Pull ARM SoC non-critical fixes from Olof Johansson:
"Here is a collection of fixes (and some intermixed cleanups) that were
considered less important and thus not included in the later parts of
the 3.9-rc cycle.
It's a bit all over the map, contents wise. A series of ux500 fixes
and cleanups, a bunch of various fixes for OMAP and tegra, and some
for Freescale i.MX and even Qualcomm MSM.
Note that there's also a patch on this branch to globally turn off
-Wmaybe-uninitialized when building with -Os. It's been posted
several times by Arnd and no dissent was raised, but nobody seemed
interested to pick it up. So here it is, as the topmost patch."
* tag 'fixes-nc-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (70 commits)
Turn off -Wmaybe-uninitialized when building with -Os
ARM: orion5x: include linux/cpu.h
ARM: tegra: call cpu_do_idle from C code
ARM: u300: fix ages old copy/paste bug
ARM: OMAP2+: add dependencies on ARCH_MULTI_V6/V7
ARM: tegra: solve adr range issue with THUMB2_KERNEL enabled
ARM: tegra: fix relocation truncated error when THUMB2_KERNEL enabled
ARM: tegra: fix build error when THUMB2_KERNEL enabled
ARM: msm: Fix uncompess.h tx underrun check
ARM: vexpress: Remove A9 PMU compatible values for non-A9 platforms
ARM: cpuimx27 and mbimx27: prepend CONFIG_ to Kconfig macro
ARM: OMAP2+: fix typo "CONFIG_BRIDGE_DVFS"
ARM: OMAP1: remove "config MACH_OMAP_HTCWIZARD"
ARM: mach-imx: mach-imx6q: Fix sparse warnings
ARM: mach-imx: src: Include "common.h
ARM: mach-imx: gpc: Include "common.h"
ARM: mach-imx: avic: Staticize *avic_base
ARM: mach-imx: tzic: Staticize *tzic_base
ARM: mach-imx: clk: Include "clk.h"
ARM: mach-imx: clk-busy: Staticize clk_busy_mux_ops
git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap into next/fixes-non-critical
From Tony Lindgren <tony@atomide.com>:
Non critical omap fixes for v3.10 merge window. A big chunk
of these fixes are needed to support omap5 es2 version that includes
PM features while the earlier version es1 did not.
* tag 'omap-for-v3.10/fixes-non-critical-signed' of git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap:
ARM: OMAP: dpll: enable bypass clock only when attempting dpll bypass
ARM: OMAP2+: powerdomain: avoid testing whether an unsigned char is less than 0
ARM: OMAP2+: hwmod: Remove unused _HWMOD_WAKEUP_ENABLED flag
ARM: OMAP2+: am335x: Change the wdt1 func clk src to per_32k clk
ARM: OMAP2+: AM33xx: hwmod: Add missing sysc definition to wdt1 entry
Contains an update to 3.9-rc5
This fixes a regression introduced by commit:
05ec260 mfd:db8500-prcmu: update resource passing
All DBx5x0 based SoCs have access to two Tightly Coupled Memory
(TCM) locations based on the PRCMU itself. One area from program
memory (TCPM) and one for data memory (TCDM). The PRCMU needs to
know where these are in order to function correctly. However,
these are currently passed though platform device resources, which
can only be obtained if Device Tree booting isn't in use. Thus we
must also support them in DT by supplying them through the PRCMU
node.
Signed-off-by: Lee Jones <lee.jones@linaro.org>
The ab8500 device is a child of the prcmu device, which is a memory mapped
bus device, whose children are addressable using physical memory addresses,
not using mailboxes, so a mailbox number in the ab8500 node cannot be
parsed by DT. Nothing uses this number, since it was only introduced
as part of the failed attempt to clean up prcmu mailbox handling, and
we can simply remove it.
The GPIO controlled MMCI regulator used on the ux5x0 boards takes
100us to settle. There's already a binding to provide such
information. Let's make use of it.
If not specified, the GPIO control bit is inverted by default i.e.
low-enable and high-disable. This is not the case with the MMCI
regulator, hence it will turn on during a disable and off when
regulator_enable() is invoked.
