The Odroid-U3 board has an IP4791CZ12 level shifter that is
disabled if the HPD is low, which means that the CEC pin is
disabled as well.
Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com>
Signed-off-by: Krzysztof Kozlowski <krzk@kernel.org>
Add CPU operating points for Exynos4412 Prime (it supports
additional 1704MHz & 1600MHz OPPs and 1500MHz OPP is just
a regular non-turbo OPP on this SoC). Also update relevant
cooling maps to account for new OPPs.
ODROID-X2/U2/U3 boards use Exynos4412 Prime SoC version so
update their board files accordingly.
Based on Hardkernel's kernel for ODROID-X2/U2/U3 boards.
Cc: Doug Anderson <dianders@chromium.org>
Cc: Andreas Faerber <afaerber@suse.de>
Cc: Thomas Abraham <thomas.ab@samsung.com>
Cc: Tobias Jakobi <tjakobi@math.uni-bielefeld.de>
Cc: Ben Gamari <ben@smart-cactus.org>
Signed-off-by: Bartlomiej Zolnierkiewicz <b.zolnierkie@samsung.com>
This patch fixes the following DTC warnings:
"Node /memory has a reg or ranges property, but no unit name"
Signed-off-by: Javier Martinez Canillas <javier@osg.samsung.com>
The skeleton.dtsi file was removed in ARM64 for different reasons as
explained in commit ("3ebee5a2e141 arm64: dts: kill skeleton.dtsi").
These also applies to ARM and it will also allow to get rid of the
following DTC warnings in the future:
The disassembled DTB are almost the same besides an empty chosen
node being removed and nodes reordered, so it should not have
functional changes.
The eMMC card vmmc-supply contained incorrectly two regulators: LDO20
and buck8. The second one is ignored. Additionally the buck8 is a vqmmc
supply only on X and X2. On U3 the buck8 is providing power to the LAN
(SMSC95xx) so instead the LDO22 should be used.
Fix this by defining proper vmmc and vqmmc supplies for respective
boards.
Signed-off-by: Krzysztof Kozlowski <k.kozlowski@samsung.com>
Reviewed-by: Javier Martinez Canillas <javier@osg.samsung.com>
The <dt-bindings/gpio/gpio.h> header is already included in the
exynos4412-odroid-common DTSI so there's no need to do it again
in the DTS file.
The board DTS are using numeric values instead of the defined GPIO
constanst to express polarity, use them to make the DTS more clear.
Signed-off-by: Kukjin Kim <kgene@kernel.org>
With those bindings it is possible to use pwm-fan device available in
Odroid U3 as a cooling device.
Signed-off-by: Lukasz Majewski <l.majewski@samsung.com>
Acked-by: Eduardo Valentin <edubezval@gmail.com>
Reviewed-by: Krzysztof Kozlowski <k.kozlowski@samsung.com>
Add pwm-fan node to the Odroid-U3 board file to enable PWM control of the
cooling fan. In addition, add the "pwm" label to the pwm@139D0000 node
in the exynos4412.dtsi.
Signed-off-by: Kamil Debski <k.debski@samsung.com>
SPI1 is available on IO Port #2 (as depicted on their website)
in PCB Revision 0.5 of Hardkernel Odroid U3 board.
The shield connects a 256KiB spi-nor flash on that bus.
Signed-off-by: Alexis Ballier <aballier@gentoo.org>
Now when the CDCLK I2S output clock can be handled through the clock
API the Odroid X2/U3 can be switched to the simple-audio-card DT binding.
Signed-off-by: Sylwester Nawrocki <s.nawrocki@samsung.com>
Signed-off-by: Mark Brown <broonie@kernel.org>
Add MAX98090 audio codec, I2S interface and the sound complex
nodes to enable audio on Odroid-X2/U3 boards.
Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
This patch moves some parts of exynos4412-odroidx.dts to common
exynos4412-odroid-common.dtsi file and adds support for Odroid X2 and
U2/U3 boards. X2 is same as X, but it has faster SoC module (1.7GHz
instead of 1.4GHz), while U2/U3 differs from X2 by different way of
routing signals to host USB hub. It also lacks some hw modules not yet
supported by those dts files (i.e. LCD & touch panel).
