introduced ieee80211-freq-limit property to describe these limitations at DT level. Referencing PCIe devices in DT required specifying all related bridges. Below you can see (a bit complex) PCI tree from R8000 that explains all entries that I needed to put in DT. 0000:00:00.0 14e4:8012 Bridge Device └─ 0000:01:00.0 14e4:aa52 Network Controller 0001:00:00.0 14e4:8012 Bridge Device └─ 0001:01:00.0 10b5:8603 Bridge Device ├─ 0001:02:01.0 10b5:8603 Bridge Device │ └─ 0001:03:00.0 14e4:aa52 Network Controller ├─ 0001:02:02.0 10b5:8603 Bridge Device │ └─ 0001:04:00.0 14e4:aa52 Network Controller ├─ 0001:02:03.0 000d:0000 0x000000 ├─ 0001:02:04.0 000d:0000 0x000000 ├─ 0001:02:05.0 000d:0000 0x000000 ├─ 0001:02:06.0 000d:0000 0x000000 ├─ (...) ├─ 0001:02:1d.0 000d:0000 0x000000 ├─ 0001:02:1e.0 000d:0000 0x000000 └─ 0001:02:1f.0 000d:0000 0x000000 Signed-off-by: Rafał Miłecki <rafal@milecki.pl> Signed-off-by: Florian Fainelli <f.fainelli@gmail.com>
2017-01-18ARM: dts: BCM5301X: Specify all RAM by including an extra blockRafał Miłecki
The first 128 MiB of RAM can be accessed using an alias at address 0x0. In theory we could access whole RAM using 0x80000000 - 0xbfffffff range (up to 1 GiB) but it doesn't seem to work on Northstar. For some reason (hardware setup left by the bootloader maybe?) 0x80000000 - 0x87ffffff range can't be used. I reproduced this problem on: 1) Buffalo WZR-600DHP2 (BCM47081) 2) Netgear R6250 (BCM4708) 3) D-Link DIR-885L (BCM47094) So it seems we're forced to access first 128 MiB using alias at 0x0 and the rest using real base address + 128 MiB offset which is 0x88000000. Signed-off-by: Rafał Miłecki <rafal@milecki.pl> Acked-by: Jon Mason <jon.mason@broadcom.com> Signed-off-by: Florian Fainelli <f.fainelli@gmail.com>
2017-01-18ARM: dts: BCM5301X: Enable UART by default for BCM4708(1), BCM4709(4) & BCM53012Rafał Miłecki
Every device tested so far got UART0 (at 0x18000300) working as serial console. It's most likely part of reference design and all vendors use it that way. It seems to be easier to enable it by default and just disable it if we ever see a device with different hardware design. Signed-off-by: Rafał Miłecki <rafal@milecki.pl> Acked-by: Jon Mason <jon.mason@broadcom.com> Acked-by: Hauke Mehrtens <hauke@hauke-m.de> Signed-off-by: Florian Fainelli <f.fainelli@gmail.com>
2016-10-19ARM: BCM5301X: Enable UART on Netgear R8000Rafał Miłecki
It was tested by LEDE users, all we need is to adjust clock frequency. While we're at it create a separated DTS include file to share code with other BCM4709 devices easier. Signed-off-by: Rafał Miłecki <rafal@milecki.pl> Signed-off-by: Florian Fainelli <f.fainelli@gmail.com>
2016-04-13ARM: BCM5301X: Set vcc-gpio for USB controllers of few devicesRafał Miłecki
There are few devices that have USB power controlled using GPIO. Linux USB host driver (bcma-hcd) already supports this by reading vcc-gpio from DT. Set it properly for all known devices. Signed-off-by: Rafał Miłecki <zajec5@gmail.com> Signed-off-by: Florian Fainelli <f.fainelli@gmail.com>
2015-12-06ARM: BCM5301X: Add missing Netgear R8000 LEDsRafał Miłecki
Add a bunch of LEDs missing for the Netgear R8000: wireless, wps, 5Ghz radio and USB LEDs. Signed-off-by: Rafał Miłecki <zajec5@gmail.com> Signed-off-by: Florian Fainelli <f.fainelli@gmail.com>
2015-06-06ARM: BCM5301X: add NAND flash chip descriptionHauke Mehrtens
This adds the NAND flash chip description for a standard chip found connected to this SoC. This makes use of generic Broadcom NAND driver with the iProc interface. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de> Signed-off-by: Florian Fainelli <f.fainelli@gmail.com>
2015-03-06ARM: BCM5301X: Add DT for Netgear R8000Rafał Miłecki
Signed-off-by: Rafał Miłecki <zajec5@gmail.com> Reported-by: Ian Kent <raven@themaw.net> Signed-off-by: Florian Fainelli <f.fainelli@gmail.com>