Correct the voltage specified by the mmci regulator node in Device
Tree. Despite the MMC subsystem insisting on v3.3, we actually only
offer v2.9, and not v2.6 which must have actually been a typo.
Currently we only include the PRCMU's primary registers when
referencing the register count in the 'reg' property. This patch
expands that count to include the secure registers also.
The preference is to use '-' instead of '_' in compatible strings.
The AB8500 Pinctrl driver uses PRCMU register addresses to
control Pinctrl related functions. For this to happen, the
Pinctrl driver needs the PRCMU base to work from. We can do
that using standard Open Firmware (of_*) function calls, but
first we need a mechanism to gain access to the PRCMU
device node. We're going to use a Phandle in this case.
[Added reg-names="prcmu"; to the prcmu DT node]
Current nmk_pinctrl driver is not PRCMU dependent anymore, so it needs
its own DT address resources to work properly, as done for
platform_device in:
f482833 ARM: ux500: add PRCM register base for pinctrl
Signed-off-by: Fabio Baltieri <fabio.baltieri@linaro.org>
Pull battery subsystem updates from Anton Vorontsov:
"Highlights:
- Two new drivers from Pali Rohár and N900 hackers: rx51_battery and
bq2415x_charger. The drivers are a part of a solution to replace
the proprietary Nokia BME stack
- Power supply core now registers devices with a thermal cooling
subsystem, so we can now automatically throttle charging. Thanks
to Ramakrishna Pallala!
- Device tree support for ab8500 and max8925_power drivers
- Random fixups and enhancements for a bunch of drivers."
* tag 'for-v3.8-merged' of git://git.infradead.org/battery-2.6: (22 commits)
max8925_power: Add support for device-tree initialization
ab8500: Add devicetree support for chargalg
ab8500: Add devicetree support for charger
ab8500: Add devicetree support for btemp
ab8500: Add devicetree support for fuelgauge
twl4030_charger: Change TWL4030_MODULE_* ids to TWL_MODULE_*
jz4740-battery: Use devm_request_and_ioremap
jz4740-battery: Use devm_kzalloc
bq27x00_battery: Fixup nominal available capacity reporting
bq2415x_charger: Fix style issues
bq2415x_charger: Add Kconfig/Makefile entries
power_supply: Add bq2415x charger driver
power_supply: Add new Nokia RX-51 (N900) power supply battery driver
max17042_battery: Fix missing verify_model_lock() return value check
ds2782_battery: Fix signedness bug in ds278x_read_reg16()
lp8788-charger: Fix ADC channel names
lp8788-charger: Fix wrong ADC conversion
lp8788-charger: Use consumer device name on setting IIO channels
power_supply: Register power supply for thermal cooling device
power_supply: Add support for CHARGE_CONTROL_* attributes
Pull ARM SoC device tree conversions and enablement from Olof Johansson:
"Continued device tree conversion and enablement across a number of
platforms; Kirkwood, tegra, i.MX, Exynos, zynq and a couple of other
smaller series as well.
ux500 has seen continued conversion for platforms. Several platforms
have seen pinctrl-via-devicetree conversions for simpler
multiplatform. Tegra is adding data for new devices/drivers, and
Exynos has a bunch of new bindings and devices added as well.
So, pretty much the same progression in the right direction as the
last few releases."
Fix up conflicts as per Olof.
* tag 'dt' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (185 commits)
ARM: ux500: Rename dbx500 cpufreq code to be more generic
ARM: dts: add missing ux500 device trees
ARM: ux500: Stop registering the PCM driver from platform code
ARM: ux500: Move board specific GPIO info out to subordinate DTS files
ARM: ux500: Disable the MMCI gpio-regulator by default
ARM: Kirkwood: remove kirkwood_ehci_init() from new boards
ARM: Kirkwood: Add support LED of OpenBlocks A6
ARM: Kirkwood: Convert to EHCI via DT for OpenBlocks A6
ARM: kirkwood: Add NAND partiton map for OpenBlocks A6
ARM: kirkwood: Add support second I2C bus and RTC on OpenBlocks A6
ARM: kirkwood: Add support DT of second I2C bus
ARM: kirkwood: Convert mplcec4 board to pinctrl
ARM: Kirkwood: Convert km_kirkwood to pinctrl
ARM: Kirkwood: support 98DX412x kirkwoods with pinctrl
ARM: Kirkwood: Convert IX2-200 to pinctrl.
