path: root/arch/arm/boot/dts/bcm4709-netgear-r8000.dts
2016-04-13ARM: BCM5301X: Set vcc-gpio for USB controllers of few devicesRafał Miłecki
There are few devices that have USB power controlled using GPIO. Linux USB host driver (bcma-hcd) already supports this by reading vcc-gpio from DT. Set it properly for all known devices. Signed-off-by: Rafał Miłecki <zajec5@gmail.com> Signed-off-by: Florian Fainelli <f.fainelli@gmail.com>
2015-12-06ARM: BCM5301X: Add missing Netgear R8000 LEDsRafał Miłecki
Add a bunch of LEDs missing for the Netgear R8000: wireless, wps, 5Ghz radio and USB LEDs. Signed-off-by: Rafał Miłecki <zajec5@gmail.com> Signed-off-by: Florian Fainelli <f.fainelli@gmail.com>
2015-06-06ARM: BCM5301X: add NAND flash chip descriptionHauke Mehrtens
This adds the NAND flash chip description for a standard chip found connected to this SoC. This makes use of generic Broadcom NAND driver with the iProc interface. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de> Signed-off-by: Florian Fainelli <f.fainelli@gmail.com>
2015-03-06ARM: BCM5301X: Add DT for Netgear R8000Rafał Miłecki
Signed-off-by: Rafał Miłecki <zajec5@gmail.com> Reported-by: Ian Kent <raven@themaw.net> Signed-off-by: Florian Fainelli <f.fainelli@gmail.com>
