McASP3 does not support constant addressing mode on the DAT
port, so increment transfers must be used instead. This
restriction is also applicable for McASP1 and McASP2.
This DMA addressing constraint poses a major problem for sDMA
where constant addressing mode is used on the peripheral side.
Unfortunately, using increment transfers in sDMA comes with
important side effects.
The addressing mode used in eDMA is INC, so the silicon limitation
described above has no impact and the McASP3 DAT port can be
safely added by switching to eDMA instead of sDMA.
Signed-off-by: Misael Lopez Cruz <misael.lopez@ti.com>
Signed-off-by: Peter Ujfalusi <peter.ujfalusi@ti.com>
DRA7 family has eDMA available along with the sDMA and in some cases it is
better suited for servicing peripherals.
Add the needed nodes for eDMA to be usable:
edma-tpcc, edma-tptc0/1 and the edma-xbar.
Move the sDMA xbar nodes under the L4 interconnect node.
This patch fixes the following DTC warnings:
"pbias_regulator has a reg or ranges property, but no unit name"
Signed-off-by: Javier Martinez Canillas <javier@osg.samsung.com>
Pull ARM DT updates from Arnd Bergmann:
"These are all the updates to device tree files for 32-bit platforms,
plus a couple of related 64-bit updates:
New SoC support:
- Allwinner A83T
- Axis Artpec-6 SoC
- Mediatek MT7623 SoC
- TI Keystone K2G SoC
- ST Microelectronics stm32f469
New board or machine support:
- ARM Juno R2
- Buffalo Linkstation LS-QVL and LS-GL
- Cubietruck plus
- D-Link DIR-885L
- DT support for ARM RealView PB1176 and PB11MPCore
- Google Nexus 7
- Homlet v2
- Itead Ibox
- Lamobo R1
- LG Optimus Black
- Logicpd dm3730
- Raspberry Pi Model A
Other changes include
- Lots of updates for Qualcomm APQ8064, MSM8974 and others
- Improved support for Nokia N900 and other OMAP machines
- Common clk support for lpc32xx
- HDLCD display on ARM
- Improved stm32f429 support
- Improved Renesas device support, r8a779x and others
- Lots of Rockchip updates
- Samsung cleanups
- ADC support for Atmel SAMA5D2
- BCM2835 (Raspberry Pi) improvements
- Broadcom Northstar Plus enhancements
- OMAP GPMC rework
- Several improvements for Atmel SAMA5D2 / Xplained
- Global change to remove inofficial "arm,amba-bus" compatible
string"
* tag 'armsoc-dt' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (350 commits)
ARM, ARM64: dts: drop "arm,amba-bus" in favor of "simple-bus"
ARM: dts: artpec: dual-license on artpec6.dtsi
ARM: dts: ux500: add synaptics RMI4 for Ux500 TVK DT
arm64: dts: juno/vexpress: fix node name unit-address presence warnings
arm64: dts: foundation-v8: add SBSA Generic Watchdog device node
ARM: dts: at91: sama5d2 Xplained: add leds node
ARM: dts: at91: sama5d2 Xplained: add user push button
ARM: dts: at91: sama5d2 Xplained: set pin muxing for usb gadget and usb host
ARM: dts: stm32f429: Enable Ethernet on Eval board
ARM: dts: omap3-sniper: TWL4030 keypad support
Revert "ARM: dts: DRA7: Add dt nodes for PWMSS"
ARM: dts: dm814x: dra62x: Disable wait pin monitoring for NAND
ARM: dts: dm814x: dra62x: Fix NAND device nodes
ARM: dts: stm32f429: Add Ethernet support
ARM: dts: stm32f429: Add system config bank node
ARM: dts: at91: sama5d2: add nand0 and nfc0 nodes
ARM: dts: at91: sama5d2: add dma properties to UART nodes
ARM: dts: at91: sama5d2 Xplained: Correct the macb irq pinctrl node
ARM: dts: exynos: Don't overheat the Odroid XU3-Lite on high load
ARM: dts: exynos: Add cooling levels for Exynos5422/5800 CPUs
Errata id: i877
Description:
The RGMII 1000 Mbps Transmit timing is based on the output clock
(rgmiin_txc) being driven relative to the rising edge of an internal
clock and the output control/data (rgmiin_txctl/txd) being driven relative
to the falling edge of an internal clock source. If the internal clock
source is allowed to be static low (i.e., disabled) for an extended period
of time then when the clock is actually enabled the timing delta between
the rising edge and falling edge can change over the lifetime of the
device. This can result in the device switching characteristics degrading
over time, and eventually failing to meet the Data Manual Delay Time/Skew
specs.
