commit ec33745bccc8f336957c751f4153421cc9ef5a54 upstream.
Commit 225da7e65a03 ("ARM: dts: add eMMC reset line for
exynos4412-odroid-common") added MMC power sequence for eMMC card of
Odroid X2/U3. It reused generic sd1_cd pin control configuration node
and only disabled pull-up. However that time the pinctrl configuration
was not applied during MMC power sequence driver initialization. This
has been changed later by commit d97a1e5d7cd2 ("mmc: pwrseq: convert to
proper platform device").
It turned out then, that the provided pinctrl configuration is not
correct, because the eMMC_RTSN line is being re-configured as 'special
function/card detect function for mmc1 controller' not the simple
'output', thus the power sequence driver doesn't really set the pin
value. This in effect broke the reboot of Odroid X2/U3 boards. Fix this
by providing separate node with eMMC_RTSN pin configuration.
Cc: <stable@vger.kernel.org>
Reported-by: Markus Reichl <m.reichl@fivetechno.de>
Suggested-by: Ulf Hansson <ulf.hansson@linaro.org>
Fixes: 225da7e65a03 ("ARM: dts: add eMMC reset line for exynos4412-odroid-common")
Signed-off-by: Krzysztof Kozlowski <krzk@kernel.org>
[ Upstream commit 80b7a2e2498bcffb1a79980dfbeb7a1275577b28 ]
Add CPU operating points for Exynos4412 Prime (it supports
additional 1704MHz & 1600MHz OPPs and 1500MHz OPP is just
a regular non-turbo OPP on this SoC). Also update relevant
cooling maps to account for new OPPs.
ODROID-X2/U2/U3 boards use Exynos4412 Prime SoC version so
update their board files accordingly.
Based on Hardkernel's kernel for ODROID-X2/U2/U3 boards.
Cc: Doug Anderson <dianders@chromium.org>
Cc: Andreas Faerber <afaerber@suse.de>
Cc: Thomas Abraham <thomas.ab@samsung.com>
Cc: Tobias Jakobi <tjakobi@math.uni-bielefeld.de>
Cc: Ben Gamari <ben@smart-cactus.org>
Signed-off-by: Bartlomiej Zolnierkiewicz <b.zolnierkie@samsung.com>
git://git.kernel.org/pub/scm/linux/kernel/git/krzk/linux into next/dt
Pull "Topic branch for Samsung DeviceTree cleanup for 4.9" from Krzysztof Kozłowski:
Replace in DT sources hard-coded values for pinctrl configuration like pull
up/down, drive strength and function. This makes the DTS easier to read,
especially that some drive strengths values are quite non-obvious.
* tag 'samsung-dt-pinctrl-4.9' of git://git.kernel.org/pub/scm/linux/kernel/git/krzk/linux:
ARM: dts: s3c64xx: Use macros for pinctrl configuration
ARM: dts: s3c2416: Use macros for pinctrl configuration
ARM: dts: s5pv210: Use macros for pinctrl configuration
ARM: dts: s3c64xx: Use common macros for pinctrl configuration
ARM: dts: exynos: Fix mismatched values of SD drive strengh configuration on exynos4415
ARM: dts: exynos: Fix mismatched value for SD4 pull up/down configuration on exynos4210
ARM: dts: exynos: Use macros for pinctrl configuration on exynos542x/exynos5800
ARM: dts: exynos: Use macros for pinctrl configuration on exynos5410
ARM: dts: exynos: Use macros for pinctrl configuration on exynos5260
ARM: dts: exynos: Use macros for pinctrl configuration on exynos5250
ARM: dts: exynos: Use macros for pinctrl configuration on exynos4415
ARM: dts: exynos: Use macros for pinctrl configuration on exynos4x12
ARM: dts: exynos: Use macros for pinctrl configuration on exynos4210
ARM: dts: exynos: Use macros for pinctrl configuration on exynos3250
ARM: dts: exynos: Use common macros for pinctrl configuration
pinctrl: dt-bindings: samsung: Update documentation with new macros
pinctrl: dt-bindings: samsung: Add header with values used for configuration
Usage of DTS macros instead of hard-coded numbers makes code easier to
read. One does not have to remember which value means pull-up/down or
specific driver strength.
