This patch fixes the following DTC warning with W=1:
"Node /memory has a reg or ranges property, but no unit name"
Signed-off-by: Jisheng Zhang <jszhang@marvell.com>
Signed-off-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com>
Use stdout-path to specify the console and remove the console argument
from the kernel command line.
The current GPLv2 only licensing on this dts makes it very impractical
for other software components licensed under another license.
In order to make it easier for them to reuse our device trees, relicense
this dts under a GPLv2/X11 dual-license.
Signed-off-by: Antoine Tenart <antoine.tenart@free-electrons.com>
Enable usb1 on Google Chromecast which is connected to micro-USB
plug used for external power supply, too.
With SDHCI for BG2CD, we can now enable the port and allow to access
AzureWave WiFi/BT module on Google Chromecast.
With GPIO support for Marvell Berlin, now add the two gpio-connected
LEDs on Google Chromecast.
This adds very basic device tree files for the Marvell Armada
1500-mini SoC (Berlin BG2CD) and the Google Chromecast. Currently,
SoC only has nodes for cpu, some clocks, l2 cache controller, local
timer, apb timers, uart, and interrupt controllers.
The Google Chromecast is a consumer device comprising the Armada
1500-mini SoC above.
