path: root/arch/arm/boot/dts/berlin2.dtsi
2016-09-28ARM: dts: berlin2: Add missing unit name to /soc nodeJisheng Zhang
This patch fixes the following DTC warning with W=1: "Node /soc has a reg or ranges property, but no unit name" Signed-off-by: Jisheng Zhang <jszhang@marvell.com> Signed-off-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com>
2016-09-28ARM: dts: berlin2: Remove skeleton.dtsi inclusionJisheng Zhang
As noted in [1], "there are a number of problems with skeleton.dtsi, and it would be prefereable to remove it entirely." This patch is to remove skeleton.dtsi inclusion from berlin2. [1] http://www.spinics.net/lists/arm-kernel/msg528080.html Signed-off-by: Jisheng Zhang <jszhang@marvell.com> Signed-off-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com>
2016-09-28arm: dts: berlin2: enable all wdt nodes unconditionallyJisheng Zhang
After commit f29a72c24ad4 ("watchdog: dw_wdt: Convert to use watchdog infrastructure"), the dw_wdt driver can support multiple variants, so unconditionally enable all dw_wdt nodes now. Signed-off-by: Jisheng Zhang <jszhang@marvell.com> Signed-off-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com>
2015-11-28arm: dts: berlin2: add watchdog nodesJisheng Zhang
The Marvell Berlin BG2 has 3 watchdogs which are compatible with the snps,dw-wdt driver sit in the sysmgr domain. This patch adds the corresponding device tree nodes. Signed-off-by: Jisheng Zhang <jszhang@marvell.com> Signed-off-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com>
2015-10-05ARM: berlin: add a PWM node on the BG2Antoine Tenart
This patch adds a PWM node in the Berlin BG2 device tree, using the newly added Berlin PWM driver. Signed-off-by: Antoine Tenart <antoine.tenart@free-electrons.com> Signed-off-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com>
2015-09-21ARM: berlin: dts: add the cpufreq-dt bindings on the BG2Antoine Tenart
The BG2 uses cpugreq-dt. Add the corresponding bindings. Signed-off-by: Antoine Tenart <antoine.tenart@free-electrons.com> Signed-off-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com>
2015-09-20arm: dts: berlin: add aliases for serialJisheng Zhang
This is to prepare for the using stdout-path in next commit. Signed-off-by: Jisheng Zhang <jszhang@marvell.com> Signed-off-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com>
2015-06-26Merge tag 'armsoc-drivers' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC driver updates from Kevin Hilman: "Some of these are for drivers/soc, where we're now putting SoC-specific drivers these days. Some are for other driver subsystems where we have received acks from the appropriate maintainers. Some highlights: - simple-mfd: document DT bindings and misc updates - migrate mach-berlin to simple-mfd for clock, pinctrl and reset - memory: support for Tegra132 SoC - memory: introduce tegra EMC driver for scaling memory frequency - misc. updates for ARM CCI and CCN busses" * tag 'armsoc-drivers' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (48 commits) drivers: soc: sunxi: Introduce SoC driver to map SRAMs arm-cci: Add aliases for PMU events arm-cci: Add CCI-500 PMU support arm-cci: Sanitise CCI400 PMU driver specific code arm-cci: Abstract handling for CCI events arm-cci: Abstract out the PMU counter details arm-cci: Cleanup PMU driver code arm-cci: Do not enable CCI-400 PMU by default firmware: qcom: scm: Add HDCP Support ARM: berlin: add an ADC node for the BG2Q ARM: berlin: remove useless chip and system ctrl compatibles clk: berlin: drop direct of_iomap of nodes reg property ARM: berlin: move BG2Q clock node ARM: berlin: move BG2CD clock node ARM: berlin: move BG2 clock node clk: berlin: prepare simple-mfd conversion pinctrl: berlin: drop SoC stub provided regmap ARM: berlin: move pinctrl to simple-mfd nodes pinctrl: berlin: prepare to use regmap provided by syscon reset: berlin: drop arch_initcall initialization ...