To maintain RGMII 1000 Mbps IO Timings, SW should minimize the
duration that the Ethernet internal clock source is disabled. Note that
the device reset state for the Ethernet clock is "disabled".
Other RGMII modes (10 Mbps, 100Mbps) are not affected
Workaround:
If the SoC Ethernet interface(s) are used in RGMII mode at 1000 Mbps,
SW should minimize the time the Ethernet internal clock source is disabled
to a maximum of 200 hours in a device life cycle. This is done by enabling
the clock as early as possible in IPL (QNX) or SPL/u-boot (Linux/Android)
by setting the register CM_GMAC_CLKSTCTRL[1:0]CLKTRCTRL = 0x2:SW_WKUP.
So, do not allow to gate the cpsw clocks using ti,no-idle property in
cpsw node assuming 1000 Mbps is being used all the time. If someone does
not need 1000 Mbps and wants to gate clocks to cpsw, this property needs
to be deleted in their respective board files.
Signed-off-by: Mugunthan V N <mugunthanvnm@ti.com>
Signed-off-by: Grygorii Strashko <grygorii.strashko@ti.com>
Cc: <stable@vger.kernel.org>
Signed-off-by: Paul Walmsley <paul@pwsan.com>
This reverts commit 5fcc673067a2b577d37f2c5c5439dbb177f7107e.
The binding may need to change pending related hwmod comments,
so reverting as requested by Paul Walmsley <paul@pwsan.com>.
Add PWMSS device tree nodes for DRA7 SoC family and add documentation
for dt bindings.
Signed-off-by: Vignesh R <vigneshr@ti.com>
DRA7 SoC has the capability to support DDR memory upto 4GB. In order to
represent this in memory dt node, the address-cells and size cells
should be 2. So, changing the address-cells and size-cells to 2 and
updating the memory nodes accordingly.
Add compatible id, GPMC register resource and interrupt
resource to NAND controller nodes.
The GPMC node will provide an interrupt controller for the
NAND IRQs.
Signed-off-by: Roger Quadros <rogerq@ti.com>
OMAP5 has 3 thermal zones cpu, core and multimedia.
On the other hand DRA7 has 5 thermal zones cpu, gpu, core, dspeve
and iva. Currently cpu, core and multimedia are being added via device tree
and the other 2 are getting added via kernel. Add the missing thermal
domains in device tree so we can create the zones with the appropriate
trip numbers, type and temperatures.
Signed-off-by: Keerthy <j-keerthy@ti.com>
Acked-by: Eduardo Valentin <edubezval@gmail.com>
DWC3's tx-fifo-resize property has been deprecated
because of it being unnecessary to any HW other than
OMAP5 ES1.0.
Signed-off-by: Felipe Balbi <balbi@kernel.org>
Add "syscon-phy-power" property and remove the deprecated "ctrl-module"
property from SATA and USB PHY node. Also remove the unused control
module dt nodes.
Signed-off-by: Kishon Vijay Abraham I <kishon@ti.com>
The USB2 PHY2 has a different register map compared to USB2 PHY1
to power on/off the PHY. In order to handle it, use the new compatible
string "ti,dra7x-usb2-phy2" for the second instance of USB2 PHY.
Add "syscon-phy-power" property and "syscon-pcs" property which can
be used to perform the control module initializations and remove
the deprecated "ctrl-module" property from PCIe PHY dt nodes.
Phandle to "sysclk" clock node is also added to the PCIe PHY node
since some of the syscon initializations is based on system clock
frequency.
Since "omap_control_pcie1phy" and "omap_control_pcie2phy" devicetree
nodes are no longer used, remove it.
Add new device tree node for the control module register space where
PCIe registers are present.
git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap into next/dt
Second set of omap device tree changes for v4.5 merge window. This series
updates the EDMA bindings based on the various fixes to split EDMA into
separate independent devices. It also adds support for more devices on the
CompuLab cm-t335 and LogicPD Torpedo boards, and enables the new bindings
for qspi for am437x and dra7. There are also few dra7 regulator fixes, and
change of gpoi-key,wakeup to wakeup-source.