Signed-off-by: Krzysztof Kozlowski <k.kozlowski@samsung.com>
Reviewed-by: Javier Martinez Canillas <javier@osg.samsung.com>
This patch enables getting a HPD GPIO descriptor quicker.
The exynos-hdmi driver uses "hpd" for HDMI hot plug detection.
static int hdmi_resources_init(struct hdmi_context *hdata)
hdata->hpd_gpio = devm_gpiod_get(dev, "hpd", GPIOD_IN);
This calls 'of_find_gpio()' and it generates the GPIO consumer ID by referring
GPIO suffix. So 'hpd-gpios' is preferred on getting a GPIO descriptor.
However, if the device tree uses 'hpd-gpio', then the exynos-hdmi driver
always retries to get a GPIO descriptor because the first GPIO suffix is not
'gpio' but 'gpios'. So you always see the debug message below.
of_get_named_gpiod_flags: can't parse 'hpd-gpios' property of node '/soc/hdmi@14530000[0]'
Use the preferred property, 'hpd-gpios' instead of 'hpd-gpio'.
Acked-by: Rob Herring <robh@kernel.org>
Reviewed-by: Andrzej Hajda <a.hajda@samsung.com>
Cc: devicetree@vger.kernel.org
Cc: linux-samsung-soc@vger.kernel.org
Signed-off-by: Milo Kim <woogyom.kim@gmail.com>
Topic branch for Exynos MFC changes for v4.8, part 2:
Replace hardcoded reserved memory ranges with auto-allocated ones
and enable MFC for all boards.
* tag 'samsung-drivers-exynos-mfc-4.8-2' of git://git.kernel.org/pub/scm/linux/kernel/git/krzk/linux:
ARM: dts: exynos: enable MFC device for all boards
ARM: dts: exynos: move MFC reserved memory regions from boards to .dtsi
ARM: dts: exynos: replace hardcoded reserved memory ranges with auto-allocated ones
ARM: dts: exynos: Enable MFC device on Exynos4412 Odroid boards
ARM: dts: exynos: Convert MFC device to generic reserved memory bindings
ARM: EXYNOS: Remove code for MFC custom reserved memory handling
media: s5p-mfc: add iommu support
media: s5p-mfc: replace custom reserved memory handling code with generic one
media: s5p-mfc: use generic reserved memory bindings
of: reserved_mem: add support for using more than one region for given device
media: set proper max seg size for devices on Exynos SoCs
media: vb2-dma-contig: add helper for setting dma max seg size
s5p-mfc: Fix race between s5p_mfc_probe() and s5p_mfc_open()
s5p-mfc: Add release callback for memory region devs
s5p-mfc: Set device name for reserved memory region devs
MFC device can be used without any external hardware dependencies (when
IOMMU is enabled), so it can be enabled by default (like it has been
already done for Exynos 542x platforms). This unifies handling of this
device for Exynos3250, Exynos4 and Exynos542x platforms. Board can still
include exynos-mfc-reserved-memory.dtsi to enable using this device
without IOMMU being enabled.
This patch moves assigning reserved memory regions from each board dts
to common exynos-mfc-reserved-memory.dtsi file, where those regions are
defined.
Tested-by: Javier Martinez Canillas <javier@osg.samsung.com>
Enable support for Multimedia Codec (MFC) device for all Exynos4412-based
Odroid boards.
Odroid X/X2/U3 schematics say that SD card vmmc regulator
(LDO21/TFLASH) operates on 2.8 V. Mainline U-Boot uses that value as
well and 2.8 V is common on Exynos-based boards. Additionally use some
descriptive name for this regulator.
The eMMC card vmmc-supply contained incorrectly two regulators: LDO20
and buck8. The second one is ignored. Additionally the buck8 is a vqmmc
supply only on X and X2. On U3 the buck8 is providing power to the LAN
(SMSC95xx) so instead the LDO22 should be used.
Fix this by defining proper vmmc and vqmmc supplies for respective
boards.
Odroid X/X2/U3
The SD-card vmmc-supply contained incorrectly two regulators. The second
one is ignored. Fix this by defining proper vmmc and vqmmc supplies.
Additionally these regulators do not have to be always on, so allow
disabling them to reduce energy consumption.
Pull ARM SoC late DT updates from Arnd Bergmann:
"This is a collection of a few late fixes and other misc stuff that had
dependencies on things being merged from other trees.
