Usage of DTS macros instead of hard-coded numbers makes code easier to
read. One does not have to remember which value means pull-up/down or
specific driver strength.
Signed-off-by: Krzysztof Kozlowski <k.kozlowski@samsung.com>
Reviewed-by: Javier Martinez Canillas <javier@osg.samsung.com>
Replace duplicated macros in each DTSI file with a common macro coming
from header. Include the header in each pinctrl DTSI so further changes
could use it.
Although PIN_FUNC_SPC_2 does not bring much information about the
function itself, it still is more descriptive then hard-coded
number <2>.
This patch adds the MSHC2 (Mobile Storage Host Controller) Device Tree node for
Exynos3250 SoC.
Signed-off-by: Chanwoo Choi <cw00.choi@samsung.com>
This patch add the UART2 Device Tree node for Exynos3250 SoC.
Signed-off-by: Pankaj Dubey <pankaj.dubey@samsung.com>
This patch adds initial pin configuration using pinctrl subsystem
to reduce leakage power-consumption of gpio pins in normal state.
All pins included in this patch are NC (not connected) pin.
This patch add sleep mode pin configuration using pinctrl subsystem
to reduce leakage power-consumption of gpio pin in sleep state.
Acked-by: Kyungmin Park <kyungmin.park@samsung.com>
Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
This patch adds new exynos3250.dtsi to support Exynos3250 SoC
based on Cortex-A7 dual core and includes following dt nodes:
- GIC interrupt controller
- Pinctrl to control GPIOs
- Clock controller
- CPU information (Cortex-A7 dual core)
- UART to support serial port
- MCT (Multi Core Timer)
- ADC (Analog Digital Converter)
- I2C/SPI bus
- Power domain
- PMU (Performance Monitoring Unit)
- MSHC (Mobile Storage Host Controller)
- PWM (Pluse Width Modulation)
- AMBA bus
- sysram node for SYSRAM memory mapping
Signed-off-by: Tomasz Figa <t.figa@samsung.com>
Signed-off-by: Inki Dae <inki.dae@samsung.com>
Signed-off-by: Hyunhee Kim <hyunhee.kim@samsung.com>
Signed-off-by: Jaehoon Chung <jh80.chung@samsung.com>
Signed-off-by: Bartlomiej Zolnierkiewicz <b.zolnierkie@samsung.com>
Cc: Ben Dooks <ben-linux@fluff.org>
Cc: Kukjin Kim <kgene.kim@samsung.com>
Cc: Rob Herring <robh+dt@kernel.org>
Cc: Pawel Moll <pawel.moll@arm.com>
Cc: Mark Rutland <mark.rutland@arm.com>
Cc: Ian Campbell <ijc+devicetree@hellion.org.uk>
Cc: Kumar Gala <galak@codeaurora.org>
Cc: devicetree@vger.kernel.org