These depend on commit ae0add740cd0 ("dmaengine: edma: DT: Change reserved
slot array from 16bit to 32bit type") already merged into mainline.
* tag 'omap-for-v4.5/dt-pt2' of git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap:
ARM: OMAP2+: LogicPD Torpedo: Add Touchscreen Support
ARM: dts: DRA7-EVM: Add regulator-allow-bypass property for ldo9
ARM: dts: DRA72-EVM: Add regulator-allow-bypass property for ldo1 and ldo2
ARM: dts: AM4372: add entry for qspi mmap region
ARM: dts: DRA7: add entry for qspi mmap region
ARM: OMAP2+: LogicPD Torpedo: Revert Duplicative Entries
ARM: OMAP2+: LogicPD Torpedo + Wireless: Add Bluetooth
ARM: OMAP2+: LogicPD Torpedo: Add LCD Type 15 Support
ARM: dts: cm-t335: add support for bluetooth
ARM: dts: cm-t335: add support for DVI/LCD
ARM: dts: cm-t335: add support for I2C GPIO expander
ARM: dts: cm-t335: add support for SBC-T335
ARM: dts: cm-t335: add support for USB0
ARM: dts: omap: replace legacy *,wakeup property with wakeup-source
ARM: dts: am335x: replace gpio-key,wakeup with wakeup-source property
ARM: DTS: am437x: Use the new DT bindings for the eDMA3
ARM: DTS: am33xx: Use the new DT bindings for the eDMA3
dmaengine: edma: DT: Change reserved slot array from 16bit to 32bit type
dmaengine: edma: DT: Change memcpy channel array from 16bit to 32bit type
Add qspi memory mapped region entries for DRA7xx based SoCs. Also,
update the binding documents for the controller to document this change.
Acked-by: Rob Herring <robh@kernel.org>
Merge "Device tree changes for omaps for v4.5 merge window" from Tony Lindgren:
- Update all omaps to use pinctrl macros. This makes comparing the pinmux
settings against the documentation much earlier. Javier compared the
checksums of the generated dtb files to make sure nothing changed for
the dtb files.
- Updates for dm816x
- Add GPMC DMA channels for am437x
- Updates for LogicPD Torpedo
- Basic support for CompuLab cm-t335
- Remove tps65217.dtsi file, we're better off adding SoC generic board
dtsi files for the common features
- Add support for ELM on am33xx
- Add support for Bosch shc c3 board
- Add qspi aliases for am437x and dra7
- Wake-up support for dra7-evm uart1
- Basic support for CompuLab sbc-t43
- Basic support for CompuLab cl-som-am57x
- Use MMC pwrseq for libertas WLAN on igep0020 and igep0030
* tag 'omap-for-v4.5/dt-pt1' of git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap: (97 commits)
ARM: dts: omap3-igep0030: Use MMC pwrseq to init SDIO WiFi
ARM: dts: omap3-igep0020: Use MMC pwrseq to init SDIO WiFi
ARM: dts: am57xx: cl-som-am57x: skip resetting ETH PHYs
ARM: dts: am57xx: sbc-am57x: add HDMI support
ARM: dts: am57xx: compulab-sb-som: add HDMI connector
ARM: dts: am57xx: sbc-am57x: add LCD support
ARM: dts: am57xx: sbc-am57x: add GPIO expander support
ARM: dts: am57xx: sbc-am57x: add EEPROM support
ARM: dts: am57xx: sbc-am57x: add usb vbus pinmux
ARM: dts: am57xx: cl-som-am57x: add MMC1 support
ARM: dts: am57xx: sbc-am57x: add basic board support
ARM: dts: am57xx: cl-som-am57x: add analog audio support
ARM: dts: am57xx: cl-som-am57x: add touchscreen support
ARM: dts: am57xx: cl-som-am57x: add USB support
ARM: dts: am57xx: cl-som-am57x: add dual EMAC support
ARM: dts: am57xx: cl-som-am57x: add spi-flash support
ARM: dts: am57xx: cl-som-am57x: add eMMC support
ARM: dts: am57xx: cl-som-am57x: add EEPROM support
ARM: dts: am57xx: cl-som-am57x: add I2C3 support
ARM: dts: am57xx: cl-som-am57x: dts: add RTC support
Set the alias for qspi to spi0
McASP node needs to list all mandatory clocks: gfclk and ahclkx
Tested-by: Felipe Balbi <balbi@ti.com>
Pull ARM DT updates from Olof Johansson:
"As usual, this is the massive branch we have for each release. Lots
of various updates and additions of hardware descriptions on existing
hardware, as well as the usual additions of new boards and SoCs.
