sources
Replace hard-coded values of interrupt flags with respective macros from
header to increase code readability.
Suggested-by: Marek Szyprowski <m.szyprowski@samsung.com>
Signed-off-by: Krzysztof Kozlowski <krzk@kernel.org>
Odroid-X2 differs from Odroid-X only in RAM and prime CPU.
Remove doubled nodes from exynos4412-odroidx2.dts and move
sound node to exynos4412-odroidx.dts to enable sound on both boards.
Signed-off-by: Markus Reichl <m.reichl@fivetechno.de>
Reviewed-by: Krzysztof Kozlowski <krzk@kernel.org>
Odroid-X, -X2, -XU3 and -XU4 have SOC-ADC routed to an external connector.
Enable the ADC for use as iio-device.
git://git.kernel.org/pub/scm/linux/kernel/git/krzk/linux into next/dt
Pull "Topic branch for Samsung DeviceTree cleanup for 4.9" from Krzysztof Kozłowski:
Replace in DT sources hard-coded values for pinctrl configuration like pull
up/down, drive strength and function. This makes the DTS easier to read,
especially that some drive strengths values are quite non-obvious.
* tag 'samsung-dt-pinctrl-4.9' of git://git.kernel.org/pub/scm/linux/kernel/git/krzk/linux:
ARM: dts: s3c64xx: Use macros for pinctrl configuration
ARM: dts: s3c2416: Use macros for pinctrl configuration
ARM: dts: s5pv210: Use macros for pinctrl configuration
ARM: dts: s3c64xx: Use common macros for pinctrl configuration
ARM: dts: exynos: Fix mismatched values of SD drive strengh configuration on exynos4415
ARM: dts: exynos: Fix mismatched value for SD4 pull up/down configuration on exynos4210
ARM: dts: exynos: Use macros for pinctrl configuration on exynos542x/exynos5800
ARM: dts: exynos: Use macros for pinctrl configuration on exynos5410
ARM: dts: exynos: Use macros for pinctrl configuration on exynos5260
ARM: dts: exynos: Use macros for pinctrl configuration on exynos5250
ARM: dts: exynos: Use macros for pinctrl configuration on exynos4415
ARM: dts: exynos: Use macros for pinctrl configuration on exynos4x12
ARM: dts: exynos: Use macros for pinctrl configuration on exynos4210
ARM: dts: exynos: Use macros for pinctrl configuration on exynos3250
ARM: dts: exynos: Use common macros for pinctrl configuration
pinctrl: dt-bindings: samsung: Update documentation with new macros
pinctrl: dt-bindings: samsung: Add header with values used for configuration
Usage of DTS macros instead of hard-coded numbers makes code easier to
read. One does not have to remember which value means pull-up/down or
specific driver strength.
Signed-off-by: Krzysztof Kozlowski <k.kozlowski@samsung.com>
Reviewed-by: Javier Martinez Canillas <javier@osg.samsung.com>
This patch fixes the following DTC warnings:
"Node /memory has a reg or ranges property, but no unit name"
Signed-off-by: Javier Martinez Canillas <javier@osg.samsung.com>
The skeleton.dtsi file was removed in ARM64 for different reasons as
explained in commit ("3ebee5a2e141 arm64: dts: kill skeleton.dtsi").
These also applies to ARM and it will also allow to get rid of the
following DTC warnings in the future:
The disassembled DTB are almost the same besides an empty chosen
node being removed and nodes reordered, so it should not have
functional changes.
The eMMC card vmmc-supply contained incorrectly two regulators: LDO20
and buck8. The second one is ignored. Additionally the buck8 is a vqmmc
supply only on X and X2. On U3 the buck8 is providing power to the LAN
(SMSC95xx) so instead the LDO22 should be used.
Fix this by defining proper vmmc and vqmmc supplies for respective
boards.
Though the keyboard and other driver will continue to support the legacy
"gpio-key,wakeup", "linux-keypad,wakeup" boolean property to enable the
wakeup source, "wakeup-source" is the new standard binding.
This patch replaces all the legacy wakeup properties with the unified
"wakeup-source" property in order to avoid any further copy-paste
duplication.
Reviewed-by: Krzysztof Kozlowski <k.kozlowski@samsung.com>
Signed-off-by: Sudeep Holla <sudeep.holla@arm.com>
The board DTS are using numeric values instead of the defined GPIO
constanst to express polarity, use them to make the DTS more clear.
Signed-off-by: Kukjin Kim <kgene@kernel.org>
Usage of labels instead of full paths reduces possible mistakes when
overriding nodes.
