exynos4210
The pinctrl pull up/down register on exynos4210 is 2-bit wide for each
pin and it accepts only values of 0, 1 and 3. The pins sd4-bus-width8
were configured with value of 4. The driver does not validate the value
so this overflow effectively set a bit 1 in adjacent pins thus
configuring them to pull down.
The author's intention was probably to set drive strength of 4x. All
other bus-widths pins are configured with pull up and drive strength of
4x. Fix this one with same pattern.
Fixes: 87711d8c7c70 ("ARM: dts: Add pinctrl node entries for SAMSUNG EXYNOS4210 SoC")
Signed-off-by: Krzysztof Kozlowski <k.kozlowski@samsung.com>
Reviewed-by: Javier Martinez Canillas <javier@osg.samsung.com>
Reviewed-by: Bartlomiej Zolnierkiewicz <b.zolnierkie@samsung.com>
Usage of DTS macros instead of hard-coded numbers makes code easier to
read. One does not have to remember which value means pull-up/down or
specific driver strength.
Replace duplicated macros in each DTSI file with a common macro coming
from header. Include the header in each pinctrl DTSI so further changes
could use it.
Although PIN_FUNC_SPC_2 does not bring much information about the
function itself, it still is more descriptive then hard-coded
number <2>.
Add pinctrl nodes for the HDMI CEC device to the Exynos4210 and
Exynos4x12 SoCs. These are required by the HDMI CEC device.
Signed-off-by: Kamil Debski <kamil@wypas.org>
Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com>
Add pinctrl nodes for the camera parallel port CAM_A data bus
and the CAM_A_CLKOUT clock output pin.
Signed-off-by: Andrzej Hajda <a.hajda@samsung.com>
Signed-off-by: Sylwester Nawrocki <s.nawrocki@samsung.com>
Reviewed-by: Tomasz Figa <t.figa@samsung.com>
Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
Adds pinctrl entries required by FIMD.
Signed-off-by: Sachin Kamat <sachin.kamat@linaro.org>
Signed-off-by: Tushar Behera <tushar.behera@linaro.org>
PWM nodes are added to EXYNOS4210 pinctrl DT file.
This patch modifies pin control groups of SD pins on EXYNOS4210
and EXYNOS4X12 to use drive strength 3 as a default value which
corresponds to S5P_GPIO_DRVSTR_LV4 in legacy non-DT code.
This is needed at least on Origen board for sdhci2 to work and
if any other drive strength is required on each board, we can
overide it.
Signed-off-by: Tomasz Figa <t.figa@samsung.com>
[kgene.kim@samsung.com: edited commit message]
This patch reworks wake-up interrupt handling in pinctrl-exynos driver,
so each pin bank, which provides wake-up interrupts, has its own IRQ
domain.
Information about whether given pin bank provides wake-up interrupts,
how many and whether they are separate or muxed are parsed from device
tree.
It gives following advantages:
- interrupts can be specified in device tree in a more readable way,
e.g. :
device {
interrupt-parent = <&gpx2>;
interrupts = <4 0>;
- the amount and layout of interrupts is not hardcoded in the code
anymore, but defined in SoC-specific structure
- bank and pin of each wake-up interrupt can be easily identified, to
allow operations, such as setting the pin to EINT function, from
irq_set_type() callback
Reviewed-by: Kyungmin Park <kyungmin.park@samsung.com>
Acked-by: Thomas Abraham <thomas.abraham@linaro.org>
This patch is a preparation for converting the pinctrl-samsung driver to
one GPIO chip and IRQ domain per bank. It allows particular banks to be
specified using their phandles.
Add pinctrl driver nodes for the three instances of pin controllers
in SAMSUNG EXYNOS4210 SoC and add the pin group nodes available in the
each of those three instances.
Signed-off-by: Thomas Abraham <thomas.abraham@linaro.org>
