Add 2GB of memory starting at physical offset 0x6000_0000.
Signed-off-by: Jon Mason <jon.mason@broadcom.com>
Signed-off-by: Florian Fainelli <f.fainelli@gmail.com>
Add Device Tree entries for the Ethernet devices (AMAC) present on the Broadcom
Northstar Plus SoCs.
Add sata support to the Northstar Plus SoC device tree.
Signed-off-by: Yendapally Reddy Dhananjaya Reddy <yendapally.reddy@broadcom.com>
Acked-by: Florian Fainelli <f.fainelli@gmail.com>
This enables the pinctrl support for Broadcom NSP SoC
Signed-off-by: Yendapally Reddy Dhananjaya Reddy <yrdreddy@broadcom.com>
Add NAND support to the device tree for the Broadcom Northstar Plus SoC.
Since no driver changes are needed to enable this hardware, only the
device tree changes are required to make this functional.
Signed-off-by: Jon Mason <jonmason@broadcom.com>
Add PCI support to the Northstar Plus SoC. This uses the existing
pcie-iproc driver. So, all that is needed is device tree entries in the
DTS.
Add a very minimalistic set of Northstar Plus Device Tree files which
describes the SoC and the BCM958625 implementation. The perpherials
described are:
ARM Cortex A9 CPU
2 8250 UARTs
ARM GIC
PL310 L2 Cache
ARM A9 Global timer
Signed-off-by: Kapil Hali <kapilh@broadcom.com>
Reviewed-by: Ray Jui <rjui@broadcom.com>
