path: root/arch/arm/boot/dts/ecx-2000.dts
2017-02-07ARM: DTS: Fix register map for virt-capable GICMarc Zyngier
Since everybody copied my own mistake from the DT binding example, let's address all the offenders in one swift go. Most of them got the CPU interface size wrong (4kB, while it should be 8kB), except for both keystone platforms which got the control interface wrong (4kB instead of 8kB). In a few cases where I knew for sure what implementation was used, I've added the "arm,gic-400" compatible string. I'm 99% sure that this is what everyone is using, but short of having the TRM for all the other SoCs, I've left them alone. Acked-by: Shawn Guo <shawnguo@kernel.org> Acked-by: Tony Lindgren <tony@atomide.com> Acked-by: Santosh Shilimkar <ssantosh@kernel.org> Acked-by: Krzysztof Kozlowski <krzk@kernel.org> Acked-by: Maxime Ripard <maxime.ripard@free-electrons.com> Acked-by: Antoine Tenart <antoine.tenart@free-electrons.com> Acked-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Matthias Brugger <matthias.bgg@gmail.com> Acked-by: Heiko Stuebner <heiko@sntech.de> Reviewed-by: Javier Martinez Canillas <javier@osg.samsung.com> Signed-off-by: Marc Zyngier <marc.zyngier@arm.com> Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2013-11-04ARM: dts: calxeda: move memory-controller node out of ecx-common.dtsiRob Herring
The DDR controller is slightly different in ECX-2000 and ECX-1000, so we need to have different nodes for each platform. Signed-off-by: Rob Herring <rob.herring@calxeda.com> [Device Tree documentation updated.] Signed-off-by: Robert Richter <rric@kernel.org>
2013-01-07ARM: dts: add device_type prop to cpu nodes on Calxeda platformsRob Herring
While device_type is considered deprecated, it is still needed for tools like lshw to identify cpu nodes. Signed-off-by: Rob Herring <rob.herring@calxeda.com> Signed-off-by: Olof Johansson <olof@lixom.net>
2012-10-31ARM: dts: Add Calxeda ECX-2000 supportRob Herring
Separate out common dts pieces from highbank dts and add support for Calxeda ECX-2000 (Midway) SOC. Signed-off-by: Rob Herring <rob.herring@calxeda.com> Acked-by: Arnd Bergmann <arnd@arndb.de>
