Add a "serial1" alias for the serial console (it is labeled "uart1").
Add the serial port config to "chosen/stdout-path", which requires
referring to the port by alias.
Drop the "console=" parameter from the kernel command line, as it's no
longer needed for DT-based platforms.
Signed-off-by: Geert Uytterhoeven <geert+renesas@glider.be>
Signed-off-by: Simon Horman <horms+renesas@verge.net.au>
Warning (unit_address_vs_reg): Node /memory has a reg or ranges property, but no unit name
Warning (unit_address_vs_reg): Node /pfc@e0140200/serial@e1030000 has a unit name, but no reg property
Warning (unit_address_vs_reg): Node /gpio_keys/button@1 has a unit name, but no reg property
Warning (unit_address_vs_reg): Node /gpio_keys/button@2 has a unit name, but no reg property
Warning (unit_address_vs_reg): Node /gpio_keys/button@3 has a unit name, but no reg property
Warning (unit_address_vs_reg): Node /gpio_keys/button@4 has a unit name, but no reg property
Warning (unit_address_vs_reg): Node /regulator@0 has a unit name, but no reg property
Warning (unit_address_vs_reg): Node /regulator@1 has a unit name, but no reg property
Since 16ccaf5bb5a5 ("pinctrl: sh-pfc: Accept standard function, pins and
groups properties") renesas pfc drivers accept generic "function", "pins"
and "groups" properties.
This patch updates the kzm9d device tree to use the generic properties.
Acked-by: Geert Uytterhoeven <geert+renesas@glider.be>
The keyboard driver for GPIO buttons(gpio-keys) checks for one of the
two boolean properties to enable gpio buttons as wakeup source:
1. "wakeup-source" or
2. the legacy "gpio-key,wakeup"
However juno, ste-snowball and emev2-kzm9d dts file have a undetected
"wakeup" property to indictate the wakeup source.
This patch fixes it by making use of "wakeup-source" property.
Cc: Magnus Damm <magnus.damm@gmail.com>
Acked-by: Simon Horman <horms@verge.net.au>
Signed-off-by: Sudeep Holla <sudeep.holla@arm.com>
Signed-off-by: Wolfram Sang <wsa+renesas@sang-engineering.com>
lan9220 -> ethernet
uart -> serial
Configure the pinmux on kzm9d to use the serial connector for uart1.
Signed-off-by: Niklas Söderlund <niso@kth.se>
Acked-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
Add a stdout-path property so that automatic console selection works
in the absence of a "console=" parameter on the kernel command line.
Note that we have to keep the "console=ttyS1,115200n81" parameter in
chosen/bootargs, else the console will use the default setting of 9600
baud.
Signed-off-by: Ulrich Hecht <ulrich.hecht+renesas@gmail.com>
Signed-off-by: Laurent Pinchart <laurent.pinchart+renesas@ideasonboard.com>
Use the gpio-keys driver to support the 4 pins on the
dip switch DSW2 which is mounted on the KZM9D board.
Signed-off-by: Magnus Damm <damm@opensource.se>
Copy the device nodes from KZM9D reference into the KZM9D
device tree file. This will allow us to use a single DTS
file regarless of kernel configuration. In case of legacy
C board code the device nodes may or may not be used, but
in the multiplatform case all the DT device nodes are used.
NFS detail settings like "nfsroot=,rsize=4096,wsize=4096" are no longer needed
Signed-off-by: Kuninori Morimoto <kuninori.morimoto.gx@renesas.com>
Update the KZM9D DTS command line to remove following cruft:
- console=tty0 - no graphic support upstream anyway
- earlyprintk= - not supported by the 8250-em driver anyway
- mem= - this is provided via DT anyway
* Do not disable SUSPEND
Suspend seems to work fine on the kzm9d.
This is part of an effort reduce differences between mach-shmobile
defconfigs with a view to using a common defconfig.
* Enable PM_RUNTIME
This also seems to work fine on the kzm9d.
* Move kernel command line from defconfig to dts.
This brings us one small step closer to sharing defconfig
between kzm9d and other boards.
Use DT_MACHINE_START() on the emev2 based KZM9D board.
Also include a tiny DTS file to describe the board and
update the Kconfig dependencies to select CONFIG_USE_OF.
Update the SMP glue code to use OF for matching.
