This patch adds a PWM node in the Berlin BG2CD device tree, using the
newly added Berlin PWM driver.
Signed-off-by: Antoine Tenart <antoine.tenart@free-electrons.com>
Signed-off-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com>
The BG2CD uses cpugreq-dt. Add the corresponding bindings.
This is to prepare for the using stdout-path in next commit.
Signed-off-by: Jisheng Zhang <jszhang@marvell.com>
Pull ARM SoC driver updates from Kevin Hilman:
"Some of these are for drivers/soc, where we're now putting
SoC-specific drivers these days. Some are for other driver subsystems
where we have received acks from the appropriate maintainers.
Some highlights:
- simple-mfd: document DT bindings and misc updates
- migrate mach-berlin to simple-mfd for clock, pinctrl and reset
- memory: support for Tegra132 SoC
- memory: introduce tegra EMC driver for scaling memory frequency
- misc. updates for ARM CCI and CCN busses"
* tag 'armsoc-drivers' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (48 commits)
drivers: soc: sunxi: Introduce SoC driver to map SRAMs
arm-cci: Add aliases for PMU events
arm-cci: Add CCI-500 PMU support
arm-cci: Sanitise CCI400 PMU driver specific code
arm-cci: Abstract handling for CCI events
arm-cci: Abstract out the PMU counter details
arm-cci: Cleanup PMU driver code
arm-cci: Do not enable CCI-400 PMU by default
firmware: qcom: scm: Add HDCP Support
ARM: berlin: add an ADC node for the BG2Q
ARM: berlin: remove useless chip and system ctrl compatibles
clk: berlin: drop direct of_iomap of nodes reg property
ARM: berlin: move BG2Q clock node
ARM: berlin: move BG2CD clock node
ARM: berlin: move BG2 clock node
clk: berlin: prepare simple-mfd conversion
pinctrl: berlin: drop SoC stub provided regmap
ARM: berlin: move pinctrl to simple-mfd nodes
pinctrl: berlin: prepare to use regmap provided by syscon
reset: berlin: drop arch_initcall initialization
Now that the rework to have one sub-node per device in the chip and
system controllers is done, their dedicated compatible can be removed.
With the introduction of the Berlin simple-mfd controller driver, all
drivers previously sharing the chip and system controller nodes now
have their own sub-node.
Now with proper support for simple-mfd probed pinctrl driver, move
to the new soc-pinctrl and system-pinctrl nodes.
Now with a proper platform driver for reset and simple-mfd, move to
the new marvell,berlin-reset node.
The chip and system controller nodes will be handled by simple-mfd based
driver probing. Prepare the conversion by adding "simple-mfd" and "syscon"
compatibles to the corresponding nodes.
The current GPLv2 only licensing on this dtsi makes it very impractical
for other software components licensed under another license.
In order to make it easier for them to reuse our device trees, relicense
this dtsi under a GPLv2/X11 dual-license.
Acked-by: Jisheng Zhang <jszhang@marvell.com>
According to the gic binding document, "bits[15:8] PPI interrupt cpu
mask. Each bit corresponds to each of the 8 possible cpus attached to
the GIC. A bit set to '1' indicated the interrupt is wired to that
CPU." This patch wants to add the PPI cpu mask for completeness.
This patch adds the pmu node, enabling the PMU unit on Marvell BG2Q and
BG2CD SoCs.
Adds nodes describing the Marvell Berlin BG2CD USB PHY and USB. The BG2CD
SoC has 2 USB ChipIdea controllers, with usb0 host-only and usb1 dual-role
capable.
Marvell Berlin BG2 has three, BG2CD just one pxav3 compatible
sdhci controllers, add them to the corresponding DT SoC
includes.
Marvell BG2CD has two fast ethernet controllers with internal PHY,
add the corresponding nodes to SoC dtsi.
Tested-by: Antoine Ténart <antoine.tenart@free-electrons.com>
Reviewed-by: Florian Fainelli <f.fainelli@gmail.com>
The chip controller node now also describes the Marvell Berlin reset
controller. Add the required 'reset-cells' property.
Signed-off-by: Antoine Ténart <antoine.tenart@free-electrons.com>
Acked-by: Philipp Zabel <p.zabel@pengutronix.de>
Add pinctrl bindings and system control nodes to what we currently know
about Berlin SoCs. Where available, also set default pinctrl property
for uarts, when there is only one pinmux option for it.
This converts Berlin BG2CD SoC dtsi to make use of the new DT clock
nodes for Berlin SoCs. Also add a binding include to ease core clock
references.
The Berlin BG2CD has 32 GPIOs in SoC power domain and 16 in the SM one.
This adds very basic device tree files for the Marvell Armada
1500-mini SoC (Berlin BG2CD) and the Google Chromecast. Currently,
SoC only has nodes for cpu, some clocks, l2 cache controller, local
timer, apb timers, uart, and interrupt controllers.
The Google Chromecast is a consumer device comprising the Armada
1500-mini SoC above.