This is also the first release where we've started mixing 64- and
32-bit DT updates in one branch.
(Specific details on what's actually here and new is pretty easy to
tell from the diffstat, so there's little point in duplicating listing
it here)"
* tag 'armsoc-dt' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (499 commits)
ARM: dts: uniphier: add system-bus-controller nodes
ARM64: juno: disable NOR flash node by default
ARM: dts: uniphier: add outer cache controller nodes
arm64: defconfig: Enable PCI generic host bridge by default
arm64: Juno: Add support for the PCIe host bridge on Juno R1
Documentation: of: Document the bindings used by Juno R1 PCIe host bridge
ARM: dts: uniphier: add I2C aliases for ProXstream2 boards
dts/Makefile: Add build support for LS2080a QDS & RDB board DTS
dts/ls2080a: Add DTS support for LS2080a QDS & RDB boards
dts/ls2080a: Update Simulator DTS to add support of various peripherals
dts/ls2080a: Remove text about writing to Free Software Foundation
dts/ls2080a: Update DTSI to add support of various peripherals
doc: DTS: Update DWC3 binding to provide reference to generic bindings
doc/bindings: Update GPIO devicetree binding documentation for LS2080A
Documentation/dts: Move FSL board-specific bindings out of /powerpc
Documentation: DT: Add entry for FSL LS2080A QDS and RDB boards
arm64: Rename FSL LS2085A SoC support code to LS2080A
arm64: Use generic Layerscape SoC family naming
ARM: dts: uniphier: add ProXstream2 Vodka board support
ARM: dts: uniphier: add ProXstream2 Gentil board support
The DRA7xx family of SOCs have two IPUs and one DSP processor
subsystems in common. The IOMMU DT nodes have been added for
these processor subsystems, and have been disabled by default.
These MMUs are very similar to those on OMAP4 and OMAP5, with
the only difference being the presence of a second MMU within
the DSP subsystem for the EDMA port. The DSP IOMMUs also need
an additional 'ti,syscon-mmuconfig' property compared to the
IPU IOMMUs.
NOTE: The enabling of these nodes is left to the respective
board dts files.
Signed-off-by: Suman Anna <s-anna@ti.com>
The DSP_SYSTEM sub-module is a dedicated system control logic
module present within a DRA7 DSP processor sub-system. This
module is responsible for power management, clock generation
and connection to the device PRCM module.
Add a syscon node for this module for the DSP1 processor
sub-system. This is added as a syscon node as it is a common
configuration module that can be used by the different IOMMU
instances and the corresponding remoteproc device.
The node is added to the common dra7.dtsi file, as the DSP1
processor sub-system is mostly common across all the variants
of the DRA7 SoC family.
net/dsa/slave.c
net/dsa/slave.c simply had overlapping changes.
"ARM: dts: <omap2/omap4/omap5/dra7>: add minimal l4 bus
layout with control module support" moved pbias_regulator dt node
from being a child node of ocp to be the child node of
'syscon'. Since 'syscon' doesn't have the 'ranges' property,
address translation fails while trying to convert the address
to resource. Fix it here by populating 'ranges' property in
syscon dt node.
Fixes: 72b10ac00eb1 ("ARM: dts: omap24xx: add minimal l4 bus
layout with control module support")
Fixes: 7415b0b4c645 ("ARM: dts: omap4: add minimal l4 bus layout
Fixes: ed8509edddeb ("ARM: dts: omap5: add minimal l4 bus
Fixes: d919501feffa ("ARM: dts: dra7: add minimal l4 bus
[tony@atomide.com: fixed omap3 pbias to work]
There are 2 MACIDs stored in the control module of the dra7.
These are read by the cpsw driver if no valid MACID was found
in the devicetree.
