This patch fixes the following DTC warnings:
"Node /memory has a reg or ranges property, but no unit name"
Signed-off-by: Javier Martinez Canillas <javier@osg.samsung.com>
Signed-off-by: Krzysztof Kozlowski <krzk@kernel.org>
The skeleton.dtsi file was removed in ARM64 for different reasons as
explained in commit ("3ebee5a2e141 arm64: dts: kill skeleton.dtsi").
These also applies to ARM and it will also allow to get rid of the
following DTC warnings in the future:
The disassembled DTB are almost the same besides an empty chosen
node being removed and nodes reordered, so it should not have
functional changes.
MAX8997 PMIC requires interrupt and fails probing without it.
Fixes: d105f0b1215d ("ARM: dts: Add basic dts file for Samsung Trats board")
Cc: <stable@vger.kernel.org>
[k.kozlowski: Write commit message, add CC-stable]
Signed-off-by: Krzysztof Kozlowski <k.kozlowski@samsung.com>
exynos4210-trats
The usage of slash character causes failure when creating regulator
debugfs entry.
[k.kozlowski: Write commit message]
Though the keyboard and other driver will continue to support the legacy
"gpio-key,wakeup", "linux-keypad,wakeup" boolean property to enable the
wakeup source, "wakeup-source" is the new standard binding.
This patch replaces all the legacy wakeup properties with the unified
"wakeup-source" property in order to avoid any further copy-paste
duplication.
Reviewed-by: Krzysztof Kozlowski <k.kozlowski@samsung.com>
Signed-off-by: Sudeep Holla <sudeep.holla@arm.com>
exynos4412 boards
Exynos USB2 PHY driver now supports VBUS regulator, so add it to all
boards which have it available. This also fixes commit
7eec1266751b ("ARM: dts: Add Maxim 77693 PMIC to exynos4412-trats2"),
which added new regulators to Trats2 board, but without linking them to
the consumers.
Fixes: 7eec1266751b ("ARM: dts: Add Maxim 77693 PMIC to exynos4412-trats2")
Signed-off-by: Kukjin Kim <kgene@kernel.org>
The board DTS are using numeric values instead of the defined GPIO
constanst to express polarity, use them to make the DTS more clear.
For Exynos4210 platforms, add CPU operating points and CPU regulator
supply properties for migrating from Exynos specific cpufreq driver
to using generic cpufreq driver.
Cc: Doug Anderson <dianders@chromium.org>
Cc: Andreas Faerber <afaerber@suse.de>
Cc: Sachin Kamat <sachin.kamat@linaro.org>
Cc: Andreas Farber <afaerber@suse.de>
Cc: Javier Martinez Canillas <javier.martinez@collabora.co.uk>
Signed-off-by: Thomas Abraham <thomas.ab@samsung.com>
[b.zolnierkie: removed exynos5250 and exynos5420 support for now]
Signed-off-by: Bartlomiej Zolnierkiewicz <b.zolnierkie@samsung.com>
[k.kozlowski: Rebased, moved cpu nodes to alphabetical position]
Usage of labels instead of full paths reduces possible mistakes when
overriding nodes.
Signed-off-by: Krzysztof Kozlowski <k.kozlowski.k@gmail.com>
Presented patch aims to move data necessary for correct CPU cooling device
configuration from exynos_tmu_data.c to device tree.
Signed-off-by: Lukasz Majewski <l.majewski@samsung.com>
Acked-by: Eduardo Valentin <edubezval@gmail.com>
The thermal IP block (Thermal Management Unit) called TMU has been
enabled in this device.
Pull ARM SoC DT updates from Olof Johansson:
"DT changes continue to be the bulk of our merge window contents.
We continue to have a large set of changes across the board as new
platforms and drivers are added.
