path: root/arch/arm/boot/dts/bcm958623hr.dts
2018-02-03ARM: dts: NSP: Disable AHCI controller for HR NSP boardsFlorian Fainelli
[ Upstream commit 77416ab35f5712382e5a792bfa1736ceb70d5bbb ] The AHCI controller is currently enabled for all of these boards: bcm958623hr and bcm958625hr would result in a hard hang on boot that we cannot get rid of. Since this does not appear to have an easy and simple fix, just disable the AHCI controller for now until this gets resolved. Fixes: 70725d6e97ac ("ARM: dts: NSP: Enable SATA on bcm958625hr") Fixes: d454c3762437 ("ARM: dts: NSP: Add new DT file for bcm958623hr") Acked-by: Jon Mason <jon.mason@broadcom.com> Signed-off-by: Florian Fainelli <f.fainelli@gmail.com> Signed-off-by: Sasha Levin <alexander.levin@verizon.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-08-07ARM: dts: NSP: Add USB3 and USB3 PHY to NSPJon Mason
This uses the existing Northstar USB3 PHY driver to enable the USB3 ports on NSP. Signed-off-by: Jon Mason <jon.mason@broadcom.com> Signed-off-by: Florian Fainelli <f.fainelli@gmail.com>
2017-05-09Merge tag 'armsoc-dt' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM Device-tree updates from Olof Johansson: "Device-tree continues to see lots of updates. The majority of patches here are smaller changes for new hardware on existing platforms, and there are a few larger changes worth pointing out. Major new platforms: - Gemini has been ported to DT, so a handful of "new" platforms moved over from board files - Rockchip RK3288 support for Tinkerboard and Phytec phyCORE-RK3288 SoM and RDK - A bunch of embedded platforms, several Linksys platforms, Synology DS116, - Motorola Droid4 (really old OMAP-based phone) support is added. Some refactorings, i.e. Allwinner H3/H5 support is commonalized. And lots of smaller changes, cleanups, etc. See shortlog for more description We're adding ability to cross-include DT files between arm and arm64, by creating appropriate links in the dt-include directory, and using arm/ and arm64/ as include prefixes. This will avoid other local hacks such as per-file links between the two arch trees (this broke for external mirroring of DT contents). Now they can just provide their own appropriate dt-include hierarcy per platform" * tag 'armsoc-dt' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (349 commits) ARM: dts: exynos: Use - instead of @ for DT OPP entries arm: spear6xx: add DT description of the ADC on SPEAr600 arm: spear6xx: remove unneeded pinctrl properties in spear600-evb arm: spear6xx: switch spear600-evb to the new flash partition DT binding arm: spear6xx: fix spaces in spear600-evb.dts arm: spear6xx: use node labels in spear600-evb.dts arm: spear6xx: add labels to various nodes in spear600.dtsi ARM: dts: vexpress: fix few unit address format warnings ARM: dts: at91: sama5d3_xplained: not all ADC channels are available ARM: dts: at91: sama5d3_xplained: fix ADC vref ARM: dts: at91: add envelope detector mux to the Axentia TSE-850 ARM: dts: armada-38x: label USB and SATA nodes ARM: dts: imx6q-utilite-pro: add hpd gpio ARM: dts: imx6qp-sabresd: Set reg_arm regulator supply ARM: dts: imx6qdl-sabresd: Set LDO regulator supply ARM: dts: imx: add Gateworks Ventana GW5903 support ARM: dts: i.MX25: add AIPS control registers ARM: dts: imx7-colibri: add Carrier Board 3.3V/5V regulators ARM: dts: imx7-colibri: remove 1.8V fixed regulator ARM: dts: imx7-colibri: allow to disable Ethernet rail ...
2017-03-18ARM: dts: NSP: Add EHCI/OHCI USB nodes to device treeJon Mason
Add the EHCI and OHCI entries to the Northstar Plus device tree files. Signed-off-by: Yendapally Reddy Dhananjaya Reddy <yendapally.reddy@broadcom.com> Signed-off-by: Jon Mason <jon.mason@broadcom.com> Signed-off-by: Florian Fainelli <f.fainelli@gmail.com>
2017-03-16ARM: dts: NSP: GPIO reboot open-sourceJon Mason
The libgpio code pre-sets the GPIO values for the gpio-reset in the device tree. This results in the device being reset during bringup. To prevent this pre-setting, use the "open-source" flag in the device tree. Signed-off-by: Jon Mason <jon.mason@broadcom.com> Fixes: b1aaf88 ("ARM: dts: NSP: Add GPIO reboot method to bcm958625hr DTS file") Fixes: 10baed1 ("ARM: dts: NSP: Add GPIO reboot method to bcm958625xmc DTS file") Fixes: 088e3148 ("ARM: dts: NSP: Add new DT file for bcm958522er") Fixes: e3227c1 ("ARM: dts: NSP: Add new DT file for bcm958525er") Fixes: 2f8bc00 ("ARM: dts: NSP: Add new DT file for bcm958622hr") Fixes: d454c37 ("ARM: dts: NSP: Add new DT file for bcm958623hr") Fixes: f27eacf ("ARM: dts: NSP: Add new DT file for bcm988312hr") Signed-off-by: Florian Fainelli <f.fainelli@gmail.com>
2017-01-18ARM: dts: NSP: Add and enable amac2Jon Mason
Add and enable the third AMAC ethernet interface in the device trees for the platforms where it is present. Also, enable amac1 on some of the platforms where that was missing. Signed-off-by: Jon Mason <jon.mason@broadcom.com> Signed-off-by: Florian Fainelli <f.fainelli@gmail.com>
2017-01-18ARM: dts: NSP: Add QSPI support to missing boardsJon Mason
QSPI device tree entries are present in bcm958625k, but missing from bcm958522er, bcm958525er, bcm958525xmc, bcm958622hr, bcm958623hr, bcm958625hr, and bcm988312hr. Duplicate the entry in bcm958625k for all of those that are missing it (as they are identical). Signed-off-by: Jon Mason <jon.mason@broadcom.com> Signed-off-by: Florian Fainelli <f.fainelli@gmail.com>
2017-01-18ARM: dts: NSP: DT Clean-upsJon Mason
The QSPI entry was added out of the sequental order that the rest of the DTSI file is in. Move it to make it fit in properly. Also, some other entries have been added in a non-alphabetical order in the DTS files, making them different from the other NSP DTS files. Move the relevant peices to make it match. Finally, remove errant new lines. Signed-off-by: Jon Mason <jon.mason@broadcom.com> Signed-off-by: Florian Fainelli <f.fainelli@gmail.com>
2016-08-08ARM: dts: NSP: Add new DT file for bcm958623hrJon Mason
Create a new device tree file for the Broadcom Northstar Plus bcm958623hr SVK. This SVK has 2GB RAM, 5 ports Ethernet, SATA, 2 PCI slots, and 1 UART. Also, it has the ability to reboot via GPIO. To be added in the future are support for the USB and SLIC audio. Signed-off-by: Jon Mason <jon.mason@broadcom.com> Signed-off-by: Florian Fainelli <f.fainelli@gmail.com>