Register address in name of the node is wrong
Signed-off-by: Vishal Mahaveer <vishalm@ti.com>
Acked-by: Mugunthan V N <mugunthanvnm@ti.com>
Use platform specific compatible strings instead of the common
"ti,pbias-omap" compatible string.
Pull networking updates from David Miller:
"Another merge window, another set of networking changes. I've heard
rumblings that the lightweight tunnels infrastructure has been voted
networking change of the year. But what do I know?
1) Add conntrack support to openvswitch, from Joe Stringer.
2) Initial support for VRF (Virtual Routing and Forwarding), which
allows the segmentation of routing paths without using multiple
devices. There are some semantic kinks to work out still, but
this is a reasonably strong foundation. From David Ahern.
3) Remove spinlock fro act_bpf fast path, from Alexei Starovoitov.
4) Ignore route nexthops with a link down state in ipv6, just like
ipv4. From Andy Gospodarek.
5) Remove spinlock from fast path of act_gact and act_mirred, from
Eric Dumazet.
6) Document the DSA layer, from Florian Fainelli.
7) Add netconsole support to bcmgenet, systemport, and DSA. Also
8) Add Mellanox Switch Driver and core infrastructure, from Jiri
Pirko.
9) Add support for "light weight tunnels", which allow for
encapsulation and decapsulation without bearing the overhead of a
full blown netdevice. From Thomas Graf, Jiri Benc, and a cast of
others.
10) Add Identifier Locator Addressing support for ipv6, from Tom
Herbert.
11) Support fragmented SKBs in iwlwifi, from Johannes Berg.
12) Allow perf PMUs to be accessed from eBPF programs, from Kaixu Xia.
13) Add BQL support to 3c59x driver, from Loganaden Velvindron.
14) Stop using a zero TX queue length to mean that a device shouldn't
have a qdisc attached, use an explicit flag instead. From Phil
Sutter.
15) Use generic geneve netdevice infrastructure in openvswitch, from
Pravin B Shelar.
16) Add infrastructure to avoid re-forwarding a packet in software
that was already forwarded by a hardware switch. From Scott
Feldman.
17) Allow AF_PACKET fanout function to be implemented in a bpf
program, from Willem de Bruijn"
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1458 commits)
netfilter: nf_conntrack: make nf_ct_zone_dflt built-in
netfilter: nf_dup{4, 6}: fix build error when nf_conntrack disabled
net: fec: clear receive interrupts before processing a packet
ipv6: fix exthdrs offload registration in out_rt path
xen-netback: add support for multicast control
bgmac: Update fixed_phy_register()
sock, diag: fix panic in sock_diag_put_filterinfo
flow_dissector: Use 'const' where possible.
flow_dissector: Fix function argument ordering dependency
ixgbe: Resolve "initialized field overwritten" warnings
ixgbe: Remove bimodal SR-IOV disabling
ixgbe: Add support for reporting 2.5G link speed
ixgbe: fix bounds checking in ixgbe_setup_tc for 82598
ixgbe: support for ethtool set_rxfh
ixgbe: Avoid needless PHY access on copper phys
ixgbe: cleanup to use cached mask value
ixgbe: Remove second instance of lan_id variable
ixgbe: use kzalloc for allocating one thing
flow: Move __get_hash_from_flowi{4,6} into flow_dissector.c
ixgbe: Remove unused PCI bus types
"Ladies and gentlemen, we proudly announce to you the latest branch of
ARM device tree contents for the mainline kernel. Come and see, come
and see!
No less than twentythree thousand lines of additions! Just imagine the
joy you will have of using your mainline kernel on newly supported
hardware such as Rockchip Chromebooks, Freescale i.MX6UL boards or
UniPhier hardware!
For those of you feeling less adventurous, added hardware support on
platforms such as TI DM814x and Gumstix Overo platforms might be more
of your liking.
We've got something for everyone here!
Ahem. Cough. So, anyway...