Signed-off-by: Krzysztof Kozlowski <k.kozlowski.k@gmail.com>
For thermal zones:
Acked-by: Eduardo Valentin <edubezval@gmail.com>
This patch adds support for simple GPIO-based button availabled on
Exynos4 based Odroid boards. All supported boards have POWER button,
which has been defined in exynos4412-odroid-common.dtsi. X/X2 boards
also have additional user-configurable button which has been mapped to
KEY_HOME. All defined keys have been marked as possible wakeup source.
Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
This patch moves some parts of exynos4412-odroidx.dts to common
exynos4412-odroid-common.dtsi file and adds support for Odroid X2 and
U2/U3 boards. X2 is same as X, but it has faster SoC module (1.7GHz
instead of 1.4GHz), while U2/U3 differs from X2 by different way of
routing signals to host USB hub. It also lacks some hw modules not yet
supported by those dts files (i.e. LCD & touch panel).
Last megabyte of RAM is used by secure firmware and should not be accessed
by Linux kernel, so correct available memory size in DTS file.
This patch adds basic support for USB modules (host and device) on
OdroidX board.
Signed-off-by: Kamil Debski <k.debski@samsung.com>
[removed incorrect port@2 node]
This patch adds support for common hardware modules available on all
Exynos4412-based Odroid boards, which already have complete support in
mainline kernel. This includes secure firmware calls, watchdog, g2d and
fimc (mem2mem) multimedia accelerators.
git://git.kernel.org/pub/scm/linux/kernel/git/kgene/linux-samsung into next/cleanup3
Merge "Exynos cleanup for v3.15" from Kukjin Kim:
- reorganize code for
- add support reserve memory for mfc-v7
- consolidate exynos4 and exynos5 machine codes
- add generic compatible strings for exynos4 and exynos5
- update DT with generic compatible strings
- move clk related dt-binding header file in dt-bindings/clock
* tag 'exynos-cleanup' of git://git.kernel.org/pub/scm/linux/kernel/git/kgene/linux-samsung:
dt-bindings: clock: Move exynos-audss-clk.h to dt-bindings/clock
ARM: dts: Update Exynos DT files with generic compatible strings
ARM: EXYNOS: Add generic compatible strings
ARM: EXYNOS: Consolidate exynos4 and exynos5 machine files
ARM: EXYNOS: Consolidate CPU init code
ARM: SAMSUNG: Introduce generic Exynos4 and 5 helpers
ARM: EXYNOS: Add support to reserve memory for MFC-v7
ARM: SAMSUNG: Reorganize calls to reserve memory for MFC
arch/arm/mach-exynos/exynos.c
Signed-off-by; Arnd Bergmann <arnd@arndb.de>
Add generic compatible strings to the respective board DT files.
Signed-off-by: Sachin Kamat <sachin.kamat@linaro.org>
To allow EXYNOS4412 based Odroidx and Origen-quad boards to operate between
200MHz to 1.4Ghz, update the vdd_arm voltage range to operate between these
cpu clock speeds.
Cc: Dongjin Kim <tobetter@gmail.com>
Signed-off-by: Thomas Abraham <thomas.ab@samsung.com>
git://git.linaro.org/people/mike.turquette/linux
Pull clk framework changes from Mike Turquette:
"The first half of the clk framework pull request is made up almost
entirely of new platform/driver support. There are some conversions
of existing drivers to the common-clock Device Tree binding, and a few
non-critical fixes to the framework.
Due to an entirely unnecessary cyclical dependency with the arm-soc
tree this pull request is broken into two pieces. The second piece
will be sent out after arm-soc sends you the pull request that merged
in core support for the HiSilicon 3620 platform. That same pull
request from arm-soc depends on this pull request to merge in those
HiSilicon bits without causing build failures"
[ Just did the ARM SoC merges, so getting ready for the second clk tree
pull request - Linus ]
* tag 'clk-for-linus-3.14-part1' of git://git.linaro.org/people/mike.turquette/linux: (97 commits)
devicetree: bindings: Document qcom,mmcc
devicetree: bindings: Document qcom,gcc
clk: qcom: Add support for MSM8660's global clock controller (GCC)
clk: qcom: Add support for MSM8974's multimedia clock controller (MMCC)
clk: qcom: Add support for MSM8974's global clock controller (GCC)
clk: qcom: Add support for MSM8960's multimedia clock controller (MMCC)
clk: qcom: Add support for MSM8960's global clock controller (GCC)
clk: qcom: Add reset controller support
clk: qcom: Add support for branches/gate clocks
clk: qcom: Add support for root clock generators (RCGs)
clk: qcom: Add support for phase locked loops (PLLs)
clk: qcom: Add a regmap type clock struct
clk: Add set_rate_and_parent() op
reset: Silence warning in reset-controller.h
clk: sirf: re-arch to make the codes support both prima2 and atlas6
clk: composite: pass mux_hw into determine_rate
clk: shmobile: Fix MSTP clock array initialization
clk: shmobile: Fix MSTP clock index
ARM: dts: Add clock provider specific properties to max77686 node
clk: max77686: Register OF clock provider
This patch adds a label and #clock-cells property to device node of
max77686 PMIC to allow using it as a clock provider.
