[ Upstream commit cf680cc5251487b9a39919c3cda31a108af19cf8 ]
dtc has new checks for I2C and SPI buses. Fix the warnings in node names
and unit-addresses.
arch/arm/boot/dts/dove-cubox.dtb: Warning (i2c_bus_reg): /i2c-mux/i2c@0/clock-generator: I2C bus unit address format error, expected "60"
arch/arm/boot/dts/dove-cubox-es.dtb: Warning (i2c_bus_reg): /i2c-mux/i2c@0/clock-generator: I2C bus unit address format error, expected "60"
arch/arm/boot/dts/dove-cubox.dtb: Warning (spi_bus_bridge): /mbus/internal-regs/spi-ctrl@10600: node name for SPI buses should be 'spi'
arch/arm/boot/dts/dove-cubox-es.dtb: Warning (spi_bus_bridge): /mbus/internal-regs/spi-ctrl@10600: node name for SPI buses should be 'spi'
arch/arm/boot/dts/dove-dove-db.dtb: Warning (spi_bus_bridge): /mbus/internal-regs/spi-ctrl@10600: node name for SPI buses should be 'spi'
arch/arm/boot/dts/dove-sbc-a510.dtb: Warning (spi_bus_bridge): /mbus/internal-regs/spi-ctrl@10600: node name for SPI buses should be 'spi'
arch/arm/boot/dts/dove-sbc-a510.dtb: Warning (spi_bus_bridge): /mbus/internal-regs/spi-ctrl@14600: node name for SPI buses should be 'spi'
arch/arm/boot/dts/orion5x-kuroboxpro.dtb: Warning (i2c_bus_reg): /soc/internal-regs/i2c@11000/rtc: I2C bus unit address format error, expected "32"
arch/arm/boot/dts/orion5x-linkstation-lschl.dtb: Warning (i2c_bus_reg): /soc/internal-regs/i2c@11000/rtc: I2C bus unit address format error, expected "32"
arch/arm/boot/dts/orion5x-linkstation-lsgl.dtb: Warning (i2c_bus_reg): /soc/internal-regs/i2c@11000/rtc: I2C bus unit address format error, expected "32"
arch/arm/boot/dts/orion5x-linkstation-lswtgl.dtb: Warning (i2c_bus_reg): /soc/internal-regs/i2c@11000/rtc: I2C bus unit address format error, expected "32"
Cc: Jason Cooper <jason@lakedaemon.net>
Cc: Andrew Lunn <andrew@lunn.ch>
Cc: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com>
Cc: Gregory Clement <gregory.clement@bootlin.com>
Signed-off-by: Rob Herring <robh@kernel.org>
Signed-off-by: Gregory CLEMENT <gregory.clement@bootlin.com>
Philippe Ombredanne.
How this work was done:
the use cases:
lines of source
lines).
identifiers to apply.
COPYING file license applied.
GPL-2.0 11139
the concluded license(s).
in time.
they are related.
in about 15000 files.
correct identifier.
version early this week with:
license ids and scores
generate the patches.
Enable the GPU for SolidRun's Cubox.
Signed-off-by: Lucas Stach <l.stach@pengutronix.de>
Signed-off-by: Gregory CLEMENT <gregory.clement@free-electrons.com>
Si5351 clock generator on CuBox uses XTAL as clock reference, name the
clock phandle accordingly.
Signed-off-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com>
As Mainlining effort for SolidRun CuBox has been carried out on the
Engineering Sample, the board DTS was reflecting this. Actually,
SolidRun CuBox comes in three different variants:
Engineering Sample (ES), production with 1GB RAM (1G),
and production with 2GB RAM (2G).
Therefore, we base current dove-cubox.dts on to the 1G production
variant and add a ES dts to add required quirk for misrouted SDHCI
card detect on top of dove-cubox.dts. For the 2G variant we rely on
the bootloader to setup correct RAM size.
Link: https://lkml.kernel.org/r/1401228006-3212-1-git-send-email-sebastian.hesselbarth@gmail.com
Signed-off-by: Jason Cooper <jason@lakedaemon.net>
Generally, power LEDs should indicate when power is applied, and go out
once power is removed. _Not_ annoy the developer with migraine-inducing
blinking reminicent of some badly animated television series designed to
sell sugar to children.
On a more serious note, most of these OS-specific properties aren't
necessary and should be removed. I left two that are legitimately tying
disk LEDs to disk activity. Other than that, we keep the state the
bootloader left them in until userspace changes the state via sysfs.
As defined in the DT, clkout2 is not allowed to change the pll inside
si5351.
This patch extends the properties of clkout2 so that it works as the
external clock of the audio device in the Cubox.
Also, as the second si5351 clock is not used in the Cubox, its
definition is removed.
Signed-off-by: Jean-Francois Moine <moinejf@free.fr>
Acked-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com>
This patch activates the audio device of the Cubox.
The audio flow (pin mpp_audio1) is output on both I2S and S/PDIF.
The third si5351 clock (#2, pin mpp13) is used as the external clock.
This coverts Dove DT board files to preprocessor includes instead
of dtc includes.
This adds a node for the IR receiver connected to a GPIO pin on the
SolidRun CuBox.
This adds common dedicated and gpio pinmux functions to SoC pinctrl
node. It also relocates pinctrl references to corresponding DT nodes.
This patch adds orion-eth and mvmdio device tree nodes for DT enabled
Dove boards. As there is only one ethernet controller on Dove, a default
phy node is also added with a note to set its reg property on a per-board
basis.
This patch adds the device tree node for si5351 clock generator
and the corresponding oscillator connected to it. It also limits
i2c frequency to 100kHz as there are bus locks reported on higher
frequencies.
CuBox needs to enable USB power on a gpio pin. Add a fixed regulator
to always enable usb power on boot.
gpio-leds has support for pinctrl allocation, make use of it.
Card detect for sdhci on Cubox is connected to the wrong pin
(sdio1_cd instead of sdio0_cd). With support for cd-gpios and
pinctrl add the corresponding properties to DT for Cubox.
SolidRun CuBox has a led on a gpio pin. As there is now DT pinctrl
support for Dove, make use of a pinhog to ensure the pin is set to
gpio.
This patch adds basic support for the SolidRun CuBox to DT based
mach-dove. There are still some issues related to ongoing orion/mvebu
development, e.g. gpio-led will not work as there is no DT pinctrl
for dove yet and we don't have board specific setup code. Nevertheless,
the DT description is already introduced here.