This is the usual large batch of DT updates. Lots and lots of smaller
changes, some of the larger ones to point out are:
- Rockchip veyron (Chromebook) support, as well as several other new boards
- DRM support on Atmel AT91SAM9N12EK
- USB additions on some Allwinner platforms
- Mediatek MT6580 support
- Freescale i.MX6UL support
- cleanups for Renesas shmobile platforms
- lots of added devices on LPC18xx
- lots of added devices and boards on UniPhier
There's also some dependent code added here, in particular some
branches that are primarily merged through the clock tree"
* tag 'armsoc-dt' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (389 commits)
ARM: tegra: Add gpio-ranges property
ARM: tegra: Fix AHB base address on Tegra20, Tegra30 and Tegra114
ARM: tegra: Add Tegra124 PMU support
ARM: tegra: jetson-tk1: Add GK20A GPU DT node
ARM: tegra: venice2: Add GK20A GPU DT node
ARM: tegra: Add IOMMU node to GK20A
ARM: tegra: Add CPU regulator to the Jetson TK1 device tree
ARM: tegra: Add entries for cpufreq on Tegra124
ARM: tegra: Enable the DFLL on the Jetson TK1
ARM: tegra: Add the DFLL to Tegra124 device tree
ARM: dts: zynq: Add devicetree entry for Xilinx Zynq reset controller.
ARM: dts: UniPhier: fix PPI interrupt CPU mask of timer nodes
ARM: dts: rockchip: correct regulator power states for suspend
ARM: dts: rockchip: correct regulator PM properties
ARM: dts: vexpress: Use assigned-clock-parents for sp810
pinctrl: tegra: Only set the gpio range if needed
arm: boot: dts: am4372: add ARM timers and SCU nodes
ARM: dts: AM4372: Add the am4372-rtc compatible string
ARM: shmobile: r8a7794 dtsi: Add CPG/MSTP Clock Domain
ARM: shmobile: r8a7793 dtsi: Add CPG/MSTP Clock Domain
git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci
Pull PCI updates from Bjorn Helgaas:
"PCI changes for the v4.3 merge window:
Enumeration:
- Allocate ATS struct during enumeration (Bjorn Helgaas)
- Embed ATS info directly into struct pci_dev (Bjorn Helgaas)
- Reduce size of ATS structure elements (Bjorn Helgaas)
- Stop caching ATS Invalidate Queue Depth (Bjorn Helgaas)
- iommu/vt-d: Cache PCI ATS state and Invalidate Queue Depth (Bjorn Helgaas)
- Move MPS configuration check to pci_configure_device() (Bjorn Helgaas)
- Set MPS to match upstream bridge (Keith Busch)
- ARM/PCI: Set MPS before pci_bus_add_devices() (Murali Karicheri)
- Add pci_scan_root_bus_msi() (Lorenzo Pieralisi)
- ARM/PCI, designware, xilinx: Use pci_scan_root_bus_msi() (Lorenzo Pieralisi)
Resource management:
- Call pci_read_bridge_bases() from core instead of arch code (Lorenzo Pieralisi)
PCI device hotplug:
- pciehp: Remove unused interrupt events (Bjorn Helgaas)
- pciehp: Remove ignored MRL sensor interrupt events (Bjorn Helgaas)
- pciehp: Handle invalid data when reading from non-existent devices (Jarod Wilson)
- pciehp: Simplify pcie_poll_cmd() (Yijing Wang)
- Use "slot" and "pci_slot" for struct hotplug_slot and struct pci_slot (Yijing Wang)
- Protect pci_bus->slots with pci_slot_mutex, not pci_bus_sem (Yijing Wang)
- Hold pci_slot_mutex while searching bus->slots list (Yijing Wang)
Power management:
- Disable async suspend/resume for JMicron multi-function SATA/AHCI (Zhang Rui)
Virtualization:
- Add ACS quirks for Intel I219-LM/V (Alex Williamson)
- Restore ACS configuration as part of pci_restore_state() (Alexander Duyck)
MSI:
- Add pcibios_alloc_irq() and pcibios_free_irq() (Jiang Liu)