The Renesas R-Car power domain handling, and the Nvidia Tegra USB
support both hand notable changes that required changing the DT
binding in a way that only provides compatibility with old DT blobs on
new kernels but not vice versa. As a consequence, the DT changes are
based on top of the driver changes and are now in this branch.
For NXP i.MX and Samsung Exynos, the changes in here depend on other
changes that got merged through the clk maintainer tree"
* tag 'armsoc-late' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (35 commits)
ARM: dts: exynos: Add support of Bus frequency using VDD_INT for exynos5422-odroidxu3
ARM: dts: exynos: Add bus nodes using VDD_INT for Exynos542x SoC
ARM: dts: exynos: Add NoC Probe dt node for Exynos542x SoC
ARM: dts: exynos: Add support of bus frequency for exynos4412-trats/odroidu3
ARM: dts: exynos: Expand the voltage range of buck1/3 regulator for exynos4412-odroidu3
ARM: dts: exynos: Add support of bus frequency using VDD_INT for exynos3250-rinato
ARM: dts: exynos: Add exynos4412-ppmu-common dtsi to delete duplicate PPMU nodes
ARM: dts: exynos: Add bus nodes using VDD_MIF for Exynos4210
ARM: dts: exynos: Add bus nodes using VDD_INT for Exynos4x12
ARM: dts: exynos: Add bus nodes using VDD_MIF for Exynos4x12
ARM: dts: exynos: Add bus nodes using VDD_INT for Exynos3250
ARM: dts: exynos: Add DMC bus frequency for exynos3250-rinato/monk
ARM: dts: exynos: Add DMC bus node for Exynos3250
ARM: tegra: Enable XUSB on Nyan
ARM: tegra: Enable XUSB on Jetson TK1
ARM: tegra: Enable XUSB on Venice2
ARM: tegra: Add Tegra124 XUSB controller
ARM: tegra: Move Tegra124 to the new XUSB pad controller binding
ARM: dts: r8a7794: Use SYSC "always-on" PM Domain
ARM: dts: r8a7793: Use SYSC "always-on" PM Domain
This patch adds the bus device tree nodes for both MIF (Memory) and INT
(Internal) block to enable the bus frequency.
The DMC bus is parent device in MIF block using VDD_MIF and the LEFTBUS
bus is parent device in INT block using VDD_INT.
Signed-off-by: Chanwoo Choi <cw00.choi@samsung.com>
Reviewed-by: Krzysztof Kozlowski <k.kozlowski@samsung.com>
[m.reichl and linux.amoon: Tested it on exynos4412-odroidu3 board]
Tested-by: Markus Reichl <m.reichl@fivetechno.de>
Tested-by: Anand Moon <linux.amoon@gmail.com>
exynos4412-odroidu3
This patch expands the voltage range of buck1/3 regulator due to as following:
- MIF (Memory Interface) bus frequency needs the range of '900 - 1100 mV'.
- INT (Internal) bus frequency needs the range of '900 - 1050 mV'.
This patch adds the exynos4412-ppmu-common.dtsi to remove duplicate PPMU nodes
because exynos3250-rinato/monk, exynos4412-trats2/odroidu3 has the same
PPMU device tree node.
There is no external dependency for Security SubSystem (SSS) block so
the nodes for Pseudo Random Number Generator and AES hardware
acceleration can be enabled always for all Exynos4 devices.
Suggested-by: Marek Szyprowski <m.szyprowski@samsung.com>
Add a dts node entry and enable the HDMI CEC device present in the Exynos4
family of SoCs.
Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com>
[k.kozlowski: Put the node in alphabetical order]
Enable the Security SubSystem (SSS) on Exynos4412-based Odroid boards
to provide hardware acceleration for AES operations.
Suggested-by: Tobias Jakobi <tjakobi@math.uni-bielefeld.de>
Tested-by: Tobias Jakobi <tjakobi@math.uni-bielefeld.de>
Though the keyboard and other driver will continue to support the legacy
"gpio-key,wakeup", "linux-keypad,wakeup" boolean property to enable the
wakeup source, "wakeup-source" is the new standard binding.
This patch replaces all the legacy wakeup properties with the unified
"wakeup-source" property in order to avoid any further copy-paste
duplication.
