path: root/arch/arm/boot/dts/bcm94708.dts
2015-11-16ARM: dts: bcm5301x: Add BCM SVK DT filesJon Mason
Add device tree files for Broadcom Northstar based SVKs. Since the bcm5301x.dtsi already exists, all that is necessary is the dts files to enable the UARTs. With these files, the SVKs are able to boot to shell. Signed-off-by: Jon Mason <jonmason@broadcom.com> Signed-off-by: Florian Fainelli <f.fainelli@gmail.com>
