The board DTS are using numeric values instead of the defined GPIO
constanst to express polarity, use them to make the DTS more clear.
Signed-off-by: Javier Martinez Canillas <javier@osg.samsung.com>
Signed-off-by: Kukjin Kim <kgene@kernel.org>
With those bindings it is possible to use pwm-fan device available in
Odroid U3 as a cooling device.
Signed-off-by: Lukasz Majewski <l.majewski@samsung.com>
Acked-by: Eduardo Valentin <edubezval@gmail.com>
Reviewed-by: Krzysztof Kozlowski <k.kozlowski@samsung.com>
Add pwm-fan node to the Odroid-U3 board file to enable PWM control of the
cooling fan. In addition, add the "pwm" label to the pwm@139D0000 node
in the exynos4412.dtsi.
Signed-off-by: Kamil Debski <k.debski@samsung.com>
SPI1 is available on IO Port #2 (as depicted on their website)
in PCB Revision 0.5 of Hardkernel Odroid U3 board.
The shield connects a 256KiB spi-nor flash on that bus.
Signed-off-by: Alexis Ballier <aballier@gentoo.org>
Now when the CDCLK I2S output clock can be handled through the clock
API the Odroid X2/U3 can be switched to the simple-audio-card DT binding.
Signed-off-by: Sylwester Nawrocki <s.nawrocki@samsung.com>
Signed-off-by: Mark Brown <broonie@kernel.org>
Add MAX98090 audio codec, I2S interface and the sound complex
nodes to enable audio on Odroid-X2/U3 boards.
Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
This patch moves some parts of exynos4412-odroidx.dts to common
exynos4412-odroid-common.dtsi file and adds support for Odroid X2 and
U2/U3 boards. X2 is same as X, but it has faster SoC module (1.7GHz
instead of 1.4GHz), while U2/U3 differs from X2 by different way of
routing signals to host USB hub. It also lacks some hw modules not yet
supported by those dts files (i.e. LCD & touch panel).