Some of the new platforms are:
- Alphascale ASM9260
- Marvell Armada 388
- CSR Atlas7
- TI Davinci DM816x
- Hisilicon HiP01
- ST STiH418
There have also been some sweeping changes, including relicensing of
DTS contents from GPL to GPLv2+/X11 so that the same files can be
reused in other non-GPL projects more easily. There's also been
changes to the DT Makefile to make it a little less conflict-ridden
and churny down the road"
* tag 'dt-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (330 commits)
ARM: dts: Add PPMU node for exynos4412-trats2
ARM: dts: Add PPMU node for exynos3250-monk and exynos3250-rinato
ARM: dts: Add PPMU dt node for exynos4 and exynos4210
ARM: dts: Add PPMU dt node for exynos3250
ARM: dts: add mipi dsi device node for exynos4415
ARM: dts: add fimd device node for exynos4415
ARM: dts: Add syscon phandle to the video-phy node for Exynos4
ARM: dts: Add sound nodes for exynos4412-trats2
ARM: dts: Fix CLK_MOUT_CAMn parent clocks assignment for exynos4412-trats2
ARM: dts: Fix CLK_UART_ISP_SCLK clock assignment in exynos4x12.dtsi
ARM: dts: Add max77693 charger node for exynos4412-trats2
ARM: dts: Switch max77686 regulators to GPIO control for exynos4412-trats2
ARM: dts: Add suspend configuration for max77686 regulators for exynos4412-trats2
ARM: dts: Add Maxim 77693 fuel gauge node for exynos4412-trats2
ARM: dts: am57xx-beagle-x15: Fix USB2 mode
ARM: dts: am57xx-beagle-x15: Add extcon nodes for USB
ARM: dts: dra72-evm: Add extcon nodes for USB
ARM: dts: dra7-evm: Add extcon nodes for USB
ARM: dts: rockchip: move the hdmi ddc-i2c-bus property to the actual boards
ARM: dts: rockchip: enable vops and hdmi output on rk3288-firefly and -evb
This patch adds stdout-path property to chosen nodes of Exynos4 boards
to enable use of earlycon feature without the need to hardcode port
number in kernel itself.
Signed-off-by: Tomasz Figa <t.figa@samsung.com>
All currently supported boards use hsotg/dwc2 controller in device
('peripheral') mode, so add property which sets correct operation mode.
This patch fixes support in recent changes in dwc2 driver, which added
support for dual-role devices.
Suggested-by: Paul Zimmerman <paulz@synopsys.com>
Specify the default mux and divider clocks in device tree
to ensure the FIMC devices on Trats, Trats2, Universal_c210
and Odroid X2/U3 boards are clocked from recommended clock
source and with maximum supported frequency.
For Trats2 also the MIPI-CSIS and the camera sensor clocks
are configured, the 'clock-frequency' property is deprecated
in favour of 'assigned-clock-rates' property.
Signed-off-by: Sylwester Nawrocki <s.nawrocki@samsung.com>
Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
This patch adds device tree nodes necessary to enable USB
gadget functionality on Exynos4210-based Trats board.
Pull drm updates from Dave Airlie:
"Highlights:
- drm:
Generic display port aux features, primary plane support, drm
master management fixes, logging cleanups, enforced locking checks
(instead of docs), documentation improvements, minor number
handling cleanup, pseudofs for shared inodes.
- ttm:
add ability to allocate from both ends
- i915:
broadwell features, power domain and runtime pm, per-process
address space infrastructure (not enabled)
- msm:
power management, hdmi audio support
- nouveau:
ongoing GPU fault recovery, initial maxwell support, random fixes
- exynos:
refactored driver to clean up a lot of abstraction, DP support
moved into drm, LVDS bridge support added, parallel panel support
- gma500:
SGX MMU support, SGX irq handling, asle irq work fixes
- radeon:
video engine bringup, ring handling fixes, use dp aux helpers
- vmwgfx:
add rendernode support"
* 'drm-next' of git://people.freedesktop.org/~airlied/linux: (849 commits)
DRM: armada: fix corruption while loading cursors
drm/dp_helper: don't return EPROTO for defers (v2)
drm/bridge: export ptn3460_init function
drm/exynos: remove MODULE_DEVICE_TABLE definitions
ARM: dts: exynos4412-trats2: enable exynos/fimd node
ARM: dts: exynos4210-trats: enable exynos/fimd node
ARM: dts: exynos4412-trats2: add panel node
ARM: dts: exynos4210-trats: add panel node
ARM: dts: exynos4: add MIPI DSI Master node
drm/panel: add S6E8AA0 driver
ARM: dts: exynos4210-universal_c210: add proper panel node
drm/panel: add ld9040 driver
panel/ld9040: add DT bindings
panel/s6e8aa0: add DT bindings
drm/exynos: add DSIM driver
exynos/dsim: add DT bindings
drm/exynos: disallow fbdev initialization if no device is connected
drm/mipi_dsi: create dsi devices only for nodes with reg property
drm/mipi_dsi: add flags to DSI messages
Skip intel_crt_init for Dell XPS 8700
The patch changes fimd node status to OK.