Signed-off-by: Sudeep Holla <sudeep.holla@arm.com>
G2D device is always available and doesn't depend on any external (board
specific) peripherals, so it can be unconditionally enabled.
The board DTS are using numeric values instead of the defined GPIO
constanst to express polarity, use them to make the DTS more clear.
Signed-off-by: Javier Martinez Canillas <javier@osg.samsung.com>
Signed-off-by: Kukjin Kim <kgene@kernel.org>
Use 'ldoN_reg: LDON' syntax and drop the deprecated
'regulator-compatible' property.
Signed-off-by: Tobias Jakobi <tjakobi@math.uni-bielefeld.de>
The pinctrl settings in i2c_0 and i2c_1 are already provided
through the exynos4 dtsi.
For Exynos4x12 platforms, add CPU operating points (using
opp-v2 bindings) and CPU regulator supply properties for
migrating from Exynos specific cpufreq driver to using
generic cpufreq driver.
Based on the earlier work by Thomas Abraham.
Acked-by: Viresh Kumar <viresh.kumar@linaro.org>
Tested-by: Krzysztof Kozlowski <k.kozlowski@samsung.com>
Usage of labels instead of full paths reduces possible mistakes when
overriding nodes.
Signed-off-by: Krzysztof Kozlowski <k.kozlowski.k@gmail.com>
For thermal zones:
Acked-by: Eduardo Valentin <edubezval@gmail.com>
The Exynos4412 SoC has a s3c6410 RTC where the source clock
is now a mandatory property.
This patch fixes probe failure of s3c-rtc on Odroid-X2/U2/U3 boards.
Signed-off-by: Markus Reichl <m.reichl@fivetechno.de>
Reviewed-by: Chanwoo Choi <cw00.choi@samsung.com>
Reviewed-by: Javier Martinez Canillas <javier.martinez@collabora.co.uk>
git://git.kernel.org/pub/scm/linux/kernel/git/kgene/linux-samsung into next/dt
Merge "Samsung DT updates for v4.1" from Kukjin Kim:
- for exynos3250
: add assigned clock parents for CMU nodes
- for exynos4412-odroid
- for exynos5250
: fixed typo for interrupt-cells
- for exynos5250-snow
: define stdout-path property
: represent bridge and panel connection
: enable wifi power-on and add cap-sdio-irq to wifi mmc node
- for exynos5250-spring
- for exynos5420
: add async-bridge clocks for gsc and disp1 PDs
- for exynos5420 boards
: Mux XMMCnDATA[0] pad correctly
- for exynos5420-odroidxu3
- for Peach boards
: add HS400 support and define stdout-path property
: add mclk entry and add WiFi module support
* tag 'samsung-dt' of git://git.kernel.org/pub/scm/linux/kernel/git/kgene/linux-samsung:
ARM: dts: Fixed typo interrupt-cells for exynos5420 and exynos5250
ARM: dts: Add HS400 support for exynos5420 and exynos5800
ARM: dts: add async-bridge clocks to gsc power domain for exynos5420
ARM: dts: add async-bridge clocks to disp1 power domain for exynos5420
dt-bindings: add asynchronous bridge clock for exynos
ARM: dts: Define stdout-path property for exynos5250-spring
ARM: dts: Define stdout-path property for exynos5250-snow
ARM: dts: Define stdout-path property for Peach boards
ARM: dts: Add assigned clock parents to CMU node for exynos3250
ARM: dts: Add mclk entry for Peach boards
ARM: dts: Add WiFi module support for Peach boards
ARM: dts: Mux XMMCnDATA[0] pad correctly for Exynos5420 boards
ARM: dts: add eMMC reset line for exynos5422-odroidxu3
ARM: dts: represent bridge and panel connection for exynos5420-peach-pit
ARM: dts: represent bridge and panel connection for exynos5250-snow
ARM: dts: Add cap-sdio-irq to wifi mmc node for exynos5250-snow
ARM: dts: Enable wifi power-on for exynos5250-snow
This patch adds nodes specific to Exynos4412 based Odroid X/X2/U2/U3
boards required for enabling HDMI display.
Presented patch aims to move data necessary for correct CPU cooling device
configuration from exynos_tmu_data.c to device tree.