Signed-off-by: Tomasz Figa <t.figa@samsung.com>
Acked-by: Kyungmin Park <kyungmin.park@samsung.com>
Signed-off-by: Mike Turquette <mturquette@linaro.org>
All SoCs from Exynos4x12 series contain the MSHC block, so its node can
be located in exynos4x12.dtsi. In addition, missing clock specifiers
are added, generic SoC attributes are moved from board dts files
to common dtsi file of SoC family and the node is renamed to a more
generic name to follow node naming recommendations.
Replace /include/ (dtc) with #include (C pre-processor) for all
Samsung DT files
Signed-off-by: Padmavathi Venna <padma.v@samsung.com>
Reviewed-by: Sylwester Nawrocki <s.nawrocki@samsung.com>
Reviewed-by: Doug Anderson <dianders@chromium.org>
This patch is to add vmmc regulator node at MSHC and SDHCI for ODROID-X
board file.
Signed-off-by: Dongjin Kim <tobetter@gmail.com>
ODROID-X board have a max77686 PMIC on i2c channel 0. The properties of used
LDO and BUCK are defined according the schematic.
git://git.kernel.org/pub/scm/linux/kernel/git/kgene/linux-samsung into next/drivers
From Kukjin Kim <kgene.kim@samsung.com>:
add suppport common clock framework for exynos
* tag 'clk-exynos-for-v3.10' of git://git.kernel.org/pub/scm/linux/kernel/git/kgene/linux-samsung: (73 commits)
ARM: EXYNOS: fix compilation error introduced due to common clock migration
clk: exynos5250: Fix divider values for sclk_mmc{0,1,2,3}
clk: exynos4: export clocks required for fimc-is
clk: samsung: Fix compilation error
clk: exynos5250: register display block gate clocks to common clock framework
clk: exynos4: Add support for SoC-specific register save list
clk: exynos4: Add missing registers to suspend save list
clk: exynos4: Remove E4X12 prefix from SRC_DMC register
clk: exynos4: Add E4210 prefix to GATE_IP_PERIR register
clk: exynos4: Add E4210 prefix to LCD1 clock registers
clk: exynos4: Remove SoC-specific registers from save list
clk: exynos4: Use SRC_MASK_PERIL{0,1} definitions
clk: exynos4: Define {E,V}PLL registers
clk: exynos4: Add missing mout_sata on Exynos4210
clk: exynos4: Add missing CMU_TOP and ISP clocks
clk: exynos4: Add G3D clocks
clk: exynos4: Add camera related clock definitions
clk: exynos4: Export mout_core clock of Exynos4210
clk: samsung: Remove unimplemented ops for pll
clk: exynos4: Export clocks used by exynos cpufreq drivers
[arnd: add missing #address-cells property in mshc DT node]
The clock frequency of xxti and xusbxti clocks is dependent on the
frequency of the on-board oscillator that is used to generate these
clocks. So allow the frequency of these clocks to be specfied from
device tree.
Signed-off-by: Thomas Abraham <thomas.abraham@linaro.org>
This patch enables RTC device node defined in exynos4.dtsi for
exynos4412-odroidx.
This fixes the property of dw-mshc-sdr-timing and dw-mshc-ddr-timing as per
its current binding, it only has two cells.
Add initial DT for Hardkernel's ODROID-X board based on EXYNOS4412
SoC. This patch including adds the node to support fixed voltage for
peripherals like LED, ethernet controller, and this patch adds GPIO
connected LEDS on ODROID-X board and configure its properties like
following:
LED1: use 'heartbeat' trigger, blinking while the board is running.
LED2: use 'mmc0' trigger, on when mmc0 is accessing.
And adds the device node to support eMMC storage on SDCARD4 ports,
controlled by MSHC.
Acked-by: Olof Johansson <olof@lixom.net>
[kgene.kim@samsung.com: squashed into one commit as per Olof's comment]
