git://git.kernel.org/pub/scm/linux/kernel/git/krzk/linux into next/dt
Pull "Topic branch for Samsung DeviceTree cleanup for 4.9" from Krzysztof Kozłowski:
Replace in DT sources hard-coded values for pinctrl configuration like pull
up/down, drive strength and function. This makes the DTS easier to read,
especially that some drive strengths values are quite non-obvious.
* tag 'samsung-dt-pinctrl-4.9' of git://git.kernel.org/pub/scm/linux/kernel/git/krzk/linux:
ARM: dts: s3c64xx: Use macros for pinctrl configuration
ARM: dts: s3c2416: Use macros for pinctrl configuration
ARM: dts: s5pv210: Use macros for pinctrl configuration
ARM: dts: s3c64xx: Use common macros for pinctrl configuration
ARM: dts: exynos: Fix mismatched values of SD drive strengh configuration on exynos4415
ARM: dts: exynos: Fix mismatched value for SD4 pull up/down configuration on exynos4210
ARM: dts: exynos: Use macros for pinctrl configuration on exynos542x/exynos5800
ARM: dts: exynos: Use macros for pinctrl configuration on exynos5410
ARM: dts: exynos: Use macros for pinctrl configuration on exynos5260
ARM: dts: exynos: Use macros for pinctrl configuration on exynos5250
ARM: dts: exynos: Use macros for pinctrl configuration on exynos4415
ARM: dts: exynos: Use macros for pinctrl configuration on exynos4x12
ARM: dts: exynos: Use macros for pinctrl configuration on exynos4210
ARM: dts: exynos: Use macros for pinctrl configuration on exynos3250
ARM: dts: exynos: Use common macros for pinctrl configuration
pinctrl: dt-bindings: samsung: Update documentation with new macros
pinctrl: dt-bindings: samsung: Add header with values used for configuration
Usage of DTS macros instead of hard-coded numbers makes code easier to
read. One does not have to remember which value means pull-up/down or
specific driver strength.
Signed-off-by: Krzysztof Kozlowski <k.kozlowski@samsung.com>
Reviewed-by: Javier Martinez Canillas <javier@osg.samsung.com>
This patch fixes the following DTC warnings:
"Node /memory has a reg or ranges property, but no unit name"
Signed-off-by: Javier Martinez Canillas <javier@osg.samsung.com>
Signed-off-by: Krzysztof Kozlowski <krzk@kernel.org>
The skeleton.dtsi file was removed in ARM64 for different reasons as
explained in commit ("3ebee5a2e141 arm64: dts: kill skeleton.dtsi").
These also applies to ARM and it will also allow to get rid of the
following DTC warnings in the future:
The disassembled DTB are almost the same besides an empty chosen
node being removed and nodes reordered, so it should not have
functional changes.
MFC device can be used without any external hardware dependencies (when
IOMMU is enabled), so it can be enabled by default (like it has been
already done for Exynos 542x platforms). This unifies handling of this
device for Exynos3250, Exynos4 and Exynos542x platforms. Board can still
include exynos-mfc-reserved-memory.dtsi to enable using this device
without IOMMU being enabled.
This patch moves assigning reserved memory regions from each board dts
to common exynos-mfc-reserved-memory.dtsi file, where those regions are
defined.
Tested-by: Javier Martinez Canillas <javier@osg.samsung.com>
This patch replaces custom properties for defining reserved memory
regions with generic reserved memory bindings for MFC video codec
device.
Reviewed-by: Krzysztof Kozlowski <k.kozlowski@samsung.com>
[k.kozlowski: Add Samsung copyrights]
Though the keyboard and other driver will continue to support the legacy
"gpio-key,wakeup", "linux-keypad,wakeup" boolean property to enable the
wakeup source, "wakeup-source" is the new standard binding.
This patch replaces all the legacy wakeup properties with the unified
"wakeup-source" property in order to avoid any further copy-paste
duplication.
Signed-off-by: Sudeep Holla <sudeep.holla@arm.com>
G2D device is always available and doesn't depend on any external (board
specific) peripherals, so it can be unconditionally enabled.
The board DTS are using numeric values instead of the defined GPIO
constanst to express polarity, use them to make the DTS more clear.
Signed-off-by: Kukjin Kim <kgene@kernel.org>
Usage of labels instead of full paths reduces possible mistakes when
overriding nodes.
Signed-off-by: Krzysztof Kozlowski <k.kozlowski.k@gmail.com>
This patch adds stdout-path property to chosen nodes of Exynos4 boards
to enable use of earlycon feature without the need to hardcode port
number in kernel itself.
Signed-off-by: Tomasz Figa <t.figa@samsung.com>
This patch replaces the "cs-gpio" from "controller-data" node
as was specified in the old binding and uses the standard
"cs-gpios" property expected by the SPI core as is defined now
in the spi-s3c64xx driver DT binding.
Signed-off-by: Naveen Krishna Chatradhi <ch.naveen@samsung.com>
Reviewed-by: Javier Martinez Canillas <javier.martinez@collabora.co.uk>
Reviewed-by: Tomasz Figa <t.figa@samsung.com>
Signed-off-by: Mark Brown <broonie@linaro.org>
Add generic compatible strings to the respective board DT files.
Signed-off-by: Sachin Kamat <sachin.kamat@linaro.org>
Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
Replace /include/ (dtc) with #include (C pre-processor) for all
Samsung DT files
Signed-off-by: Padmavathi Venna <padma.v@samsung.com>
Reviewed-by: Sylwester Nawrocki <s.nawrocki@samsung.com>
Reviewed-by: Doug Anderson <dianders@chromium.org>
Add default pin state information for all client nodes that require
pin configuration support using pinctrl interface.
Signed-off-by: Thomas Abraham <thomas.abraham@linaro.org>
Added G2D DT node to SMDKV310 board.
The clock frequency of xxti and xusbxti clocks is dependent on the
frequency of the on-board oscillator that is used to generate these
clocks. So allow the frequency of these clocks to be specfied from
device tree.
This patch adds status override of serial nodes to enable used
serial ports on Origen and SMDKV310 board.
Cc: Thomas Abraham <thomas.abraham@linaro.org>
Currently all boards must explicitly disable all unused device tree
nodes of unused components (e.g. i2c, sdhci, etc...). This makes it
necessary to all boards to be aware of all components on the SoC, which
in turns makes board dts files longer and more difficult to maintain
(e.g. adding new components to SoC-level tree requires adding nodes with
status="disabled" to every board).
This patch changes "status" of all optional components in SoC-level dts
file to "disabled", adds status="okay" to respective nodes of used
components in dts of all boards and removes all nodes with only
status="disabled" from boards dts.
Acked-by: Thomas Abraham <thomas.abraham@linaro.org>
Add device nodes for the three instances of spi controllers in
EXYNOS4 platforms. Enable instance SPI 2 for SMDKV310 board and
disable all spi instances for Origen board.
Add initial dts file for EXYNOS4210 SoC. This dts file describes
the SoC specific devices and properties. Along with this, add dts
file for Samsung's SMDKV310 board and Insignal's ORIGEN board which
uses the EXYNOS4210 dts file and extends it to describe the board
specific properties.