Signed-off-by: Lukasz Majewski <l.majewski@samsung.com>
This commit enables TMU IP block on the Exynos4412 Odroid based
devices such as Odroid U3.
This patch adds LDO10 regulator node for TMU.
This patch adds reset-gpios property to the eMMC slot, so the MMC driver
is able to properly reset eMMC card on system restart and thus fixes
system hang on software reboot.
Pull ARM SoC DT updates from Olof Johansson:
"DT changes continue to be the bulk of our merge window contents.
We continue to have a large set of changes across the board as new
platforms and drivers are added.
Some of the new platforms are:
- Alphascale ASM9260
- Marvell Armada 388
- CSR Atlas7
- TI Davinci DM816x
- Hisilicon HiP01
- ST STiH418
There have also been some sweeping changes, including relicensing of
DTS contents from GPL to GPLv2+/X11 so that the same files can be
reused in other non-GPL projects more easily. There's also been
changes to the DT Makefile to make it a little less conflict-ridden
and churny down the road"
* tag 'dt-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (330 commits)
ARM: dts: Add PPMU node for exynos4412-trats2
ARM: dts: Add PPMU node for exynos3250-monk and exynos3250-rinato
ARM: dts: Add PPMU dt node for exynos4 and exynos4210
ARM: dts: Add PPMU dt node for exynos3250
ARM: dts: add mipi dsi device node for exynos4415
ARM: dts: add fimd device node for exynos4415
ARM: dts: Add syscon phandle to the video-phy node for Exynos4
ARM: dts: Add sound nodes for exynos4412-trats2
ARM: dts: Fix CLK_MOUT_CAMn parent clocks assignment for exynos4412-trats2
ARM: dts: Fix CLK_UART_ISP_SCLK clock assignment in exynos4x12.dtsi
ARM: dts: Add max77693 charger node for exynos4412-trats2
ARM: dts: Switch max77686 regulators to GPIO control for exynos4412-trats2
ARM: dts: Add suspend configuration for max77686 regulators for exynos4412-trats2
ARM: dts: Add Maxim 77693 fuel gauge node for exynos4412-trats2
ARM: dts: am57xx-beagle-x15: Fix USB2 mode
ARM: dts: am57xx-beagle-x15: Add extcon nodes for USB
ARM: dts: dra72-evm: Add extcon nodes for USB
ARM: dts: dra7-evm: Add extcon nodes for USB
ARM: dts: rockchip: move the hdmi ddc-i2c-bus property to the actual boards
ARM: dts: rockchip: enable vops and hdmi output on rk3288-firefly and -evb
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty
Pull tty/serial driver patches from Greg KH:
"Here's the big tty/serial driver update for 3.20-rc1. Nothing huge
here, just lots of driver updates and some core tty layer fixes as
well. All have been in linux-next with no reported issues"
* tag 'tty-3.20-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty: (119 commits)
serial: 8250: Fix UART_BUG_TXEN workaround
serial: driver for ETRAX FS UART
tty: remove unused variable sprop
serial: of-serial: fetch line number from DT
serial: samsung: earlycon support depends on CONFIG_SERIAL_SAMSUNG_CONSOLE
tty/serial: serial8250_set_divisor() can be static
tty/serial: Add Spreadtrum sc9836-uart driver support
Documentation: DT: Add bindings for Spreadtrum SoC Platform
serial: samsung: remove redundant interrupt enabling
tty: Remove external interface for tty_set_termios()
serial: omap: Fix RTS handling
serial: 8250_omap: Use UPSTAT_AUTORTS for RTS handling
serial: core: Rework hw-assisted flow control support
tty/serial: 8250_early: Add support for PXA UARTs
tty/serial: of_serial: add support for PXA/MMP uarts
tty/serial: of_serial: add DT alias ID handling
serial: 8250: Prevent concurrent updates to shadow registers
serial: 8250: Use canary to restart console after suspend
serial: 8250: Refactor XR17V35X divisor calculation
serial: 8250: Refactor divisor programming
Now when the CDCLK I2S output clock can be handled through the clock
API the Odroid X2/U3 can be switched to the simple-audio-card DT binding.