ARM: Kirkwood: Convert lsxl boards to pinctrl.
ARM: Kirkwood: Convert ib62x0 to pinctrl.
ARM: Kirkwood: Convert GoFlex Net to pinctrl.
ARM: Kirkwood: Convert dreamplug to pinctrl.
ARM: Kirkwood: Convert dockstar to pinctrl.
GPIO numbers for the newly created gpio-regulator will differ from
board to board. Therefore it's not sensible to leave this information
in the top level DTSI file. Let's move them out to the DTS files
where they can correctly vary.
Not all supported boards will require a MMCI gpio-regulator,
therefore it's a good idea to only enable the node when and if
it is required. Let's disable it by default.
This patch adds device tree support for charging algorithm driver
Signed-off-by: Rajanikanth H.V <rajanikanth.hv@stericsson.com>
Signed-off-by: Anton Vorontsov <anton.vorontsov@linaro.org>
This patch adds device tree support for ab8500-charger driver
This patch adds device tree support for battery-temperature-monitor driver
- This patch adds device tree support for fuelgauge driver
- optimize bm devices platform_data usage and of_probe(...)
Note: of_probe() routine for battery managed devices is made
common across all bm drivers.
- test status:
- interrupt numbers assigned differs between legacy and FDT mode.
This patch adds device tree properties for ST-Ericsson DB8500 thermal driver,
also adds the platform data to support the old fashion.
Signed-off-by: hongbo.zhang <hongbo.zhang@linaro.com>
Reviewed-by: Viresh Kumar <viresh.kumar@linaro.org>
Signed-off-by: Zhang Rui <rui.zhang@intel.com>
There is a very simple mechanism to change and SDI's voltage which
consists of toggling some GPIOs. This scenario can be better handled
if we convert it to a GPIO regulator. This patch provides one which
can be read from Device Tree.
In the DB8500 Reference Manual SDI devices are described as being
part of peripheral blocks. This is more in line with how these devices
are actually represented in hardware, so here we detail which
peripheral block each of the SDI devices belong in the node name.
Requested-by: Linus Walleij <linus.walleij@linaro.org>
Regulator supply names should be allocated by board rather than
per SoC, as the same SoC could be wired differently on varying
hardware. Here we push all regulator-name allocation out to the
dbx5x0 subordinate board files; HREF and Snowball.
Requested-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
Here we fix a simple copy and paste error and bring some node
spaces back into line with the remainder of the tree.
Now the Nomadik I2C driver has been converted to an AMBA one, we
are required to provide the Primecell IDs via platform code. When
booting with DT enabled these have to be specified in the device
nodes. We do that here.
SSP won't probe unless the specified register address format
is correct i.e. we have to specify that the address is in hex.
After this patch has been applied, the SSP (SPI) driver probes
as expected.
This patch inserts all known MSP devices into the DBx5x0 Device Tree
disabled and enables the two important ones for the Snowball low-cost
development board.
Ensure correct probing and pass though important configuration
options to the AB8500 CODEC driver when DT is enabled
Since initial support was provided for the Nomadik I2C driver, it
has been converted to an AMBA device. AMBA devices are probed in
a slightly different way to other devices, so we have to identify
them using an "arm,primecell" compatible string. As well as doing
just that, this patch specifies which regulators the controller
should use and requests a clock-speed. The latter is provided as
more of an example, as it's the same as the recently changed
default configuration.
The compatible string found in the Power-On-Key's MFD cell matches
the device name provided in the driver. Keeping this naming convention
seems like a good idea, so we're changing the one found in the DTS
file to match.
It's understood that the AB8500 should be subordinate to the DB8500;
however, the AB8500 uses the GIC as it's interrupt controller. If
we do not specify which IRQ controller to use the default is to use
the next encountered IRQ controller as we climb the tree. This would
be the DB8500. This patch ensures the AB8500 makes use of the correct
We're just about to provide the DB8500-PRCMU with its own IRQ domain,
so that its subordinate drivers can use it as an interrupt controller.
It's obligatory for all IRQ controllers to reference themselves as
such from its own node in Device Tree. This patch does just that.
and u9540
