2017-07-18 | ARM: dts: exynos: Remove num-slots from exynos platforms | Shawn Lin | |
dwmmc driver deprecated num-slots and plan to get rid of it finally. Just move a step to cleanup it from DT. Cc: Jaehoon Chung <jh80.chung@samsung.com> Signed-off-by: Shawn Lin <shawn.lin@rock-chips.com> Reviewed-by: Jaehoon Chung <jh80.chung@samsung.com> Signed-off-by: Krzysztof Kozlowski <krzk@kernel.org> | |||
2017-03-13 | ARM: dts: exynos: Enable watchdog on all Exynos4 boards | Krzysztof Kozlowski | |
Watchdog module does not have external dependencies so it can be safely enabled in exynos4.dtsi thus making it available for all Exynos4-based boards. Signed-off-by: Krzysztof Kozlowski <krzk@kernel.org> Acked-by: Guenter Roeck <linux@roeck-us.net> | |||
2016-10-18 | ARM: dts: exynos: Add TOPEET itop core board SCP package version | Randy Li | |
The TOPEET itop is a Samsung Exynos4412 core board, which has two package versions. This patch adds the support for SCP version. Currently supported are USB3503A HSIC, USB OTG, eMMC, RTC and PMIC. The future features are in the based board. Also MFC and watchdog have been enabled. Signed-off-by: Randy Li <ayaka@soulik.info> [krzk: fixup pin function macro, adjust commit msg] Signed-off-by: Krzysztof Kozlowski <krzk@kernel.org> |