Signed-off-by: Andrzej Hajda <a.hajda@samsung.com>
Signed-off-by: Inki Dae <inki.dae@samsung.com>
The patch adds s6e8aa0 panel node for trats.
It adds also trats specific properties for DSI.
Add generic compatible strings to the respective board DT files.
Signed-off-by: Sachin Kamat <sachin.kamat@linaro.org>
and trats boards
Exynos cpufreq drivers does not support device tree based regulator
lookup, so it can get the VDD ARM regulator only by its name. To get
cpufreq working for now, this patch works this around by renaming the
regulator in board dts files to vdd_arm, which is the name expected by
the driver.
This fixes a regression introduced by dropping support of board file
based bootup of Exynos 4210 boards that rendered cpufreq inoperable on
Trats and Origen boards.
Add MAX8998 LDO12 and fixed voltage regulator nodes. While at it,
all fixed voltage regulator nodes are grouped in a 'regulators' node.
Reviewed-by: Tomasz Figa <t.figa@samsung.com>
Enable FIMC devices on the Trats board. This allows using the
device in memory-to-memory mode only. The camera port pinctrl
property is now empty and will be updated while support for the
camera sensors is added.
Replace /include/ (dtc) with #include (C pre-processor) for all
Samsung DT files
Signed-off-by: Padmavathi Venna <padma.v@samsung.com>
Reviewed-by: Sylwester Nawrocki <s.nawrocki@samsung.com>
Reviewed-by: Doug Anderson <dianders@chromium.org>
The clock frequency of xxti and xusbxti clocks is dependent on the
frequency of the on-board oscillator that is used to generate these
clocks. So allow the frequency of these clocks to be specfied from
device tree.
Signed-off-by: Thomas Abraham <thomas.abraham@linaro.org>
The broken voltage property has been replaced with auto detection based
on voltages available on vmmc voltage regulator, so there is no use for
it now.
This patch removes the now unused property from Trats Device Tree
sources.
This patch adds a device tree node for the Melfas MMS114-controlled
touchscreen present on Samsung Trats board.
This patch adds device tree node for a fixed voltage regulator used for
touchscreen on Samsung Trats board.
This patch adds device tree node for i2c3 bus to device tree source
of Samsung Trats board. This bus is used by mms114 touchscreen
controller, for which support will be added in separate patch.
This patch extends dts file of Samsung Trats board to add support for
available GPIO keys using gpio-keys driver.
This patch updates all parts of Trats dts related to pin configuration
to use new GPIO and pinctrl bindings, instead of (now unsupported on
Exynos4) legacy gpio-samsung bindings.
Since the maximum section size on mach-exynos is set to 256MiB, boards
with memory configuration defined using sections bigger than 256MiB will
fail to boot with a kernel panic.
This patch modifies the dts file of Samsung Trats board to define four
sections of 256MiB instead of two of 512MiB to fix the boot problem.
This commit adds basic device tree for Exynos4210-based Trats board.
Currently it provides support for eMMC over sdhci and MAX8997 PMIC.
Reviewed-by: Thomas Abraham <thomas.abraham@linaro.org>
