Nearly all of the information in the cpus node, especially for cpu0, is
the same between dra74x and dra72x so move the common information to
the parent dra7.dtsi to avoid duplication of data.
Signed-off-by: Dave Gerlach <d-gerlach@ti.com>
Acked-by: Viresh Kumar <viresh.kumar@linaro.org>
Add the sub-mailbox nodes that are used to communicate between
MPU and the remote processors IPU1, IPU2 and DSP1. These match the
respective node definitions on DRA74x to maintain compatibility for
the equivalent remote processors. There is no DSP2 on DRA72x, and
so the corresponding sub-mailbox node is not added.
These sub-mailbox nodes are added to match the hard-coded mailbox
configuration used within the TI IPC 3.x software package. The
Dual-Cortex M4 IPU1 and IPU2 processor sub-systems are assumed to
be running in SMP-mode, and hence only a single sub-mailbox node
is added for each.
All these sub-mailbox nodes are left in disabled state, and should
be enabled (and modified if needed) as per the individual product
configuration in the corresponding board dts files.
Signed-off-by: Suman Anna <s-anna@ti.com>
DRA7xxx contains a very similar DSS to OMAP5. The main differences are:
* no DSI or RFBI support.
* 1 or 2 dedicated video PLLs.
* need to do additional configuration to the DRA7 CONTROL module.
DRA72xx has only one video PLL, and DRA74xx has two.
Signed-off-by: Tomi Valkeinen <tomi.valkeinen@ti.com>
Cc: devicetree@vger.kernel.org
Pull ARM SoC fixes from Olof Johansson:
"Here's the usual "low-priority fixes that didn't make it into the last
few -rcs, with a twist: We had a fixes pull request that I didn't send
in time to get into 4.0, so we'll send some of them to Greg for
-stable as well.
Contents here is as usual not all that controversial:
- a handful of randconfig fixes from Arnd, in particular for older
Samsung platforms
- Exynos fixes, !SMP building, DTS updates for MMC and lid switch
- Kbuild fix to create output subdirectory for DTB files
- misc minor fixes for OMAP"
* tag 'armsoc-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (23 commits)
ARM: at91/dt: sama5d3 xplained: add phy address for macb1
kbuild: Create directory for target DTB
ARM: mvebu: Disable CPU Idle on Armada 38x
ARM: DRA7: Enable Cortex A15 errata 798181
ARM: dts: am57xx-beagle-x15: Add thermal map to include fan and tmp102
ARM: dts: DRA7: Add bandgap and related thermal nodes
bus: ocp2scp: SYNC2 value should be changed to 0x6
ARM: dts: am4372: Add "ti,am437x-ocp2scp" as compatible string for OCP2SCP
ARM: OMAP2+: remove superfluous NULL pointer check
ARM: EXYNOS: Fix build breakage cpuidle on !SMP
ARM: dts: fix lid and power pin-functions for exynos5250-spring
ARM: dts: fix mmc node updates for exynos5250-spring
ARM: OMAP4: remove dead kconfig option OMAP4_ERRATA_I688
MAINTAINERS: add OMAP defconfigs under OMAP SUPPORT
ARM: OMAP1: PM: fix some build warnings on 1510-only Kconfigs
ARM: cns3xxx: don't export static symbol
ARM: S3C24XX: avoid a Kconfig warning
ARM: S3C24XX: fix header file inclusions
ARM: S3C24XX: fix building without PM_SLEEP
ARM: S3C24XX: use SAMSUNG_WAKEMASK for s3c2416
Add bandgap and related thermal nodes. The patch adds 5 thermal
sensors. Only one cooling device for mpu as of now. The sensors are
the exact same on both dra72 and dra7. Introduce CPU, GPU, core nodes
for the moment as they are direct reuse of OMAP5 entities.
NOTE: OMAP4 has a finer counter granularity, which allows for a delay
of 1000ms in the thermal zone polling intervals. DRA7 have different
counter mechanism, which allows at maximum a 500ms timer. Adjust the
cpu thermal zone accordingly for DRA7.