2015-05-18ARM: berlin: remove useless chip and system ctrl compatiblesAntoine Tenart
Now that the rework to have one sub-node per device in the chip and system controllers is done, their dedicated compatible can be removed. Signed-off-by: Antoine Tenart <antoine.tenart@free-electrons.com> Signed-off-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com>
2015-05-18ARM: berlin: move BG2 clock nodeAntoine Tenart
With the introduction of the Berlin simple-mfd controller driver, all drivers previously sharing the chip and system controller nodes now have their own sub-node. Signed-off-by: Antoine Tenart <antoine.tenart@free-electrons.com> Signed-off-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com>
2015-05-18ARM: berlin: move pinctrl to simple-mfd nodesAntoine Tenart
Now with proper support for simple-mfd probed pinctrl driver, move to the new soc-pinctrl and system-pinctrl nodes. Signed-off-by: Antoine Tenart <antoine.tenart@free-electrons.com> Signed-off-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com>
2015-05-18ARM: berlin: move reset to simple-mfd nodesAntoine Tenart
Now with a proper platform driver for reset and simple-mfd, move to the new marvell,berlin-reset node. Signed-off-by: Antoine Tenart <antoine.tenart@free-electrons.com> Signed-off-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com>
2015-05-18ARM: berlin: prepare simple-mfd/syscon conversion of sys/chip ctrl nodesAntoine Tenart
The chip and system controller nodes will be handled by simple-mfd based driver probing. Prepare the conversion by adding "simple-mfd" and "syscon" compatibles to the corresponding nodes. Signed-off-by: Antoine Tenart <antoine.tenart@free-electrons.com> Signed-off-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com>
2015-05-16ARM: dts: berlin: relicense the berlin2 dtsi under GPLv2/X11Antoine Tenart
The current GPLv2 only licensing on this dtsi makes it very impractical for other software components licensed under another license. In order to make it easier for them to reuse our device trees, relicense this dtsi under a GPLv2/X11 dual-license. Signed-off-by: Antoine Tenart <antoine.tenart@free-electrons.com> Acked-by: Jisheng Zhang <jszhang@marvell.com> Signed-off-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com>
2015-01-07ARM: dts: berlin: add PPI cpu mask to twd timer interruptsJisheng Zhang
According to the gic binding document, "bits[15:8] PPI interrupt cpu mask. Each bit corresponds to each of the 8 possible cpus attached to the GIC. A bit set to '1' indicated the interrupt is wired to that CPU." This patch wants to add the PPI cpu mask for completeness. Signed-off-by: Jisheng Zhang <jszhang@marvell.com> Signed-off-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com>
2014-11-12ARM: berlin: Add AHCI and SATA PHY nodes to BG2Sebastian Hesselbarth
Add DT nodes for the AHCI controller and SATA PHY found on Marvell Berlin2 SoCs. Acked-by: Antoine Ténart <antoine.tenart@free-electrons.com> Signed-off-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com>
2014-10-29ARM: dts: berlin: Add SDHCI controller nodes to BG2/BG2CDSebastian Hesselbarth
Marvell Berlin BG2 has three, BG2CD just one pxav3 compatible sdhci controllers, add them to the corresponding DT SoC includes. Signed-off-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com>
2014-10-29ARM: dts: berlin: Add BG2 ethernet DT nodesSebastian Hesselbarth
Marvell BG2 has two fast ethernet controllers with internal PHY, add the corresponding nodes to SoC dtsi. Tested-by: Antoine Ténart <antoine.tenart@free-electrons.com> Reviewed-by: Florian Fainelli <f.fainelli@gmail.com> Signed-off-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com>
2014-10-29ARM: dts: berlin: add a required reset property in the chip controller nodeAntoine Ténart
The chip controller node now also describes the Marvell Berlin reset controller. Add the required 'reset-cells' property. Signed-off-by: Antoine Ténart <antoine.tenart@free-electrons.com> Acked-by: Philipp Zabel <p.zabel@pengutronix.de> Signed-off-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com>
2014-06-16ARM: dts: berlin: add SMP related nodes and properties for BG2Antoine Ténart
Add required nodes and properties into the Berlin BG2 device tree to take advantage of the newly introduced SMP support. Add the scu and cpu-ctrl nodes along with the CPUs enable-method property. Signed-off-by: Antoine Ténart <antoine.tenart@free-electrons.com> Signed-off-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com>
2014-05-19ARM: dts: berlin: add the pinctrl node and muxing setup for uartsAntoine Tenart
Add pinctrl bindings and system control nodes to what we currently know about Berlin SoCs. Where available, also set default pinctrl property for uarts, when there is only one pinmux option for it. Signed-off-by: Antoine Tenart <antoine.tenart@free-electrons.com> Signed-off-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com>
2014-05-19ARM: dts: berlin: convert BG2 to DT clock nodesSebastian Hesselbarth
This converts Berlin BG2 SoC dtsi to make use of the new DT clock nodes for Berlin SoCs. While at it, also fix up twdclk which is running at cpuclk/3 instead of sysclk. Signed-off-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com>
2014-05-19ARM: dts: berlin: add the BG2 GPIO nodesAntoine Tenart
The Berlin BG2 has 32 GPIOs in SoC power domain and 16 in the SM one. Only the first 8 SM GPIOs have interrupt support. Signed-off-by: Antoine Tenart <antoine.tenart@free-electrons.com> Signed-off-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com>
2014-05-19ARM: dts: berlin: add scu and chipctrl device nodes for BG2/BG2QSebastian Hesselbarth
This adds scu and general purpose registers device nodes required for SMP on Berlin BG2 and BG2Q SoCs. The secondary CPUs will pick their jump address from general purpose (SW generic) register 1. Signed-off-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com> Acked-by: Alexandre Belloni <alexandre.belloni@free-electrons.com> Acked-by: Antoine Tenart <antoine.tenart@free-electrons.com> Acked-by: Jisheng Zhang <jszhang@marvell.com> Tested-by: Antoine Tenart <antoine.tenart@free-electrons.com>
2013-12-13ARM: add Armada 1500 and Sony NSZ-GS7 device tree filesSebastian Hesselbarth
This adds very basic device tree files for the Marvell Armada 1500 SoC (Berlin BG2) and the Sony NSZ-GS7 GoogleTV board. Currently, SoC only has nodes for cpus, some clocks, l2 cache controller, local timer, apb timers, uart, and interrupt controllers. The Sony NSZ-GS7 is a GoogleTV consumer device comprising the Armada 1500 SoC above. Signed-off-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com> Reviewed-by: Jason Cooper <jason@lakedaemon.net> Reviewed-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Reviewed-by: Arnd Bergmann <arnd@arndb.de> Reviewed-by: Jisheng Zhang <jszhang@marvell.com>
