2016-07-06 | ARM: BCM5301X: Specify NAND chip select and ECC in separated files | Rafał Miłecki | |
Using separated file with common chip select parameters will allow us adding other ECC setups without code duplication. Signed-off-by: Rafał Miłecki <zajec5@gmail.com> Signed-off-by: Florian Fainelli <f.fainelli@gmail.com> |