Signed-off-by: Keerthy <j-keerthy@ti.com>
[t-kristo@ti.com: few reuse from OMAP5 entities]
Signed-off-by: Tero Kristo <t-kristo@ti.com>
Signed-off-by: Nishanth Menon <nm@ti.com>
OMAP4/5 has been (ab)using the gic_arch_extn to provide
wakeup from suspend, and it makes a lot of sense to convert
this code to use stacked domains instead.
This patch does just this, updating the DT files to actually
reflect what the HW provides.
BIG FAT WARNING: because the DTs were so far lying by not
exposing the WUGEN HW block, kernels with this patch applied
won't have any suspend-resume facility when booted with old DTs,
and old kernels with updated DTs won't even boot.
On a platform with this patch applied, the system looks like
this:
root@bacon-fat:~# cat /proc/interrupts
CPU0 CPU1
16: 0 0 WUGEN 37 gp_timer
19: 233799 155916 GIC 27 arch_timer
23: 0 0 WUGEN 9 l3-dbg-irq
24: 1 0 WUGEN 10 l3-app-irq
27: 282 0 WUGEN 13 omap-dma-engine
44: 0 0 4ae10000.gpio 13 DMA
294: 0 0 WUGEN 20 gpmc
297: 506 0 WUGEN 56 48070000.i2c
298: 0 0 WUGEN 57 48072000.i2c
299: 0 0 WUGEN 61 48060000.i2c
300: 0 0 WUGEN 62 4807a000.i2c
301: 8 0 WUGEN 60 4807c000.i2c
308: 2439 0 WUGEN 74 OMAP UART2
312: 362 0 WUGEN 83 mmc2
313: 502 0 WUGEN 86 mmc0
314: 13 0 WUGEN 94 mmc1
350: 0 0 PRCM pinctrl, pinctrl
406: 35155709 0 GIC 109 ehci_hcd:usb1
407: 0 0 WUGEN 7 palmas
409: 0 0 WUGEN 119 twl6040
410: 0 0 twl6040 5 twl6040_irq_ready
411: 0 0 twl6040 0 twl6040_irq_th
IPI0: 0 1 CPU wakeup interrupts
IPI1: 0 0 Timer broadcast interrupts
IPI2: 95334 902334 Rescheduling interrupts
IPI3: 0 0 Function call interrupts
IPI4: 479 648 Single function call interrupts
IPI5: 0 0 CPU stop interrupts
IPI6: 0 0 IRQ work interrupts
IPI7: 0 0 completion interrupts
Err: 0
Link: https://lkml.kernel.org/r/1426088629-15377-8-git-send-email-marc.zyngier@arm.com
Signed-off-by: Jason Cooper <jason@lakedaemon.net>
Support for the TI crossbar used on the DRA7 family of chips
is implemented as an ugly hack on the side of the GIC.
Converting it to stacked domains makes it slightly more
palatable, as it results in a cleanup.
Unfortunately, as the DT bindings failed to acknowledge the
fact that this is actually yet another interrupt controller
(the third, actually), we have yet another breakage. Oh well.
Link: https://lkml.kernel.org/r/1426088629-15377-3-git-send-email-marc.zyngier@arm.com
DRA74x and DRA72x family of processors vary slightly in the number
of CPUs. So, add different instances of PMU for each of these processor
groups. Further, since the interrupts bypass crossbar and are directly
connected to GIC, mark the dts nodes with relevant information.
Tested with perf utility.
Reviewed-by: Felipe Balbi <balbi@ti.com>
Signed-off-by: Lucas Weaver <l-weaver@ti.com>
DRA722 is part of DRA72x family which are single core cortex A15 devices
with most infrastructure IPs otherwise same as whats on the DRA74x family.
So move the cpu nodes into dra74x.dtsi and dra72x.dtsi respectively.
Also add a minimal dra72-evm dts file.
Signed-off-by: Rajendra Nayak <rnayak@ti.com>
Cc: linux-doc@vger.kernel.org
[tony@atomide.com: updated for Makefile sorting]
