dwmmc driver deprecated num-slots and plan to get rid
of it finally. Just move a step to cleanup it from DT.
Cc: Jaehoon Chung <jh80.chung@samsung.com>
Signed-off-by: Shawn Lin <shawn.lin@rock-chips.com>
Reviewed-by: Jaehoon Chung <jh80.chung@samsung.com>
Signed-off-by: Krzysztof Kozlowski <krzk@kernel.org>
In drivers/mmc/core/host.c, there is a "max-frequency" property.
Behavior should not change, so use the "max-frequency" instead of
"clock-freq-min-max".
Signed-off-by: Jaehoon Chung <jh80.chung@samsung.com>
This patch fixes the following DTC warnings:
"Node /memory has a reg or ranges property, but no unit name"
Signed-off-by: Javier Martinez Canillas <javier@osg.samsung.com>
The skeleton.dtsi file was removed in ARM64 for different reasons as
explained in commit ("3ebee5a2e141 arm64: dts: kill skeleton.dtsi").
These also applies to ARM and it will also allow to get rid of the
following DTC warnings in the future:
The disassembled DTB are almost the same besides an empty chosen
node being removed and nodes reordered, so it should not have
functional changes.
This patch adds the Device Tree source for Samsung ARTIK5 module[1]
based on Exynos3250 SoC. The ARTIK5 module includes the following
devices:
- Application Processor (Samsung Exynos3250)
- WiFi/BT Combo chip (Broadcom4354)
- PMIC (Samsung S2MPS14)
- eMMC (4GB)
- DRAM LPDDR3 (512MB)
- Connectors pin (60 Pins x 3 set)
Also, this patch adds the ARTIK5 evaluation board[2] dts file which includes
the ARTIK5 module[1] and have the devices such as sound codec, sd card port,
ethernet port, uart port and so on.
[1] https://www.artik.io/hardware/artik-5
[2] http://www.digikey.com/product-search/en?FV=ffecca14
Signed-off-by: Chanwoo Choi <cw00.choi@samsung.com>
Signed-off-by: Andi Shyti <andi.shyti@samsung.com>
Acked-by: Rob Herring <robh@kernel.org>
Signed-off-by: Krzysztof Kozlowski <k.kozlowski@samsung.com>