- x86: Implement pcibios_alloc_irq() and pcibios_free_irq() (Jiang Liu)
- Add helpers to manage pci_dev->irq and pci_dev->irq_managed (Jiang Liu)
- Free legacy IRQ when enabling MSI/MSI-X (Jiang Liu)
- ARM/PCI: Remove msi_controller from struct pci_sys_data (Lorenzo Pieralisi)
- Remove unused pcibios_msi_controller() hook (Lorenzo Pieralisi)
Generic host bridge driver:
- Remove dependency on ARM-specific struct hw_pci (Jayachandran C)
- Build setup-irq.o for arm64 (Jayachandran C)
- Add arm64 support (Jayachandran C)
APM X-Gene host bridge driver:
- Add APM X-Gene PCIe 64-bit prefetchable window (Duc Dang)
- Add support for a 64-bit prefetchable memory window (Duc Dang)
- Drop owner assignment from platform_driver (Krzysztof Kozlowski)
Broadcom iProc host bridge driver:
- Allow BCMA bus driver to be built as module (Hauke Mehrtens)
- Delete unnecessary checks before phy calls (Markus Elfring)
- Add arm64 support (Ray Jui)
Synopsys DesignWare host bridge driver:
- Don't complain missing *config* reg space if va_cfg0 is set (Murali Karicheri)
TI DRA7xx host bridge driver:
- Disable pm_runtime on get_sync failure (Kishon Vijay Abraham I)
- Add PM support (Kishon Vijay Abraham I)
- Clear MSE bit during suspend so clocks will idle (Kishon Vijay Abraham I)
- Add support to make GPIO drive PERST# line (Kishon Vijay Abraham I)
Xilinx AXI host bridge driver:
- Check for MSI interrupt flag before handling as INTx (Russell Joyce)
Miscellaneous:
- Fix Intersil/Techwell TW686[4589] AV capture class code (Krzysztof Hałasa)
- Use PCI_CLASS_SERIAL_USB instead of bare number (Bjorn Helgaas)
- Fix generic NCR 53c810 class code quirk (Bjorn Helgaas)
- Fix TI816X class code quirk (Bjorn Helgaas)
- Remove unused "pci_probe" flags (Bjorn Helgaas)
- Host bridge driver code simplifications (Fabio Estevam)
- Add dev_flags bit to access VPD through function 0 (Mark Rustad)
- Add VPD function 0 quirk for Intel Ethernet devices (Mark Rustad)
- Kill off set_irq_flags() usage (Rob Herring)
- Remove Intel Cherrytrail D3 delays (Srinidhi Kasagar)
- Clean up pci_find_capability() (Wei Yang)"
* tag 'pci-v4.3-changes' of git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci: (72 commits)
PCI: Disable async suspend/resume for JMicron multi-function SATA/AHCI
PCI: Set MPS to match upstream bridge
PCI: Move MPS configuration check to pci_configure_device()
PCI: Drop references acquired by of_parse_phandle()
PCI/MSI: Remove unused pcibios_msi_controller() hook
PCI: Add pci_scan_root_bus_msi()
ARM/PCI: Replace panic with WARN messages on failures
PCI: generic: Add arm64 support
PCI: Build setup-irq.o for arm64
PCI: generic: Remove dependency on ARM-specific struct hw_pci
PCI: imx6: Simplify a trivial if-return sequence
PCI: spear: Use BUG_ON() instead of condition followed by BUG()
PCI: dra7xx: Remove unneeded use of IS_ERR_VALUE()
PCI: Remove pci_ats_enabled()
PCI: Stop caching ATS Invalidate Queue Depth
PCI: Move ATS declarations to linux/pci.h so they're all together
PCI: Clean up ATS error handling
PCI: Use pci_physfn() rather than looking up physfn by hand
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty
Pull tty/serial driver updates from Greg KH:
"Here is the big tty/serial driver update for 4.3-rc1.
Not many major things, a number of driver updates and changes, and the
8250 driver got split up a bit to make it easier to work with by
moving some functions to a new file. Full details are in the
shortlog.
