This patch fixes the following DTC warning with W=1:
"Node /memory has a reg or ranges property, but no unit name"
Signed-off-by: Jisheng Zhang <jszhang@marvell.com>
Signed-off-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com>
The sdhci1 on Marvell BG2Q DMP board is used as sdcard interface, we
have gpios for card detection, write-protect, vqmmc and vmmc.
This patch adds pinmux for this sdcard interface, then adds regulators
for vmmc and vqmmc, lastly adds cd-gpios, wp-gpios properties.
The eMMC is non-removable so is marked with the non-removable DT
property to avoid having to redetect it after a suspend/resume.
But it also has the broken-cd property which is wrong since only
one of the DT properties for card detection should be used
Use stdout-path to specify the console and remove the console argument
from the kernel command line.
The current GPLv2 only licensing on this dts makes it very impractical
for other software components licensed under another license.
In order to make it easier for them to reuse our device trees, relicense
this dts under a GPLv2/X11 dual-license.
Signed-off-by: Antoine Tenart <antoine.tenart@free-electrons.com>
Acked-by: Jisheng Zhang <jszhang@marvell.com>
There's no card detection for the eMMC, so this patch adds the missing
broken-cd property. This patch also sets bus width as 8 to add
MMC_CAP_8_BIT_DATA in the Host capabilities.
Cc: stable@vger.kernel.org # 3.16+
Fixes: 3047086dfd56 ("ARM: dts: berlin: enable SD card reader and eMMC for the BG2Q DMP")
Enable the 2 available USB PHY and USB nodes on the Marvell Berlin BG2Q
DMP.
The BG2Q has an AHCI SATA controller with an eSATA interface. Enable it.
Only enable the first port, the BG2Q DMP does not support the second one.
Signed-off-by: Antoine Ténart <antoine.tenart@free-electrons.com>
This patch enables the Ethernet port on the Marvell Berlin2Q DMP board.
Enable the I2C0 and I2C2 for the Marvell Berlin BG2G DMP. I2C1 and I2C3
are also working on this board, but no devices seemed to be there.
Reviewed-by: Andrew Lunn <andrew@lunn.ch>
Enable the SD Card reader and the internal eMMC on the Berlin BG2Q DMP
using two of the SDHCI nodes of the Berlin BG2Q.
Adds initial support for the Marvell BG2-Q DMP. The board has 2GB of
memory, an uart activated and what's initially supported by the Marvell
Armada 1500 pro dtsi.
