path: root/arch/arm/boot/dts/dove-sbc-a510.dts
2017-01-03ARM: dts: mvebu: Correct license textAlexandre Belloni
The license text has been mangled at some point then copy pasted across multiple files. Restore it to what it should be. Note that this is not intended as a license change. Acked-by: Florian Fainelli <f.fainelli@gmail.com> Acked-by: Stefan Roese <sr@denx.de> Acked-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Acked-by: Rafał Miłecki <zajec5@gmail.com> Acked-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com> Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com> Signed-off-by: Gregory CLEMENT <gregory.clement@free-electrons.com>
2015-05-11ARM: dts: dove: Add proper support for Compulab CM-A510/SBC-A510Sebastian Hesselbarth
Existing dts file for Compulab CM-A510 was very limited due to missing hardware. Now that we actually found somebody with that board, properly rework it to provide a CoM/SoM include and a board file for Compulab's SBC-A510. Both the CM-A510 SoM and the SBC-A510 can be configured with different options, so we only enable a minimum set of options. The actual board configuration will have to be set by either the bootloader or user. Although functionally not required, repeat even disabled nodes again to increse their visibility in the dtsi/dts files. Signed-off-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com> Tested-by: Gabriel Dobato <dobatog@gmail.com> Acked-by: Gregory CLEMENT <gregory.clement@free-electrons.com> Signed-off-by: Gregory CLEMENT <gregory.clement@free-electrons.com>