All have been in linux-next with no reported issues"
* tag 'tty-4.3-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty: (90 commits)
serial: imx: save and restore context in the suspend path
serial: imx: allow waking up on RTSD
serial: imx: introduce serial_imx_enable_wakeup()
serial: imx: remove unbalanced clk_prepare
serial: 8250: move rx_running out of the bitfield
tty: serial: 8250_omap: do not use RX DMA if pause is not supported
serial:8250_dw: do not alter CTS and DCTS since AFE is enabled
tty: serial: men_z135_uart.c: Don't initialize port->lock
tty: serial: men_z135_uart.c: Fix race between IRQ and set_termios()
serial: 8250: bind to ALi Fast Infrared Controller (ALI5123)
serial: 8250: don't bind to SMSC IrCC IR port
serial: mxs-auart: fix baud rate range
serial: mxs-auart: keep the AUART unit in reset state when not in use
serial: mxs-auart: use a function name to reflect what it really does
serial: 8250_pci: fix mode after S3/S4 resume for F81504/508/512
sc16is7xx: constify devtype
sc16is7xx: support multiple devices
sc16is7xx: save and use per-chip line number
uart: pl011: Add support to ZTE ZX296702 uart
uart: pl011: Improve LCRH register access decision
drivers/net/usb/qmi_wwan.c
Overlapping additions of new device IDs to qmi_wwan.c
Pull ARM SoC fixes from Olof Johansson:
"A smallish batch of fixes, a little more than expected this late, but
all fixes are contained to their platforms and seem reasonably low
risk:
- a somewhat large SMP fix for ux500 that still seemed warranted to
include here
- OMAP DT fixes for pbias regulator specification that broke due to
some DT reshuffling
- PCIe IRQ routing bugfix for i.MX
- networking fixes for keystone
- runtime PM for OMAP GPMC
- a couple of error path bug fixes for exynos"
* tag 'armsoc-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc:
ARM: dts: keystone: Fix the mdio bindings by moving it to soc specific file
ARM: dts: keystone: fix the clock node for mdio
memory: omap-gpmc: Don't try to save uninitialized GPMC context
ARM: imx6: correct i.MX6 PCIe interrupt routing
ARM: ux500: add an SMP enablement type and move cpu nodes
ARM: dts: dra7: Fix broken pbias device creation
ARM: dts: OMAP5: Fix broken pbias device creation
ARM: dts: OMAP4: Fix broken pbias device creation
ARM: dts: omap243x: Fix broken pbias device creation
ARM: EXYNOS: fix double of_node_put() on error path
ARM: EXYNOS: Fix potentian kfree() of ro memory
CPSW driver has been updated with compatibles for enabling errata
workarounds. So updating cpsw compatibles.
gpio2_8 is connected to the PCIe_RESETn line and it has to be driven low to
reset the PCIe cards. Add gpios property to PCIe DT node.
Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
commit <d919501feffa> ("ARM: dts: dra7: add minimal l4 bus
layout with control module support") moved pbias_regulator dt node
scm_conf. After this device for pbias_regulator is
not created.
Fix it by adding "simple-bus" compatible property to
scm_conf dt node.
Cc: <stable@vger.kernel.org> # v4.1
Suggested-by: Tero Kristo <t-kristo@ti.com>
Tested-by: Grygorii Strashko <grygorii.strashko@ti.com>
This region contains CTRL_CORE_SMA_SW2..9 registers which
are not specific to any domain and can be reasonably
accessed via syscon driver.
Acked-by: Tero Kristo <t-kristo@ti.com>
We need to add 4 bytes to include the last 32-bit register space.
These nodes are wrongly placed. They must come under the
scm node. Nobody uses them either so get rid of them.
Add "ti,dra742-uart" to the compatible list so the driver
workaround for UART module disable errata is enabled.
This does not break backward compatibility as existing DTBs
should continue to work with newer kernels albeit without the
capability to idle the UART module when DMA is used.
Signed-off-by: Sekhar Nori <nsekhar@ti.com>
This register is required to be passed to the SATA PHY driver
to workaround errata i783 (SATA Lockup After SATA DPLL Unlock/Relock).
Add interrupt names so that the same can be used for OTG easily.
The sDMA requests are routed through the DMA crossbar and without the
crossbar only peripherals using DMA request 0-127 can be used.
DRA7xxx contains a very similar DSS to OMAP5. The main differences are:
* no DSI or RFBI support.
* 1 or 2 dedicated video PLLs.
* need to do additional configuration to the DRA7 CONTROL module.
DRA72xx has only one video PLL, and DRA74xx has two.
Signed-off-by: Tomi Valkeinen <tomi.valkeinen@ti.com>
Cc: devicetree@vger.kernel.org
Add a new Linux clock for DRA7 based SoCs to control DESHDCP clock.
Fix a typo in DRA7 dtsi where 12 bytes are needed for register
description of ABB efuse registers, however only 8 bytes are provided
to map. For some weird reason, this does not generate abort at offset
0x8, probably due to default maps already provided in io.c for the bus
register ranges.
Reported-by: Matt Gessner <Matt.Gessner@windriver.com>
Reported-by: Suman Anna <s-anna@ti.com>
Signed-off-by: Nishanth Menon <nm@ti.com>