Signed-off-by: Sylwester Nawrocki <s.nawrocki@samsung.com>
Signed-off-by: Mark Brown <broonie@kernel.org>
Clock related properties are added to the Exynos4 I2S device nodes
so they can be referred to as clock providers. Missing i2s_opclk1
clock is added to the I2S0 node and clock properties are added
to the MAX98090 codec node to allow it to control/read frequency
of the MCLK clock directly.
This patch adds stdout-path property to chosen nodes of Exynos4 boards
to enable use of earlycon feature without the need to hardcode port
number in kernel itself.
Signed-off-by: Tomasz Figa <t.figa@samsung.com>
All currently supported boards use hsotg/dwc2 controller in device
('peripheral') mode, so add property which sets correct operation mode.
This patch fixes support in recent changes in dwc2 driver, which added
support for dual-role devices.
Suggested-by: Paul Zimmerman <paulz@synopsys.com>
This ensures the core and the audio subsystem clocks are configured
properly, as expected by the sound machine driver. These bits are
missing to obtain proper audio sample rates in kernel v3.17, where
audio support for Odroid X2/U3 was first added.
Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
Specify the default mux and divider clocks in device tree
to ensure the FIMC devices on Trats, Trats2, Universal_c210
and Odroid X2/U3 boards are clocked from recommended clock
source and with maximum supported frequency.
For Trats2 also the MIPI-CSIS and the camera sensor clocks
are configured, the 'clock-frequency' property is deprecated
in favour of 'assigned-clock-rates' property.
dw-mmc in exynos
dw-mmc controller can support multiple slots.
But, there are no use-cases anywhere. So we don't need to support the
slot-node for dw-mmc controller.
And "supports-highspeed" property in dw-mmc is deprecated.
"supports-highspeed" property can be replaced with "cap-sd/mmc-highspeed".
Signed-off-by: Jaehoon Chung <jh80.chung@samsung.com>
Reviewed-by: Tushar Behera <trblinux@gmail.com>
Reviewed-by: Ulf Hansson <ulf.hansson@linaro.org>
Tested-by: Sachin Kamat <sachin.kamat@samsung.com>
[kgene.kim@samsung.com: rebased exynos5250-snow changes]
Increase max i2c bus frequency beyond the default for faster
data transfers. According to the manual, these faster speeds are
only available when the board is wired up the right way. In this case,
the vendor kernel has run at this speed for a long time.
sda-delay is needed for talking to RTC on PMIC, otherwise the i2c
controller never sees an ACK. Strangely the other PMIC i2c slave (the
main one) works fine even without this delay. I Chose value 100 to
match the vendor kernel.
Signed-off-by: Daniel Drake <drake@endlessm.com>
Reviewed-by: Tomasz Figa <t.figa@samsung.com>
Tested-by: Tomeu Vizoso <tomeu@tomeuvizoso.net>
The ODROID kernel shows that the PMIC interrupt line is hooked up
to pin GPX3-2.
This is needed for the max77686-irq driver to create the PMIC IRQ
domain, which is needed by max77686-rtc.
Add MAX98090 audio codec, I2S interface and the sound complex
nodes to enable audio on Odroid-X2/U3 boards.
TFLASH (SDHCI2 controller) uses internal card detect line, but it looks
that the driver fails to operate it properly. Use GPIO interrupt on
SD_CDn line for detecting SD card state.
This patch adds support for simple GPIO-based button availabled on
Exynos4 based Odroid boards. All supported boards have POWER button,
which has been defined in exynos4412-odroid-common.dtsi. X/X2 boards
also have additional user-configurable button which has been mapped to
KEY_HOME. All defined keys have been marked as possible wakeup source.
On Odroid U2/U3 BUCK8 is used for providing power to also to P3V3
source, which is also connected to LAN9730 chip's nRESET signal. To
reset lan chip on system reboot, the BUCK8 output should not be used in
'always on' mode. This change has no impact on X/X2 boards.
Signed-off-by: Kamil Debski <k.debski@samsung.com>
This patch moves some parts of exynos4412-odroidx.dts to common
exynos4412-odroid-common.dtsi file and adds support for Odroid X2 and
U2/U3 boards. X2 is same as X, but it has faster SoC module (1.7GHz
instead of 1.4GHz), while U2/U3 differs from X2 by different way of
routing signals to host USB hub. It also lacks some hw modules not yet
supported by those dts files (i.e. LCD & touch panel).
