Warning (unit_address_vs_reg): Node /clocks@e0110000/iic0_sclkdiv has a reg or ranges property, but no unit name
Warning (unit_address_vs_reg): Node /clocks@e0110000/iic0_sclk has a reg or ranges property, but no unit name
Warning (unit_address_vs_reg): Node /clocks@e0110000/iic1_sclkdiv has a reg or ranges property, but no unit name
Warning (unit_address_vs_reg): Node /clocks@e0110000/iic1_sclk has a reg or ranges property, but no unit name
Warning (unit_address_vs_reg): Node /clocks@e0110000/usia_u0_sclkdiv has a reg or ranges property, but no unit name
Warning (unit_address_vs_reg): Node /clocks@e0110000/usib_u1_sclkdiv has a reg or ranges property, but no unit name
Warning (unit_address_vs_reg): Node /clocks@e0110000/usib_u2_sclkdiv has a reg or ranges property, but no unit name
Warning (unit_address_vs_reg): Node /clocks@e0110000/usib_u3_sclkdiv has a reg or ranges property, but no unit name
Warning (unit_address_vs_reg): Node /clocks@e0110000/usia_u0_sclk has a reg or ranges property, but no unit name
Warning (unit_address_vs_reg): Node /clocks@e0110000/usib_u1_sclk has a reg or ranges property, but no unit name
Warning (unit_address_vs_reg): Node /clocks@e0110000/usib_u2_sclk has a reg or ranges property, but no unit name
Warning (unit_address_vs_reg): Node /clocks@e0110000/usib_u3_sclk has a reg or ranges property, but no unit name
Warning (unit_address_vs_reg): Node /clocks@e0110000/sti_sclk has a reg or ranges property, but no unit name
Signed-off-by: Geert Uytterhoeven <geert+renesas@glider.be>
Signed-off-by: Simon Horman <horms+renesas@verge.net.au>
Use GIC_* defines for GIC interrupt cells in emev2 device tree.
Acked-by: Geert Uytterhoeven <geert+renesas@glider.be>
Replace the "arm,cortex-a9-gic" compatible value for the GIC by
"arm,pl390", as the documentation states it is a PL390.
This has been confirmed (thanks Simon!) by reading the GICD_IIDR
register, which reports 0x0000043b (PL390 = 0x00, ARM = 0x43b).
This has no effect on runtime behavior, as currently the GIC driver
treats both compatible values the same.
Signed-off-by: Wolfram Sang <wsa+renesas@sang-engineering.com>
With this information all GPIOs can make use of the PFC functionality.
Signed-off-by: Niklas Söderlund <niso@kth.se>
Acked-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
smu -> clocks
sti -> timer
uart -> serial
All but "clocks" are defined in ePAPR v1.1.
Add CPU Frequency information to the EMEV2 DTS file. This
will allow us to use the shared C code to on EMEV2 which
reads out the clock frequency from DT and calculates the
delay settings from there.
Signed-off-by: Magnus Damm <damm+renesas@opensource.se>
Acked-by: Geert Uytterhoeven <geert@linux-m68k.org>
Interrupts generated by SoC internal devices are currently marked as
IRQ_TYPE_NONE. As they're level-triggered and active-high, mark them as
such.
Signed-off-by: Laurent Pinchart <laurent.pinchart+renesas@ideasonboard.com>
Use the gpio-keys driver to support the 4 pins on the
dip switch DSW2 which is mounted on the KZM9D board.
Signed-off-by: Magnus Damm <damm@opensource.se>
Add minimum clock tree description to .dts file.
This provides same set of clocks as current sh-clkfwk version .c
code does.
Signed-off-by: Takashi Yoshii <takasi-y@ops.dti.ne.jp>
Acked-by: Magnus Damm <damm@opensource.se>
Add PMU information to emev2.dtsi. With this
included KZM9D DT reference may use the PMU.
Add GIO0->GIO4 device nodes to the EMEV2 dtsi file.
Cc: Mark Rutland <mark.rutland@arm.com>
This is EMEV2 DT support V3. The support is limited to
whatever devices that are complied in the kernel. At this
point we have UARTs handled by "em-uart" and a timer
handled by "em-sti". Clocks and SMP are not supported.
