path: root/arch/arm/boot/dts/evk-pro3.dts
2016-07-15ARM: dts: at91: fix i2c-gpio node nameAlexandre Belloni
i2c-gpio doesn't need a reg property. Change the node names to i2c-gpio-x as used in other dts to remove the unit-address. Solves: Warning (unit_address_vs_reg): Node /i2c@0 has a unit name, but no reg property Warning (unit_address_vs_reg): Node /i2c@1 has a unit name, but no reg property Warning (unit_address_vs_reg): Node /i2c@2 has a unit name, but no reg property Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
2016-06-07ARM: dts: at91: at91sam9260: Remove leading zeros in OHCI node.Raashid Muhammed
Remove leading zeros in OHCI node for at91sam9260 based boards. Signed-off-by: Raashid Muhammed <raashidmuhammed@zilogic.com> Reviewed-by: Vijay Kumar B. <vijaykumar@bravegnu.org> Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
2014-07-09ARM: at91/dt: evk-pro3: define slow crytal frequencyAlexandre Belloni
Define Telit EVK-PRO3 slow crystal frequency Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com> Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com>
2013-05-17ARM: at91: dt: switch to standard GPIO flag defines.Jean-Christophe PLAGNIOL-VILLARD
Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com>
2013-05-17ARM: at91: dt: use #include for all device treesJean-Christophe PLAGNIOL-VILLARD
to prepare the switch to the macro. Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com>
2012-11-16ARM: at91/dts: evk-pro3: enable watchdogFabio Porcedda
Tested on evk-pro3. Signed-off-by: Fabio Porcedda <fabio.porcedda@gmail.com> Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com>
2012-11-16ARM: at91: dt: evk-pro3: enable uart0 and uart2Fabio Porcedda
2012-07-09ARM: at91: add support for Telit EVK-PRO3 with Telit GE863-PRO3Fabio Porcedda
